| Home Theater Projectors Infocus 4805 to Optoma HD70...what do you think?Discuss Infocus 4805 to Optoma HD70...what do you think? in the Home Theater | Audio and Video forum; Infocus 4805 to Optoma HD70...what do you think? I'm running the IF 4805 and I love it. However, I have an opportunity to purchase a new Optoma HD70 ... |
Views: 540 - Replies: 6
| Infocus 4805 to Optoma HD70...what do you think? I'm running the IF 4805 and I love it. However, I have an opportunity to purchase a new Optoma HD70 for a seriously low price (under $600) and I'm wondering I should jump on it. I will be happy if -- 1) SD material looks as good as it does on the 4805 and 2) HD material looks better. If the HD70 can't do both of those things, I'm not interested in it and will wait for the next big deal (hopefully the Mits HC1500). What are your thoughts? Can the HD70 meet this criteria? | ||||
| | #2 | ||||
| Re: Infocus 4805 to Optoma HD70...what do you think? Optoma HD 70 it is . Provided its is installed perfectly and your image size does not go beyond 100" diagonal. It's a native 720p only . I don't use keystone at all. Since HD70 does not come with lens shift but has a fixed image offset you need to do your calculation first . Please visit this site http://www.projectorcentral.com/proj...ulator-pro.cfm input the make and model and you can calculate the parameters.Good luck ! ![]() | ||||
| | #3 | |||||
| Re: Infocus 4805 to Optoma HD70...what do you think? Quote:
I'm dealing with a similar projector now in the 4805...large offset, no lens shift. I do notice that the throw distance is a little different but only by a few inches. The offset is the same as the 4805 (around 30%) which works with my 7'6" ceiling so I should be fine there as well. At the price I'm paying, I think that it should make for a pretty good substitute for the 4805. The other good thing is that I have an ISF calibrator crashing at my house next weekend! | |||||
| | #4 | ||||
| Re: Infocus 4805 to Optoma HD70...what do you think? Hi Keith, Yes. The HD-70 has a fixed offset of 36% . So for a 100" diagonal ,from the centre of the lens you will have a image offset of 17.64".HD-65 is a new model . worth taking a look if you have uncontrolled light ambiance in your set up. Besides ISF calibration will make your Home theater "Picture Perfect".Regards Rajesh ![]() | ||||
| | #5 | |||||
| | #6 | |||||
So, the search continues! I fully expect the HC1500 (or equivalent) to drop to a similar price in the not too distant future. | |||||
