| Home Theater Receivers | Processors | Amps Audyssey MultEQ Discussion ThreadDiscuss Audyssey MultEQ Discussion Thread in the Home Theater | Audio and Video forum; Audyssey MultEQ Discussion Thread Lordoftherings wrote:
And we all know, that he's been writing about audio for as long as there are cars in ... |
Views: 6059 - Replies: 175
| | #126 | ||||
| Re: Audyssey MultEQ Discussion Thread There are cars in our streets?!?!? I gotta get out more. Kal Rubinson __________________________________ "Music in the Round" Contributing Editor, Stereophile | ||||
| | #127 | ||||
| Re: Audyssey MultEQ Discussion Thread I guess my point was: Audyssey does a great job but that doesn't mean you can't go in a tweak it a bit afterward for better results. In my case it did a great job of optimizing across three seats but I felt it sacrificed a bit too much in the primary seating location. I have a feeling it tried to optimize for flatness in the 60-100 Hz range, but the sound lost impact in the 40-60 range. I found that bumping the level up helped a bit. I know that my Onkyo uses a flat target curve in THX but then I still end up with THX processing. I should have the choice. I want a totally flat response curve for music listening. I want a receiver that has EQ profiles for different inputs, custom video settings for different inputs. That's why I'm looking to replace my Onkyo | ||||
| | #128 | |||||
| Re: Audyssey MultEQ Discussion Thread Quote:
brucek | |||||
| | #129 | |||||
| Quote:
Denons offer this option on their receivers but my Onkyo does not for some reason Posted via Mobile Device | |||||
| | #130 | ||||||
![]() Kal Rubinson __________________________________ "Music in the Round" Contributing Editor, Stereophile | ||||||
| | #131 | |||||
In the home, if you play a low, mid, and high frequency signal at the same level, you'll perceive them quite differently. brucek | |||||
| | #132 | |||||
| Quote:
| | #133 | ||||||
| | #134 | |||||
So, my point is: If you have the stereo and mch systems in the same room, why should you not correct the acoustics for the stereo system when you acknowledge the use of it for MCH? Kal Rubinson __________________________________ "Music in the Round" Contributing Editor, Stereophile | |||||
| | #135 | |||||
| | #136 | |||||
| | #137 | ||||
| Re: Audyssey MultEQ Discussion Thread I have no qualms with using EQ unlike some "purists". But I'd rather leave it flat than use the tone controls in most of the standard stereo component implementations of it. The only one I"ve liked was an old NAD amp which seemed to affect a narrower range of frequencies (the actual extremes). If there somebody offered a reasonably priced but decent 2 channel int-amp that had Audyssey, I'd be lining up with my credit card. | ||||
| | #138 | ||||
| Re: Audyssey MultEQ Discussion Thread Ok Wayne, I used the word "off", because the poster used it, so I wanted to make life very simple, by also using his own word. If it would be my own choice of word, I would say that the Radio Shack Sound Pressure Level Meter is not totally "accurate" in the lower frequencies of let say, from about 30hz or so and below, and also in the higher frequencies of let say, from about 10khz or so and above. But I totally agree with you; using the RS SPL Meter is not the tool to check the frequency response of your "ROOM", from the sound emanating from your speakers' drivers, and bouncing all around from the walls, floor & ceiling. It's just a ball game to put you in the end field. ![]() Best regards, Bob * Myriad Iteration Disputable Involution * Last edited by Lordoftherings; 07-25-09 at 07:45 PM.. Reason: typo | ||||
| | #139 | ||||
| Re: Audyssey MultEQ Discussion Thread LOL. Indeed, Kal, the computer age is blinding us from the real ouside life of our neighborhoods. ![]() * Myriad Iteration Disputable Involution * | ||||
| | #140 | |||||
* Audyssey Sound EQualizer @ http://www.audyssey.com/soundequalizer/index.html * Audyssey Sub EQ @ http://www.audyssey.com/hometheater/subeq.html ________________________________ 1. Audyssey Sound Equalizer - Review ![]() @ http://www.avrev.com/home-theater-ac...equalizer.html 2. Audyssey MultEQ Pro Sound Equalizer Review ![]() @ http://www.audioholics.com/reviews/a...ound-equalizer *** Get that credit card easily accessible. ![]() Bob * Myriad Iteration Disputable Involution * Last edited by Lordoftherings; 07-25-09 at 08:44 PM.. Reason: signed | |||||
| | #141 | |||||
Regards, Wayne | |||||
| | #142 | |||||
Here's hoping I win that giveaway SVS bass EQ unit ![]() | |||||
| | #143 | |||||||||
![]() It’s pretty easy to tell if you have a house curve slope or not (and most people do, even if they claim they have flat response). Just play broadband pink noise through your system at an adequate level, and switch your SPL meter between A- and C-weighting. As you probably know, in the A-weighting setting, the meter ignores (i.e. rolls out) response below 1000 Hz, while C-weighting registers down to 40 Hz or so. If the SPL reading increases when you switch the meter to the C setting, then you have louder levels below 1000 Hz than you do above. IOW, you don't have flat response. You have a house curve. Regards, Wayne | |||||||||
| | #144 | |||||
I wish you good luck on winning that SVS SubEQ1, you seem like you deserve it. ![]() * Myriad Iteration Disputable Involution * | |||||
| | #145 | ||||
| Re: Audyssey MultEQ Discussion Thread Not if you want to hear what the conductor (and the rest of the recording team) put on the recording. The reproduction system (including the room) should be completely neutral unless, of course, you prefer something different. Kal Rubinson __________________________________ "Music in the Round" Contributing Editor, Stereophile | ||||
| | #146 | ||||
| Re: Audyssey MultEQ Discussion Thread I just got my Denon receiver and did an Audyssey calibration. I used the exact same tripod and seating positions, and the difference from my previous Onkyo Audyssey XT calibration is quite substantial. My sub trim setting is +9dB compared to my other channels, whereas on my Onkyo there was only a 4dB difference, and quick check using the ratshack meter seems to confirm that the overall sub level is higher. Now my sub is quite audible and I don't feel the need to bump it up manually at all, in fact the bass is nearly overwhelming. Weird that it seems that the results are the subjectively different. I should break out the REW again. I'm also enjoying the fact that the Denons have a flat setting which sounds better to my ears than the regular target curve. With the regular target curve, my Paradigms sound kind of dull. Dynamic EQ and Volume is also a killer feature for regular TV watching. Every receiver should offer this sort of feature. It made buying the Denon worth every cent. Anybody want a gently used Onkyo 875? (j/k, I'm going to keep it) I'm an equal opportunity fanboy. I love and currently own stuff from B&W, Paradigm, Dynaudio, Sony, SVS, Denon, Velodyne, Mirage, AKG, Headroom (all subject to change at any moment) Last edited by warpdrive; 08-08-09 at 12:45 PM.. | ||||
| | #147 | ||||||
I do like the Dynamic EQ, especially since I usually listen at low volumes and appreciate the bass boost. I'm not too fussed about the Dynamic Volume, although it does stop all the level jumping when switching channels on the satellite. I found that the default setting for Dynamic Volume was Midnight setting on the Denons, so after changing it to Daytime, the compression wasn't as great, so it's better than I originally felt. Quote:
The Audyssey Flat setting is better for music since it has no rolloff. brucek | ||||||
| | #148 | ||||
| Re: Audyssey MultEQ Discussion Thread The difference between the Audyssey runs is probably from subtle changes in measurement position, which can hugely affect the resulting correction. You could probably get the same change with another run with your Onkyo. Having said that, the only time I feel Audyssey is lacking in bass is if one or more of the measurements are close to a boundary. Keep them at ear level and away from boundaries, and the result is more predictable and usually very satisfactory. | ||||
| | #149 | |||||
It's not a scientific conclusion but I really do feel the Denon's calibration puts out more bass. I did try to replicate what I did for the Onkyo, same tripod, same height, middle of the seat of my three seating positions. Even if there is a replication error, the difference in the calibrations is quite noticeable. Now the begs the question, if the difference in calibration from run to run can be so different, then how do we know that we did a good run? Let's say I do it one day, and then next day I do it again and get a different result, then was it correct the first day or second day? I'm an equal opportunity fanboy. I love and currently own stuff from B&W, Paradigm, Dynaudio, Sony, SVS, Denon, Velodyne, Mirage, AKG, Headroom (all subject to change at any moment) | |||||
| | #150 | ||||||
* Two different manufacturers, two different implementations. * Just curious, is it the Denon AVR-3808CI? Quote:
For me, Denon and Onkyo receivers have a different sound, with the Denon seeming fuller in the bass and midrange, and the highs sounding more roll-off. Onkyo, perhaps less roll-off in the highs with less emphasis in the lows and mids. Both then, still missing that last minute detail and spaciousness (without Audyssey). "How do we know that we did a good run, from one day to the next"? Great question. Again, make use of the REW. Try to have your set of ears in top shape each and every day, and make good use of them by listening attentively, but not extensively. It's all a balancing act, and at the end, your ears plus your common good sense (getting acquainted with a new sound), will dictate you what sounds best from these listening sessions, and in the overall post time period. * Nothing's perfect in life, only God is. ![]() Cheers, Bob * Myriad Iteration Disputable Involution * Last edited by Lordoftherings; 08-09-09 at 10:08 PM.. Reason: typo | ||||||
