| Home Theater Receivers | Processors | Amps recommendation for subsonic filterDiscuss recommendation for subsonic filter in the Home Theater | Audio and Video forum; recommendation for subsonic filter i need something, processor or eq, that has a subsonic filter. i need to set a subsonic filter at about ... |
Views: 939 - Replies: 17
| recommendation for subsonic filter i need something, processor or eq, that has a subsonic filter. i need to set a subsonic filter at about 20hz so a subsonic filter that is not able to reach down in the low frequencies would be useless in my case. i am only needing the subsonic filter function and nothing else. what do most ppl use? and i'd really prefer something that is the cheapest but wont make me regret buying it. ps. if this is the wrong section to post this question, plz move it to the right section mods. thank you. | ||||
| | #2 | ||||
| Re: recommendation for subsonic filter Moved to Home Theater Components. I don't know of any unit that is just an add on subsonic filter. There is the Reckhorn B1 from Creative Sound Solutions that has a variable subsonic filter so you can tailor it to your needs. It also does bass boost up to 12 dB, has adjustable bass boost frequency and a adjustable high cut filter. $110 shipped. http://www.reckhorn.com/index.php?ln=en&prod=b1 | ||||
| | #3 | ||||
| Re: recommendation for subsonic filter How is that compared to ED's eQ.2? | ||||
| | #4 | ||||
| Re: recommendation for subsonic filter I haven't heard much about the eQ.2. I have heard from a member the B1 was excellent. | ||||
| | #5 | ||||
| Re: recommendation for subsonic filter but when i try to add the product to the cart, it sends me to another site in a different language. | ||||
| | #6 | ||||
| Re: recommendation for subsonic filter Sorry about that, the link I provided was the info on the unit from the manufacurer. It can be bought from Creative Sound Solutions. http://www.creativesound.ca/ Click on the "Products" tab at the top left side of the page and scroll down to "B1" | ||||
| | #7 | ||||
| Re: recommendation for subsonic filter i trust your advice because someone recommended me to join here and talk to you, but i'd really like to hear about the other product as well, the eQ.2. over at cixi, they praise the product but they could just be bias. if i ordered the reckhorn from canada, is there any customs fees? or is it just 100 dollars flat? | ||||
| | #8 | ||||
| Re: recommendation for subsonic filter Definitely check out your options. Not sure of the customs fees. Contact Bob At Creative Sound and he'll tell you what you need to know. http://www.creativesound.ca/contact.html | ||||
| | #9 | ||||
| Re: recommendation for subsonic filter I found some tests that were done on the E.D. eQ.2. Post #980 and #981 are the graphs and post #982 is a commentary. You can judge for yourself. http://www.avsforum.com/avs-vb/showt...3#post13935023 | ||||
| | #10 | ||||
| Re: recommendation for subsonic filter yea, i came across that too but i dont know what to think about it tho. lol. still indecisive. | ||||
| | #11 | ||||
| Re: recommendation for subsonic filter well just getting back about this, and i bought the eQ.2 from a local person for 20 discount. the product worked just exactly for what i need. however, the auto turn-on feature is weak. its slow response makes listening to movies not worth getting it. have to turn it on when i turn on my sub amp so i dont really care to use the auto-on feature. | ||||
| | #12 | ||||
| Re: recommendation for subsonic filter I've read some people have issues with this unit with Pro amps. Just curious what amp you're using for your sub? | ||||
| | #13 | ||||
| Re: recommendation for subsonic filter Behringer ep1500. there is no problem with it. like i said before, its just the auto-on feature is badly made because it turns on slower than when the bass actually hits and when there is no bass, for example in a quiet scene, the sub makes a note before auto turning off. i think they should have fixed that before selling it or scrap the idea. | ||||
| | #14 | |||||
| Re: recommendation for subsonic filter Quote:
I wouldn't have anything else controlling my bass but the B-1. Mike | |||||
| | #15 | ||||
| Re: recommendation for subsonic filter If you are looking for the highest quality, most functional option and are willing to spend more money to get it, then there is no superior option compared to the DCX2496. Not only will the DCX2496 work as a highpass filter, it will also act as a fully customizable equalizer with as many equalization bands as you could ever need. Also, the DCX will allow proper integration of your subwoofer and mains which is impossible to do with a receiver. Lastly, since you are using a pro amp there is one other plus side, the DCX has variable gain which would allow you to adjust the gain to make up for the difference between pro/home equipment. Of course, the DCX2496 is substantially more expensive than the other units suggested, but it has far more uses. Andrew | ||||
| | #16 | ||||
| Re: recommendation for subsonic filter well if i knew i could get the b1 for 85 dollars then i wouldnt have gotten this eQ.2 for 80. but i wouldnt have known what type of product it was if i didnt get it. now, i know. lol. i mean it does serve the purpose i need it for so im okay. if it ever messes up, i know what i would get next time. thanks for the comments. | ||||
| | #17 | |||||
| | #18 | ||||
| Re: recommendation for subsonic filter Pretty much any type of crossover (Butterworth, Linkwitz-Riley, etc..) and order can be used. To get an idea of what the DCX2496 is capable of you can download its easy to use computer interface for free from Berhinger's website. http://www.behringer.com/DCX2496/index.cfm Andrew | ||||
| Bookmarks |
| Tags |
| filter, recommendation, subsonic |
| Thread Tools | |
