Go Back   Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors
Register
Problem with InFocus projector and Dell laptop
Discuss Problem with InFocus projector and Dell laptop in the Home Theater | Audio and Video forum; Problem with InFocus projector and Dell laptop I have an InFocus IN26+ which I bought recently mainly to use with a Dell laptop for projecting graphics during ...
Discount Merchant
Old 02-21-08, 08:11 PM   #1 (Link)
Silver Supporter
Alias: Markdu
Loc: Dublin, Ireland
User: #4347
Since: Nov 2006
Mark DuBerry is offline
I have an InFocus IN26+ which I bought recently mainly to use with a Dell laptop for projecting graphics during live music performances. It works perfectly when used with my dvd player for projecting movies. It has had only 40 lamp hours of use.
However, something strange happens when using it with the laptop, which is an older Inspiron 8600. The computer has a pretty good video card which is why I bought it. When it boots up, without telling it to output the video signal, it sometimes either shuts down the projector with its 'change lamp' on, or what happened this evening which is the projector image flickers for a while and then it goes into some sort of semi shutdown mode with a dim blue light coming out of the lamp and the fan still on. In this state, there is only a vague blue image on the screen and I can't access any menu items etc. on the projector and nothing else seems to work. The only thing to do at that stage is to shut it down. I have heard that some Dell laptops have a problem with the vga out; something to do with sending out the wrong voltage which can put a projector into standby or something but that's all I know.
The only two ways I have found around this is either to connect the computer to the projector after it has booted up, sort of 'hot-wiring' it and then to turn on the extended desktop, or else to have everything connected but to turn the laptop on before the projector, the reverse of what is recommended, because the problem only occurs during boot-up. That is okay as long as I don't have to re-boot the laptop but if I do, I run into the same problem. This has got much worse since I had to format the drive and re-install Windows XP recently.
I wonder if anyone can shed any light on this for me as I would like to get it all working properly if possible.
Thanks
Old 02-21-08, 10:57 PM   #2 (Link)
Loc: Lower Alabama
Re: Problem with InFocus projector and Dell laptop
I haven't a clue myself, but it does sound like it is sending some sort of voltage during powering up which is causing a problem with the projector. Have you contacted Dell? They have a massive forum as well.
We use that same projector in our worship service with I believe a Compaq laptop... no issues.
Old 02-22-08, 06:08 AM   #3 (Link)
Silver Supporter
Alias: Markdu
User: #4347
Since: Nov 2006
That's good to hear. I find the projector itself fine.
I'll certainly get in touch with Dell as you suggest.
Thanks for that Sonnie,
Mark
Old 02-23-08, 12:58 AM   #4 (Link)
Alias: lou
Loc: Brooklyn NY
louthewiz's Avatar
User: #16585
Since: Feb 2008
louthewiz is offline
It is a driver problem for sure , you need to install the driver for your projector into the laptop so the projector will be seen as a secondary display ...
Yamaha htr 5790 Pre/pro | Audiosource Amp 300 powering mains | Audiosource Amp 200
powering center | Onkyo m-282 Powering surrounds | Polk rt800 mains | polk Cs400 center |
Polk fx300 side surrounds| polk MKII back surrounds | Velodyne Dps-10 sub + Klipsch Ksw-10
Denon 1600 Sdi modded dvd player + iSCAN HD+ Video scaler |Oppo 980H Toshiba HD-A3 SonicView HD8000 d*sh pvr Panasonic Dmr e-80H dvd recorder
Acer PH530 720p projector Da-Lite Video Spectra screen MonoPrice cables
Old 02-23-08, 08:49 AM   #5 (Link)
Silver Supporter
Alias: Markdu
User: #4347
Since: Nov 2006
I'm not sure about that louthewiz. I don't think there is a driver as such for an external display / projector but I could be wrong. Also there's no problem with it once the laptop is up and running: it works fine with the extended desktop etc. It's only during boot-up. I spoke with tech support at Dell and the guy there confirmed that it's probably to do with the laptop sending a voltage down the line during the POST which is triggering some sort of shut-down in the projector.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Similar Threads
problem with lcd projector pappaj Home Theater Projectors 5 11-09-07 01:38 AM
Sanyo Z2 projector problem tonyvdb Home Theater Projectors 16 09-11-07 04:57 PM
Dell 2300MP Projector DrPainMD Home Theater Projectors 0 03-28-07 06:54 PM
InFocus IN76 Video Projector Review Wayde Home Theater, Audio and Video News 0 08-14-06 02:50 PM
InFocus ScreenPlay 7210 HD DLP Projector JCD Home Theater Projectors 0 08-14-06 11:55 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
