| Home Theater Projectors Sanyo lens shift adjustmentDiscuss Sanyo lens shift adjustment in the Home Theater | Audio and Video forum; Sanyo lens shift adjustment Could someone explain how the vertical and horizontal lens adjustment on a projector like the Sanyo Z works? I've looked ... |
| | #1 (Link) | |||
| Sanyo lens shift adjustment Could someone explain how the vertical and horizontal lens adjustment on a projector like the Sanyo Z works? I've looked over the manual and it isn't clear to me how the range of motion operates, can the pictures position be adjusted anywhere from point a to b of the adjustment ark? | |||
| | #2 (Link) | |||
| Re: Sanyo lens shift adjustment I don't know which Z you have, but yeah, it's that simple. There's some aberration in the image when it's at full throw (pixels are trapezoids instead of squares), but it's not nearly as bad as the keystone adjustment if your projector is too high or low. I have to really look for it to even see it. I have my Z4 at max horizontal and just a little bit in the vertical. It allowed me to mount it on my equipment rack, rather than the ceiling in the back of the room. Be sure to also engage the lock when you are done, or vibrations can cause the offset to drift. I hope this helps. Good luck. | |||
| | #3 (Link) | ||||
| Re: Sanyo lens shift adjustment Quote:
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Vertical Lens Shift | mitchok | Home Theater Projectors | 3 | 02-06-08 11:03 AM |
| 2 sub phase adjustment | jwhite8086 | Home Audio Acoustics | 7 | 12-02-07 05:02 PM |
| Outboard phase adjustment device? | brucemck2 | REW Forum | 3 | 11-25-07 04:17 PM |
| Clean Projector lens safely????? | alan monro | Home Theater Projectors | 1 | 06-16-07 08:26 PM |
| Subwoofer LFE adjustment questions... | Darren | Home Audio Subwoofers | 62 | 07-28-06 07:08 PM |
