| Home Theater Projectors Keystoning image, Loss of quality?Discuss Keystoning image, Loss of quality? in the Home Theater | Audio and Video forum; Keystoning image, Loss of quality? My Sanyo Z2 is ceiling mounted about 10ft from the screen and level with the top but the image is ... |
Views: 571 - Replies: 17
| Keystoning image, Loss of quality? My Sanyo Z2 is ceiling mounted about 10ft from the screen and level with the top but the image is slightly wider on the bottom than on the top of the screen. My question is I can use the Keystone feature to fix this but does that affect the image quality? Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #2 | ||||
| Re: Keystoning image, Loss of quality? I am not specifically familiar with that unit, but I thought it had a lens shift adjustment to allow you to correct for keystone optically and not electronically. If you correct optically on a projector you generally do not significantly affect quality until you go pretty far. If you have to correct it electronically on a fixed pixel projector, you will distort the pixels and have unwanted effects such as moire. On a CRT projector, of course, this is not a problem. Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | ||||
| | #3 | ||||
| Re: Keystoning image, Loss of quality? The lens shift is working properly but there still seems to be a wider image at the bottom than at the top by about 1/4 inch on each side. The projector is pointed directly at the screen. seen here Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #4 | ||||
| Re: Keystoning image, Loss of quality? Tony, Although the projector may be even with the top of the screen (same distance from the ceiling), both the screen and the projector must be level to avoid needing to use the keystone adjustment. My guess would be that you will find a slight downward tip (at the front) on the projector. This would cause the image to be slightly larger on the bottom than the top. From your description, it should only be off a smidge. The projector needs to be level in all directions. Side to side and front to back. The keystone correction will indeed distort the image, causing stair stepping in the image. It sounds like yours is not far off. You may need to lower the projector a tiny bit to be able to level it off front to rear and have the image stay on the screen, or maybe raise the screen a touch. When installing my projector, I worked it in reverse. I installed the projector, zeroed out the keystone, leveled the projector using a level and double checked it using the projected the image on my wall making sure it was square by measuring it twelve ways to sunday...and then hung the screen where the image was. Perfect fit. Good luck resolving the issue. Mike | ||||
| | #5 | ||||
| Re: Keystoning image, Loss of quality? To answer your question, 'yes' keystone effects quality. The effects can be clearly seen in a bandwidth display test. However getting a projector mounted perfectly is not always possible when the room is used for general duties. Quite often a compromise has to be made, requiring loss of best setup for the PJ. The trick is to find the range of positions where you don't cause ill effects that you discribe and position the pj to be within this range. Then ask yourself if this fits the room for it's other uses? Some things to consider as you do this though, is the screen level, virtical, square to the Pj; Is the pj level square to the screen. If you get where I am going you understand that alignment starts with the fundimentals. Ignore them and the result gets harder to resolve. Laser levels and or string lines measuring tape and a spare pair of hands are the tools needed, checking levels and squareness can solve alot of ills. I might add that most projectors have a natural central position of about 1/4~1/3 from the lower or upper edge(depending if you are roof mounted or not). Being set at the edge at a relatively close range of 10ft will make things hard to resolve. A trick though is to angle the bottom of the screen up, drop the angle of the PJ down. A couple of degrees would be hard to notice but may remove the shape issue. Depends on how far you need to go. Have a careful read of your manual for 'best pos'tion' then see how you are setup. goodluck. Light changes what it is doing depending if we are looking or not. Considering we only see this as a reflection of the past....what is it really doing now? | ||||
| | #6 | ||||
| Re: Keystoning image, Loss of quality? glad i read this.....never even thought of raising the feet on the pj and lowering the lens shift to eliminate the +1 keystone i had before.... My pj is sitting on a shelf at ceiling height and this worked great!!! ![]() Thanks guys!! | ||||
| | #7 | ||||
| Re: Keystoning image, Loss of quality? Yup, I just had to angle up the front of the projector and adjust the lens shift and all is well. Thanks everyone for the suggestions. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #8 | ||||
| Re: Keystoning image, Loss of quality? While keystone will distort the image, I don't think a small amount will badly affect the viewing experience that much. At least it is better than watching a trapezoidal picture ![]() ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #9 | ||||
| Re: Keystoning image, Loss of quality? You can effectively turn a 1080 image into a 720 image by using keystone correction. It is very worthwhile to get alignment as good as one can. It is infact the fundimental first step in image calibration. Light changes what it is doing depending if we are looking or not. Considering we only see this as a reflection of the past....what is it really doing now? | ||||
| | #10 | ||||
| Re: Keystoning image, Loss of quality? I completely differ on that. I would much rather have a bit of keystone or have to tilt the screen a bit than have the distortion and reduction in resolution that electronically keystoning the image will effect. It is almost never impossible to properly place the projector and or screen so that it is not necesary, and if it is impossible, tilting the screen a few degrees is a perfectly good alternative. Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | ||||
| | #11 | ||||
| Re: Keystoning image, Loss of quality? OK. But I do some keystoning and I can never see any difference (with or without), but a trapezoidal shape. Tilting a screen is not very esthetic as well BTW. Can you tell me how much resolution will be affected? ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #12 | ||||
| Re: Keystoning image, Loss of quality? A lot. Put a resolution pattern or multiburst pattern up and you will be shocked. Or don't! Once you see what it is doing to the image in the test patterns you may see it in other images. If you don't see it now and you don't plan to modify your installation, STOP asking questions. Ignorance is bliss. Ignore my sig. Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | ||||
| | #14 | ||||
| Re: Keystoning image, Loss of quality? I am speaking about SLIGHT keystone I am using (+2). Of course I have run test patterns and the effects are neglectable in my setup....Full Stop! But tilting the screen is unthinkable! ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #15 | ||||
| Re: Keystoning image, Loss of quality? I'm inclined to agree with blazer on keystoning.. I've adjusted keystone with my DLP projector without any detrimental affect on the quality of the image.. I think it must be that some projectors handle it better than others,.. Prof.. Home Theatre...the never ending story! | ||||
| | #16 | ||||
| Re: Keystoning image, Loss of quality? Exactly, I forgot to mention that: Yes all projectors will have a degradation in picture quality, some huge and other not so: not all projectors are created equal ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #17 | ||||
| Re: Keystoning image, Loss of quality? With respect to electronic keystoning they are all very similar. Just put a multiburst pattern up. You will see what happens to your fine resolution and the artifacts that result. Think about what has to happen to correct it. It is the equivalent at scaling an image to slightly incrementing frequencies on each line. You get a mess. Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | ||||
| | #18 | ||||
| Hehehehehehe | ||||
