Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Receivers | Processors | Amps
affordable preamp / preprocessor
Discuss affordable preamp / preprocessor in the Home Theater | Audio and Video forum; affordable preamp / preprocessor Are there any affordable preamps out there? I am looking for one with the same features of, for example an ...
Views: 578 - Replies: 6
Old 03-22-09, 06:06 PM   #1
New Member
Alias: Brad
Loc: Winnipeg, Mb, Canada
User: #17428
Since: Feb 2008
  homie_g is offline
I am looking for one with the same features of, for example an Onkyo 606 or 706. I would assume that a preamp would cost less than a normal AVR with the same features since it has no build in amp. Or is it just better to get a normal AVR with preouts and not use the speaker outs if your on a budget?
Thanks.
Old 03-22-09, 08:46 PM   #2
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
  Kal Rubinson is offline
Re: affordable preamp / preprocessor
For several reasons, pre/pros are more expensive than comparably-featured AVRs. You will not find an unused pre/pro for less than the cost of an Onkyo 606.
Kal
Old 03-22-09, 09:15 PM   #3
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is online now
A pre/pro that supports all the newest audio formats will cost at minimum $1000 Your best off just getting a Onkyo 706 for $500
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 03-22-09, 11:07 PM   #4
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
The Emotiva UMC-1 AUDIO-VIDEO PROCESSOR will be $699. It should be released very soon.
Old 03-23-09, 02:55 AM   #5
Alias: Pinhead
User: #30763
Since: Dec 2008
  Pinhead-227 is offline
Why are they more expensive than full-out amplified receivers?
Old 03-23-09, 10:04 AM   #6
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
Pinhead-227 wrote: View Post
Fundamentally, the volume is too small to compensate for the additional costs of development, inventory, distribution and support.
Kal
Old 04-20-09, 12:54 PM   #7
Alias: erasma
User: #36523
Since: Apr 2009
  erasma is offline
100% it's the volume & they know if you buy power on it's own you looking for something different & will pay more, marketing is wonderful don't you think?
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Receivers | Processors | Amps »
affordable, preamp, preprocessor
