Mits WD65831 - HDMI input doesn't always work - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
Discuss Mits WD65831 - HDMI input doesn't always work in the Home Theater | Audio and Video forum; Mits WD65831 - HDMI input doesn't always work I have a Mits WD-65831. I currently use the HDMI connector for my cable and DVD player. When I turn ...
Discount Merchant
Old 02-25-08, 03:02 PM   #1 (Link)
New Member
Alias: Paul N.
User: #17331
Since: Feb 2008
pmnovak1 is offline
When I turn on my TV and its already on the cable HDMI input, the picture doesn't show up. I need to re-select the input once again to make it work. It almost seems like it doesn't recognize that something is being sent to it, until I manually select that input.
Any ideas?
Old 02-25-08, 03:42 PM   #2 (Link)
Alias: TC
Loc: Worcester Mass.
User: #9814
Since: Jun 2007
tcarcio is offline
Re: Mits WD65831 - HDMI input doesn't always work
HDMI is still glitchy with some equipment. I run into the same problem but I found if I turn my PJ on first and then my reciever it works. So you could try that to see if that works for you also.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
Similar Threads
MITS VS-50805 Problem JVP Manufacturers Service and Support 13 01-29-08 05:23 AM
Mits WD-52327 not powering on or off ck007 Video Displays and Processors 1 11-17-07 08:12 PM
Geometry Help With Mits wd-73833 njfoses Manufacturers Service and Support 2 10-12-07 08:29 PM
Mits VS-50805 problem SAMMY18 Manufacturers Service and Support 1 08-09-07 05:37 AM
HDMI Twins: Is BetterCables Selling an $89 HDMI Switcher for $350? geekwithfamily Home Theater, Audio and Video News 2 02-27-07 11:11 AM
Mach 5 Audio
