| Home Theater Receivers | Processors | Amps Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network ReceiverDiscuss Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver in the Home Theater | Audio and Video forum; Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver Onkyo new Flagship
TX-NR5007
As Onkyo’s flagship model for the network generation, the TX-NR5007 offers a mouthwatering feature set designed ... |
Views: 2821 - Replies: 32
| Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver Onkyo new Flagship TX-NR5007 As Onkyo’s flagship model for the network generation, the TX-NR5007 offers a mouthwatering feature set designed to satisfy even the most demanding home theatre purist. The expanded 9.2-channel configuration allows you to enjoy multi-zone playback as well as the latest surround formats by Dolby, DTS, and Audyssey. Advanced networking capability, meanwhile, enables you to incorporate PC-based audio and internet radio into your home theatre set-up. Video signals fed through this receiver get the luxury treatment, thanks to HQV Reon-VX processing, ISF calibration, and 1080p upscaling of all video sources via HDMI™ 1.3a. In the engine room, the TX-NR5007 boasts an impressive array of audiophile-grade components, including large, customized transistors to drive high currents and 22,000 μF capacitors to support a huge and stable power supply. Add to that high-quality 32-bit Burr-Brown DACs; ultra-low-jitter circuitry; and independent power supplies for amp, video, and audio circuitry, and you have a networking powerhouse equipped to deliver an immaculate A/V performance every time. ADVANCED FEATURES THX® Ultra2 Plus™ Certified DTS-HD Master Audio™, DTS-HD High Resolution Audio™, Dolby® TrueHD, and Dolby® Digital Plus Decoding HDMI™ Version 1.3a to Support Deep Color™, x.v.Color™, LipSync, Dolby TrueHD, DTS-HD Master Audio, DVD-Audio, Super Audio CD, Multichannel PCM, and CEC HDMI Video Upscaling to 1080p with HQV Reon-VX DSD Direct for Super Audio CD Audio and 1080p Video Processing via HDMI (1 Front/7 Rear Inputs and 2 Outputs [Main/Sub]) Burr-Brown 192 kHz/32-Bit DACs (PCM1795 x 6) for All Channels Ultra-Low-Jitter PLL (Phase Locked Loop) Circuitry to Improve Audio Quality Three TI (Aureus™) 32-Bit DSP Chips (DA830 x 1, DA788 x 2) for Advanced Processing VLSC™ (Vector Linear Shaping Circuitry) for All Channels ISF (Imaging Science Foundation) Video Calibration Audyssey DSX™ and Dolby® Pro Logic® IIz for New Surround Channels Audyssey MultEQ™ XT to Correct Room Acoustic Problems and to Calibrate Speakers Audyssey Dynamic Volume™ to Maintain Optimal Listening Level and Dynamic Range Audyssey Dynamic EQ™ for Loudness Correction Dolby® Volume for Reference-Quality Listening Experience at Any Volume Network Capability for Streaming Audio Files (MP3, WMA, WMA Lossless, FLAC, WAV, Ogg Vorbis, AAC, LPCM) Internet Radio Connectivity (Last.fm* and vTuner) Certified with Windows 7 and DLNA Version 1.5 Bi-Amping Capability Zone 2 and Zone 3 for Playback of Separate Sources in Other Rooms Zone 2 Monitor Outputs (Component and Composite) and Zone 2/3 Subwoofer Pre Outs D-sub (15 pin) Input for PC or Analog RGB Universal Port for Single-Cable Connection of Optional Onkyo Dock for the iPod or DAB+ Radio Tuner 4 DSP Modes for Gaming: Rock, Sports, Action, and RPG (Role Playing Game) 2 Independent Subwoofer Pre Outs AUDIO & VIDEO FEATURES 9.2-Channel Balanced Line-Level XLR Pre Outs (with Front Bi-Amping Capability) 2-Channel Balanced XLR Audio Inputs Dual IR Inputs with Common Output Linear Optimum Gain Volume Circuitry Neural-THX® Surround Decoder Music Optimizer™ for Compressed Digital Music Files Theater-Dimensional Virtual Surround Function RIHD (Remote Interactive over HDMI) for System Control Direct Mode and Pure Audio Mode Tone Control (Bass/Treble) for All Channels Front-Side Auxiliary Inputs (for Camcorders, Game Consoles, etc.) 2 USB Ports (Front/Rear) for MP3 Audio Devices (Audio Only) Component Video Upscaling (Up to 1080i) Component Video Switching (3 Inputs and 1 Output) 5 Composite Video Inputs and 2 Outputs Color-Coded, 9 Multichannel Pre Outs 7 Digital Inputs (4 Optical and 3 Coaxial) Independent Crossover Adjustment for F/C/S/SB/FH/FW (40/50/60/70/80/90/100/120/150/200 Hz) A/V Sync Control Function (Up to 250 ms in 5 ms Steps) 40 FM/AM Random Presets with RDS (PS/RT/PTY/TP) OTHER FEATURES Gold-Plated A/V Inputs and Outputs High-Rigidity Flat Chassis (1.6 mm Thick) 4 S-Video Inputs and 1 Output 5 A/V Inputs and 1 Output Monitor Outputs (Component Video, Composite Video, and S-Video) 3 Audio Inputs and 1 Output Phono Input Gold-Plated, Machined Solid Brass, 19 mm-Pitch Audio Inputs (CD and Phono) Color-Coded, 7.1-Multichannel Inputs 12V Triggers (A, B, and C) with Adjustable Delay Onscreen Display (OSD) IntelliVolume Aluminum Front Panel and Volume Knob Firmware Updates via Ethernet and USB Bi-Directional Ethernet Port and RS232 Port Compatible with RI (Remote Interactive) Dock for the iPod Bi-Directional, Preprogrammed, and Customizable RI Remote Control with Backlight, Onscreen Setup, Mode-Key LEDs, and Macro Presets for Four Activities | ||||
| | #2 | ||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver Looks nice. I've had good luck with Onkyo products with my customers. They like the features and sound, and for most of them, the gear is hidden (or at least behind them), so they don't mind the "million button" look on the console. | ||||
| | #3 | ||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver I am amazed how many similaraties in features there are between the integra and upper level onkyo stuff, yet the integra unit do have a much cleaner look, and not a million buttons like you said. | ||||
| | #4 | |||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver Quote:
Integra 32 Buttons plus 1 knob ![]() Onkyo 13 Buttons plus 1 Knob Now when you flip the panel open you have 26 additional buttons ![]() ![]() ![]() Last edited by wes; 08-20-09 at 01:13 PM.. | |||||
| | #7 | ||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver Onkyo has been doing the hidden buttons behind the front cover since the 805, 806 and up nothing new there. Its just there lower models that have them all out front. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #8 | ||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver I have not seen any power ratings thus far... other than 220 or 240 watts at 6 ohms. I assume it is about 140 watts per channel into 8 ohms. | ||||
| | #9 | ||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver Hello, I have been overwhelmingly pleased with my TX-SR875 which is used as a prepro. I do like the added features of the 5007 and am contemplating upgrading. The ability to upgrade firmware over ethernet is huge. Especially considering earlier versions of the 875/905/9.8 all needed revisions to the Reon chip and Audyssey to enable the Audyssey Pro features. Since Onkyo launched the 05 Series, I really think they have turned a corner. I initially purchased a TX-SR-805, but wanted the Reon processing and got the 875. However, for the price, the TX-SR805 is one of the greatest value AVR's ever. Aside from subpar video processing, the 805 was ground breakng in its price range. Shame that the 806 no longer shared the same amp section as the 876/906. I was shocked that the 806 was still THX Ultra2 rated. Makes sense that the 807 is THX Select. I also prefer the industrial design of the Onkyo's over the Integra. I like the hidden door to conceal buttons much better. I did like that the initial 05 Series were manufactured in Japan as opposed to Malaysia. Shame that all Onkyo/ Integra Stateside are now manufactured in Malaysia. While I like Denon, I think their gear is way overpriced. To get an AVR comparable to the 5007, you would have to spend multiples of the price of the 5007. Cheers, JJ | ||||
| | #11 | ||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver Nope, their are all done in Malaysia its too bad but thats the way the mass marked electronics is going. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #13 | ||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver Most of Denon's middle and all of Denon's upper range are manufactured in Japan. Surprisingly, Marantz's AVR's are made in China. Sony's AVR's are made in Malaysia. And only Yamaha's flagship RX-Z11 is made in Japan with the rest in Malaysia I believe. It was honestly impressive when the 05 Series came out that the 805 onwards were built in Japan. In fact, there was a feature in UK's Home Cinema Choice where they toured Onkyo's Japanese manufacturing facility. Given the cost of Labor in Japan, I can certainly understand why these companies have moved manufacturing away from Japan. I was quite impressed that Pioneer's early BDP's, including most BDP-51 and BDP-05's were made in Japan. Cheers, JJ | ||||
| | #14 | ||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver The 9.2 - is it just 2 subwoofer outputs? What I am getting it is - will this model be able to EQ 2 subs seperately? or will it still see only 2 subs as 1 sub? | ||||
| | #15 | ||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver Yes, the .2 is two subs. Probably separate from a volume perspective, might be able to change crossover and EQ settings. On that I'm not sure, though. | ||||
| | #16 | ||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver Onkyo really do have an impressive line up for there new AV amps, with nearly every feature you could possibly get, and price wise excellent VFM... One of my favourite features now on AV amps is the Dolby Volume which offers excellent audio quality at low levels, somehow with this new processing it retains dynamics and tonal balance which can be lost when usually listening at low volume in late night modes on previous amps, you also get the excellent EQ Audyssey on Onkyo's, I bet these will sell by the bucket load...must try and get to listen to the new range for sure.... | ||||
| | #17 | ||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver What is it with Onkyo and their 12v Triggers? It only works in Zone 2/3... what good is that? I noticed this new model doesn't even have a 120v AC outlet on the back. This pretty much eliminates auto turn on via remote control. What am I missing? | ||||
| | #18 | ||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver Yep, it was a pain having to keep turning zone 2 on, on my 905 to power up my 1575 and then the reverse to switch off ![]() | ||||
| | #19 | ||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver That would be especially annoying. What's the real point of that? Outside of a dog, a book is man's best friend. Inside of a dog it's too dark to read." - Groucho Marx | ||||
| | #20 | ||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver I have no idea... I called Onkyo and asked, but they had no clue either. ![]() Such a nice receiver, but if I cannot control all my other products power with a one button push on the remote... I ain't having it my system. At least the 876 and 906 did have an AC switched outlet on the back that could accommodate an AC/DC adapter, which is what I did with my 876 unit. | ||||
| | #21 | ||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver It does seem strange that they have left off such an important feature off of there top of the range reciever, especially as they will be releasing there new 9 channel power amp shortly ![]() | ||||
| | #22 | ||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver --> Onkyo TX-NR5007 9.2-Channel A/V Surround Receiver (Preview): * @ http://www.areadvd.de/hardware/2009/...txnr5007.shtml Mmm... very sweet indeed. ![]() ** Caps are 22,000uF each (x2). ** Weight is 55.1 lbs. ** Maximum power consumption is 11.6 Amperes. ** List price is $2,699 USA. (Street should be around $1,999 USA.) ** I think I want one... * Myriad Iteration Disputable Involution * Last edited by Lordoftherings; 10-31-09 at 12:01 AM.. Reason: additional specs | ||||
| | #23 | ||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver I just picked up a brand new NR906 for $1000 shipped... ![]() | ||||
| | #25 | ||||
| Re: Onkyo TX-NR5007 9.2-Channel A/V Surround Home Network Receiver Congrats Sonnie Onkyo really do make some great kit! | ||||
