Yamaha HTR-5590
2K views 3 replies 2 participants last post by  Jungle Jack
#1 ·
I've had this receiver for quite some time and I'm still pleased with it, however I recently bought a new Hitachi plasma TV and now for some reason can't get the OSD to work on the new TV. I'm sure its a cabling problem, but I've tried everything I know. Have HDMI cables, optical and componet hookups. Does anyone know where the problem is?
#2 ·
Hello,
Your Yamaha does not have HDMI switching so take HDMI out of the equation. Your OSD should work via Composite via the Monitor Out on your Yamaha. Or if Your Yamaha has S-Video or Component Monitor Out facilities. More than likely, it is probably Composite.
As long as your Hitachi has Composite, Component or S-Video Inputs, you should be good to go for using your OSD.
Cheers,
JJ
#4 ·
Hello,
Figured that was what it was. So glad it worked out for you. Welcome to HomeTheaterShack.
Cheers,
JJ
