Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Receivers | Processors | Amps
Audyssey MultEQ Discussion Thread
Discuss Audyssey MultEQ Discussion Thread in the Home Theater | Audio and Video forum; Audyssey MultEQ Discussion Thread Kal Rubinson wrote: Known bug? Under what circumstances? Its not really a "bug" but Audyssey MultEQ is known to set ...
Views: 6078 - Replies: 175
Old 07-18-09, 01:34 PM   #101
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Audyssey MultEQ Discussion Thread
Kal Rubinson wrote: View Post
Its not really a "bug" but Audyssey MultEQ is known to set the level of the subwoofer to low in alot of cases.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 07-18-09, 04:39 PM   #102
Silver Supporter
Alias: Ray
cavchameleon's Avatar
Loc: Albuquerque, NM
User: #15210
Since: Jan 2008
  cavchameleon is offline
Hi Tony,
I think that many feel the sub levels are too low with Audyssey because they are used to having the subs a bit hot. Audyssey sets the level very flat and if one is use to even a 2db hot sub, it will sound too low. I though this also until I got used to it and could hear more detail (esp with bass guitar and lower registers of piano).
Ray
Ray
Happy Listening!!! Listen with an open mind and heart!!!
Old 07-18-09, 05:44 PM   #103
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
  Kal Rubinson is offline
tonyvdb wrote: View Post
Too low for the preferences of some users but the levels it sets are accurate and correct. Personal taste as well as long-term adaptation to un-flat bass might make some want more.
Kal Rubinson
__________________________________
"Music in the Round"
Contributing Editor, Stereophile
Old 07-18-09, 06:44 PM   #104
Alias: DadsforHT
Loc: Spokane, WA
User: #20714
Since: May 2008
  ggallaway is offline
I do have an spl meter, should I use the built in test tones to set the level or try and use REW? what should be the steps or if you could point me to a thread that goes into this in some detail that would be great!
Old 07-19-09, 12:33 PM   #105
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
ggallaway wrote: View Post
If you are using Audyssey (assumed in this thread), there is no need for any external technology to set the level. Now, you can use REW to check/see what it is doing but, if you want more bass, just set it by ear.
Kal Rubinson
Old 07-19-09, 05:24 PM   #106
Alias: Bob
Lordoftherings's Avatar
Loc: Victoria, B.C. Canada
User: #33619
Since: Feb 2009
  Lordoftherings is offline
You can always use the Radio Shack SPL Meter for verification purpose, but be aware that it is not accurate. Still, it helps to put you in the ball park, and in particular for more than one sub.
After using the RS meter, just deduct 1.5 to 2db from the subwoofer level, for a fair value.
Here's a quick look at what you should deduct from some specific frequencies:
20hz -> deduct 7.5db
25hz -> deduct 5db
31.5hz -> deduct 3db *
40hz -> deduct 2.5db *
50hz -> deduct 1.5db *
63hz -> deduct 1.5db *
80hz -> deduct 1.5db *
100hz -> deduct 2db
Bob
* Myriad Iteration Disputable Involution *
Old 07-19-09, 10:47 PM   #107
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
Lordoftherings wrote: View Post
If it ain't accurate, what verification is it?
Kal Rubinson
Old 07-19-09, 10:48 PM   #108
Alias: Bob
User: #33619
Since: Feb 2009
Well, you have a better suggestion to balance my three subs?
Bob
Old 07-19-09, 10:51 PM   #109
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
Bob
Well, first off, I had no idea that this is the use you were referring to. The preceding posts were about bass levels in Audyssey.
Second, it is an OK way for gross level settings.
Kal Rubinson
Old 07-19-09, 11:00 PM   #110
Alias: Bob
User: #33619
Since: Feb 2009
LOL, Kal, I cannot afford better equipment, so I'll stick with gross.
And that's what I was talking about (bass levels from my Onkyo TX-SR876).
You have 3 subs in your setup Kal?
From your DTC-9.8, with Audyssey MultEQ Pro v3, anything else you're using to calibrate the bass level?
* By the way Kal, I super enjoyed "Music In The Round", every month. I learned some good stuff in there from your objective reviews and impressions.
Bob
Old 07-19-09, 11:39 PM   #111
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
Nope. I have only the jl f113 in one system but the other currently has a Paradigm Servo-15 and the new Sub-15.
REW, TEF, XTZ, TrueRTA.............................
Bob
Thanks. It is nice to hear that.
Kal Rubinson
Old 07-20-09, 12:06 AM   #112
Alias: Bob
User: #33619
Since: Feb 2009
REW, TEF, XTZ, TrueRTA..............................
Here you go Kal, you have all the tools at your disposition; that makes it an excellent way for "net" level settings.
Me, I just have to stick with my OK way for "gross" ones.
Just kidding.
Bob
Old 07-22-09, 04:29 PM   #113
Alias: Bob
User: #33619
Since: Feb 2009
Hello Mr. Rubinson (Kal).
Could you please tell me what these stand for?
1. REW
2. TEF (or is it ETF?)
3. XTZ
4. TrueRTA
5. ............
Thank you,
Bob
Old 07-22-09, 05:59 PM   #114
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
1. REW = Room EQ Wizard http://www.hometheatershack.com/roomeq/
2. TEF (or is it ETF?) TEF is a trademark of Goldline http://www.gold-line.com/tef/tef.htm
(I also have used ETF but it has been replaced by R+D and I have not gotten around to learning it. http://www.etfacoustic.com/)
3. XTZ = XTZ Room Analyzer http://www.xtz.se/produkt.php?allman...kt=41&eng=true
4. TrueRTA = TrueRTA http://www.trueaudio.com/
5. ............ = ?????
Thank you,
Bob
Howzat? (All from Google)
Kal Rubinson
Old 07-23-09, 09:45 AM   #115
Silver Supporter
Alias: Ray
User: #15210
Since: Jan 2008
Kal,
Thanks a lot for the links. I've used REW and TrueRTA. I remember seeing the fancy graphs you have in your review (BTW, I always look forward to your section in Stereophile - one of the best parts of the publication!!!), now I want XTZ also. It seems very reasonably priced.
Thanks!
Ray
Ray
Old 07-23-09, 10:17 PM   #116
Alias: Bob
User: #33619
Since: Feb 2009
Wow! This is excellent Kal. Thank you very much sir.
* Now; what "Howzat" stands for? Anything to do with the wife sneeking in, behind your affairs?
Bob
Old 07-24-09, 08:09 AM   #117
Alias: warpdrive
warpdrive's Avatar
User: #8762
Since: May 2007
  warpdrive is offline
I know the RS meter is off by a few dB in the lower registers but even with that considered, I used test tones from the receiver itself and I found that Odyssey was conservative with my bass level so I still bumped it up 3dB after the calibration and then I ran REW, and it was still flat. Unless you have dynamic EQ, I think running it hot by a couple of dB is preferable anyway due to loudness curves of your ear.
I like Audyssey in general, it does a way better job IME than YPAO or the others, but you shouldn't be scared to modify the resulting settings to your liking. I didn't like the fact that it set my speakers to large (which I changed), and also my Onkyo 875 didn't have user selectable target curves (my next receiver will have a flat setting....cough Denon cough)
Old 07-24-09, 10:07 AM   #118
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
warpdrive wrote: View Post
Again. There's no reason to think that the RW meter with pink noise at a random position is in any way more accurate than Audyssey for this but, again, if you prefer more bass, you are certainly entitled to have it your way.
Again, again. Audyssey does not select large/small; that is done by the AVR manufacturer.
Kal Rubinson
Old 07-24-09, 10:08 AM   #119
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
Phonetic spelling of "How is that?"
Kal Rubinson
Old 07-24-09, 10:40 AM   #120
Alias: warpdrive
warpdrive's Avatar
User: #8762
Since: May 2007
I did check it with REW later and I found that it was flatter in the 40-60 range after I bumped it up
Posted via Mobile Device
Old 07-24-09, 10:53 AM   #121
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
I am surprised since I have almost always found agreement between REW and Audyssey, if adequate care is taken with mic placement.
Kal Rubinson
Old 07-24-09, 11:01 AM   #122
Alias: warpdrive
warpdrive's Avatar
User: #8762
Since: May 2007
It seems to flatten the 60-100 range pretty well but I found the 40-60 pretty droopy, so bumping up the level by 3dB helped add back some impact I thought was missing.
Old 07-24-09, 05:39 PM   #123
Alias: Bob
User: #33619
Since: Feb 2009
Hi Warpdrive,
You're right, the RS meter is off, not only in the lower registers by as much as 20db at 10hz!
And still a big 7.5db off at 20hz! And even at 25hz, it's still off by 5db.
But it is also off in the high registers; at 4khz, 5khz, 6.3khz and 8khz, it is still off by 2db.
So, the Radio Shack SPL Meter is not totally "linear". But you knew that.
* By the way, Audyssey with an A, not an O (on your first paragraph only).
But the good thing about it, is that when you know the values from a chart, you can compensate to correct them. Below is the link on the Correction Values for the RS SPL Meter:
@ http://www.danmarx.org/audioinnovation/rsmeter.html
Here's another link, on the RS SPL meter, pubished by SVS (The Bass Authority) from their frequently asked questions (FAQ):
@ http://www.svsound.com/questions-faqs.cfm#meter
And their Compensation Chart (on the RS SPL Meter), only for the low frequencies (from 10hz to 125hz):
@ http://www.svsound.com/questions-faqs-rscomp.cfm
Now, I agree with you, that by adding a couple dbs or so, does in fact seems to restore properly and balance the bass with the rest of the system. It just sounds right to my ears too (for Movies).
But for Music only listening in 2-channel stereo, I deduct about one decibel or two. Again, it just seems to blend better with my two front mains. I guess it all depends of your room's acoustics, your subwoofer capability, your two main front speakers' qualities, your subwoofer's and main speaker's positions, and your own set of ears.
Audyssey is only a tool, but a good one to help you with some room acoustic issues.
But it certainly is not perfect, what is?
* By the way, your Onkyo TX-SR875 does have a Flat Audyssey (target curve) setting, but only when in THX Cinema mode.
It is automatically engaged when you select the THX Cinema audio mode.
** And it's very true what Kal is saying; Audyssey DOES NOT select your speakers as Large or Small, your Onkyo receiver DOES.
So many people are still confused by that, which is sad. There is a lack of clear information on this, and from Audyssey, and from the manufacturers. I don't blame one, I blame both.
And I agree with you, as I myself, at the end, always fine tune the results by ears, so they sound pleasant to my ears. I trust no one but God. And God is wherever you want him to be.
But there is one guy that I also trust somehow (after my ears and God, of course); and it is Kal Rubinson, because of it's vast experience with several tools for analysing and measuring, which he knows that are best at what they do.
Kal is probably one of the most knowledgeable person on various audio products and their interaction in our daily lifes. That's the benefit from years of audio experience, great dedication, "good spirit" man, and a passion for sound accuracy.
And we all know, that he's been writing about audio for as long as there are cars in our streets (well, almost).
Just my simple thoughts on the subject.
Bob
Last edited by Lordoftherings; 07-24-09 at 06:19 PM.. Reason: 2nd & 3rd link added
Old 07-24-09, 06:22 PM   #124
Alias: Bob
User: #33619
Since: Feb 2009
Thanks again Kal; without you, I don't know what I would do.
Bob
Old 07-24-09, 06:26 PM   #125
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Hi Warpdrive,
The Radio Shack meter isn’t really “off;” it tracks the C-weighting scale, like it's supposed to. The problem is that we are often using it for something it wasn’t really designed for – determining frequency response rather than sound pressure levels.
C-Weighting Curve
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Receivers | Processors | Amps »
