Go Back   Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors
Register
Noob question regarding placement of projector
Discuss Noob question regarding placement of projector in the Home Theater | Audio and Video forum; Noob question regarding placement of projector Hi Everyone, I'm planning on purchasing an Epson 1080p UB projector. My room has a ceiling that's 10 ft. high. ...
Discount Merchant
Old 02-20-08, 10:46 AM   #1 (Link)
New Member
Alias: Paul
Loc: Long Beach, CA
User: #17073
Since: Feb 2008
pzichi is offline
Hi Everyone,
I'm planning on purchasing an Epson 1080p UB projector. My room has a ceiling that's 10 ft. high. I heard that you should have the projector at least at the height of the top of the screen. The Epson manual says it should be as close to center of screen as possible.
What is usual for the placement (height) of the screen? I'll have a 106" diag Da-Lite. The area of the room is about 22 by 12 feet - seating about 12 feet from the screen. The projector will be placed about 15 feet from the wall.
I made a template of the screen to see how it would look on the wall and at this distance I feel like I have to place the screen fairly low on the wall to feel comfortable (and not craning my head upwards). Maybe I'm just used to viewing my regular HDTV where it's directly in front of me.
Please advise. I appreciate any help you can give me. Thanks.
Paul
Old 02-20-08, 01:11 PM   #2 (Link)
Alias: keith from canada
Loc: Ottawa Canada
User: #16228
Since: Jan 2008
Keith from Canada is offline
Re: Noob question regarding placement of projector
pzichi wrote: View Post
Hi Everyone,
Paul
The rule of thumb for screen placement is the 1/3 rule. When seated, your eyes should be parallel to the 1/3rd point on the screen (2/3 of the screen should be above eye level and 1/3 below). As for placement of the projector, the Epson has a fair amount of play and flexibility. You should put it in a place that's out of the way and where no-one will walk through the light path. Other than those basic guidelines, put it just about anywhere you want it (within reason)...that's the beauty of LCD lens shifting! My advice would be to get the projector, mount the screen and then move the projector to where you want it and see if it works.
Old 02-20-08, 02:36 PM   #3 (Link)
New Member
Alias: Paul
Loc: Long Beach, CA
User: #17073
Since: Feb 2008
pzichi is offline
Keith from Canada wrote: View Post
Thanks much. That's extremely helpful. I'll figure it out.
The Epson will be out of the way (behind the viewing area). Thanks again for your help!
Paul
Old 04-27-08, 11:35 AM   #4 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Hi Paul,
It makes now a little more than 2 months from your last post. Pls share impressions with your UB. FYI I have the same screen size in my room with a Carada BW and I have a lot of fun!
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 04-27-08, 04:39 PM   #5 (Link)
New Member
Alias: Paul
Loc: Long Beach, CA
User: #17073
Since: Feb 2008
pzichi is offline
Hi,
The room is nearly finished but we've already tested the placement. My contractor built a special fold-down door so the projector actually 'disappears' into the opposing wall when not in use (and covered by some artwork that slides across it when not in use).
After much experimenting we came up with the following:
The distance from the projector to the screen is approximately 20 feet. I have the height of the lens at 5.5 feet. If someone stands up it does cross the light path but it's not a big deal since this is primarily for me and my wife's use with an occasional couple of friends.
We did take your advice about the height of the screen - experimented with that as well. We bought a Da-lite 106" diagonal high-contrast matte white screen with a 25" black drop. The ceiling is actually 9' high so that places it almost exactly with your suggestion of 1/3 below 2/3s above. Seating is approximately 13.5' from the screen.
It really looks incredible - particularly with the PS3 Blu-ray player. Sound system is quite nice as well - using a Denon 3808i receiver with B&W speakers and Velodyne subwoofer.
Have to be without it now for another week and a half as they are going to install a hardwood floor (carpeting would be too deadening for the acoustics). Experimented with that as well and this seems the best solution. If it's too reverberant then we'll add throw rugs as well.
Thanks for your interest. Once again, I really appreciated your thoughtful insights for a solution to my particular situation.
Paul
Old 04-27-08, 04:51 PM   #6 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Paul,
Looks like you have some very nice gear. Is the projector bright enough for your taste? I see you're using a unity gain screen and throwing from quite far. Which mode are you using for movies?
How does Bluray compare with DVDs on that projector? Any chance we can have some screenshots?
Old 04-27-08, 10:22 PM   #7 (Link)
New Member
Alias: Paul
Loc: Long Beach, CA
User: #17073
Since: Feb 2008
pzichi is offline
It's absolutely bright enough. I've been using 'Theatre' mode but there is also one named 'Dynamic' that makes it even brighter (for use when the room is not very dark).
The PS3 does a good job of upconverting regular DVDs but honestly, regular DVDs are a bit 'soft' compared to razor sharpness of the Blu-ray discs. I've also got DirecTV hooked up to it - looks fantastic with this set up.
Once the room is completed I may consider having the Epson calibrated but right now it looks quite good right out of the box.
I'll try to provide some shots when the room is finished (about 2 more weeks).
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Similar Threads
Noob Question Eugene General Discussion 5 12-21-07 06:16 PM
Projector placement bcrawfo2 Home Theater Projectors 13 09-25-07 08:58 AM
Noob question on procedure mstailey REW Forum 3 01-19-07 12:32 PM
Noob REW question... Vader REW Forum 2 07-11-06 09:14 AM
Noob question on RS SPL sammythebu11 REW Forum 4 07-10-06 05:40 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
