Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater | Audio | Video > Home Theater Receivers | Processors | Amps
  Discuss Yamaha Receiver 500 watt in the Home Theater | Audio | Video forum; Yamaha Receiver 500 watt Hi. I saw this home theater receiver at Best Buy not long ago for $400 some and was wondering what ...
Views: 679 - Replies: 11
Old 09-24-09, 01:09 AM   #1
Alias: moviefanatic
User: #39214
Since: Jul 2009
  Moviefanatic is offline
Hi. I saw this home theater receiver at Best Buy not long ago for $400 some and was wondering what you guys could make of this model: M# YHT-391BL.
My friend told me it looked like the best one there that we looked at. I asked a sales associate why there was no mention on the back of the subwoofer of how many ohms there were. He said that it had a built in amplifier and said that you didn't need ohms if it's built in like that. It didn't make much sense to me so I thought I'd ask you guys.
My friend says that every subwoofer comes with a hole, that that's where the bass comes from. I can't recall there being a hold in it. He said it was likely on the bottom.
What gets me is that it's only 500 watts. Wouldn't that be bad sound quality?
That's all I can recall for now. Thanks in advance.
P.S. Appartently it's 600 watts, not 500. Maybe a moderator can change that mistake...?
P.P.S. The sales guy said that most subwoofers are 6-8 ohms, said that this one is probably 6. But I've seen the ohms listed at 1.5 before, which sounds like it'd sound dull.
Old 09-24-09, 07:03 AM   #2
Shack Moderator
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
Re: Yamaha Receiver 500 watt
Wow, where to begin. If it's wearing a blue shirt in BB, don't believe anything coming out of its mouth.
A receiver must indeed provide a minimum impedance (Ohms) rating to allow you to determine what speakers are appropriate. Most consumer grade speakers are 8 Ohms, but there is the occasional pair that are 4 or 6 Ohms. So that rating is important. But that is just an amp-protection thing, not a power or sound quality thing.
500W is not bad. In a 5.1 setup, that's 100W per channel to the mains and primary surrounds. A bit less for 7.1. I had a Parasound 85W amp that blew away a Kenwood 125W amp in both power and sound quality -- so it's not just wattage that matters. Yamaha has a pretty good reputation for making quality amps and receivers.
I just checked the part number you listed: it's for a full home theater in a box. Complete with speakers and subwoofer. It looks like it is a passive subwoofer, meaning the receiver is also driving the subwoofer. That's where the 500W came in. 500W mains + surround + 100W for the subwoofer. That's probably why there is no subwoofer out on the panel, but I couldn't find a picture with more detail. It may also be why the speaker impedance limits aren't marked clearly (they assume you will only be using their speakers)
What speakers do you have? If you are buying this for the whole kit and want a no-hassle install, then it's probably an okay deal. If you already have a subwoofer and main speakers, there are a lot of great receivers out there at the $400 price point that are better bargains (including some from Yamaha).
I hope this helps some.
Old 09-24-09, 08:39 AM   #3
Shack Moderator
Alias: Jack
Jungle Jack's Avatar
Loc: Sarasota, Florida
User: #40011
Since: Jul 2009
  Jungle Jack is online now
Hello,
I agree with everything has written. Also, tell your your friend not all subwoofers have "holes" from which they derive their sound. Those subwoofers are ported subwoofers and the aforementioned "hole" is the port. There are also sealed subwoofers which have no holes whatsoever. Furthermore, their are several other designs as well. Infinite Baffle, Transmission Line, etc.
However, ported and sealed are the most common. With ported being most abundant in budget subwoofers as it easily allows for higher spl's.
I would highly recommend purchasing separates as opposed to HTIB's. You will get much higher quality sound. It will cost more, but you will truly get much more enjoyment out of it.
What is the most money you can come up with at this moment? If your budget is tight, I would recommend starting with a quality receiver and a pair of speakers to start. And going from there.
Cheers,
JJ
Old 09-24-09, 09:22 AM   #4
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Have a read of this post as it will answer most of your questions that may not have been in this thread.
Home theater:
Onkyo TXSR805, Samson Servo 300 amp
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Panasonic BD60, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, Samsung BDP1400, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 09-24-09, 09:49 PM   #5
Alias: moviefanatic
User: #39214
Since: Jul 2009
Jungle Jack wrote: View Post
$300 is all I have. I do have a subwoofer that's 8 ohms. It came with a used home theater I got from a pawn shop that worked really good for a few months.
I have already read that thread you posted, tonyvdb. I haven't enough to buy anything that I want at this point. Woe is me
Old 09-24-09, 09:57 PM   #6
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Do you have any older speakers that are still somewhat good? $300 is enough to get you into an fairly decent low end receiver that is better than what you had. This Onkyo 507 would be a good start.
Home theater:
Two Channel system:
My Webpage
Old 09-24-09, 10:05 PM   #7
Alias: moviefanatic
User: #39214
Since: Jul 2009
No, the ones I had blew out due to that Wal-mart HTIB. Only a subwoofer, unfortunately. Maybe I could look in a few pawn shops to see if I can find some speakers.
Old 09-25-09, 07:02 AM   #8
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Understand, it was not the cheap HTIB that caused the problem with your speakers. It was not understanding the limits of the technology and misuse. That misunderstanding is partly due to the lack of education on the part of retailers who sell the products, but you have to accept some responsibility for using it in a manner which was simply beyond its design. If you don't educate yourself and understand this, you may repeat the experience again, only with more powerful amps and better speakers.
...the soulshine, it's better than sunshine. It's better than moonshine. It's sure better than rain.
Old 09-25-09, 10:11 PM   #9
Alias: moviefanatic
User: #39214
Since: Jul 2009
I completely get that it was my fault.
Old 09-25-09, 10:40 PM   #10
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
The thing with most if not all low end consumer electronics is that even though the volume goes to 10 does not mean that you can go that loud. Leonard is correct when he said "lack of education on the part of retailers who sell the equipment" Its even the pressure of meeting their sales quota, they miss lead customers into thinking the a HTIB system is a great buy without finding out the users requirements including room size. Speakers the size of pop cans are Not going to fill a room that is even 8'x8'. I hear so many times on this forum members with HTIB systems who are simply trying to over drive there speakers beyond what they are designed to do causing distortion and failure like in your case moviefanatic.
It simply is a case of you get what you pay for.
Home theater:
Two Channel system:
My Webpage
« Home Theater Shack > Home Theater | Audio | Video > Home Theater Receivers | Processors | Amps »
receiver, watt, yamaha
Bookmark and Share
Dish Network
