| Home Theater Projectors Best Projector for $5000 budget?Discuss Best Projector for $5000 budget? in the Home Theater | Audio and Video forum; Best Projector for $5000 budget? Just want to hear everyone's opinion on the best 1080p projector for $5000. I am looking into getting one this ... |
| | #1 (Link) | |||
| Best Projector for $5000 budget? Just want to hear everyone's opinion on the best 1080p projector for $5000. I am looking into getting one this year and I have no clue on where to start my research. Thanks: | |||
| | #2 (Link) | ||||
| Re: Best Projector for $5000 budget? Quote:
But if we're going off what I know and not hearsay, I'm of the opinion that the BenQ W10000 and Optoma HD-81 are the ones to beat in the higher-range 1080p market. Of course, I haven't had a chance to see even close to all of what is out there...that's half the fun! | ||||
| | #6 (Link) | |||
| Re: Best Projector for $5000 budget? Hi Steve, I don't know how big Infocus is as a brand in the US, but here in the UK for your budget I'd highly recommend the Infocus IN82. Our budget was slightly less than yours and so we went for the IN81 and the picture quality from a Sony BluRay DVD player is simply stunning. The IN82 is just that much better in all respects. It's also virtually silent. Regards, Tony | |||
| | #7 (Link) | |||
| Re: Best Projector for $5000 budget? You can't go wrong with a 5k budget these days. Any of the above mentioned FPs will do. Just read reviews about them, check their maunals to see what features you like more. I would suggest the Mits HC 6000 for ex. if you look for power zoom...etc. Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| | #8 (Link) | ||||
The relative importance of lumen output, contrast, black level, lens shift range, fan noise....etcetera, it all depends on how you are setting up your home cinema (screen height, seating distance, lighting conditions). If you could eleborate a bit on this... I am sure the responses you get will have a bigger change to narrow down and speed up your choice making process. Good luck! Maikel | ||||
| Thread Tools | |
Similar Threads | ||||
| Sound on a budget? | faigenistic | Home Audio Speakers | 21 | 01-21-08 01:38 PM |
| Budget AVR? | faigenistic | Home Theater Components | 5 | 11-08-07 11:17 PM |
| Which budget LCD projector? | paulspencer | Home Theater Projectors | 5 | 10-27-07 11:19 PM |
| Budget DIY 7.1 | hardman | DIY Speakers | 1 | 04-16-07 05:24 PM |
| Very low budget sub. | mgboy | DIY Subwoofers - Sealed and Ported | 53 | 02-05-07 09:48 PM |
