Affordable Multi ch power amp?
3K views 14 replies 6 participants last post by  kingnoob
#1 · (Edited)
I was wondering if anyone had any suggestions, I am open to $200-$1000 suggestions.
Plan on buying it after I get another job, right now im looking.
I might try running 11ch with my onkyo 818. need atleast a 5ch amp.
I liked the XPA-7 but it was $500 above what Im willing to spend. Perhaps I could look into a used one.
#3 ·
As far as multi channel is concerned the Emotiva is about the only one that falls into the price range your looking at.
#5 ·
125watts is plenty, either the Emotiva or the Outlaw are great options but way at the top of your budget.
#7 ·
speakers is definitely the biggest improvement but if you dont have enough power to play the speakers without distortion its no advantage. your 818 has a beefy amp section but it wont do more than about 80watts all channels driven.
#15 · (Edited)
