onkyo reciever keeps shutting off - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 11 Old 10-20-10, 02:33 PM Thread Starter
william
i have a onkyo ht-r667 reciever that keeps shutting off as soon as you turn it on my waranty is gone im pretty sure its in what onkyo calls protect mode is there anything i can do to fix tried a couple of resets still same problem called onkyo they said it needed to be serviced called the only only service center near me and was absolutly discusted.dont get me wrong i dont have a problem with people making money but when they told me on the phone that theres a flat rate of 150.00 and that dont even cover parts and labor that pretty much covers them telling you whats wrong with it thats just highway robbery. any ideas suggestions would hate just to trash it does anyone know of sombody that could fix it for a reasonable price......please help
123loomis is offline
post #2 of 11 Old 10-20-10, 02:36 PM
HTS Moderator Emeritus
Anthony's Avatar
Anthony
Re: onkyo reciever keeps shutting off
Unplug all your speakers from the back. If it still goes into protect mode when you try to turn it on, something is wrong inside and you need to send it in.
If the unit fires up fine with the speakers unplugged, then you have a short somewhere in your speaker wiring and the amp is (rightfully) protecting itself.
Good luck.
Anthony is offline
post #3 of 11 Old 10-21-10, 02:42 PM
ryan
If it works with the speakers removed, take a Volt Ohm meter and test resistance on each speaker wire pair to narrow down the culprit.
rosco968 is offline
post #4 of 11 Old 10-21-10, 04:18 PM
bambino's Avatar
bambino
Anthony wrote: View Post
Good luck.
bambino is offline
post #5 of 11 Old 10-21-10, 04:41 PM
salvasol's Avatar
David
123loomis wrote: View Post
i have a onkyo ht-r667 reciever that keeps shutting off as soon as you turn it on ...
When did this happen??? Did you make any changes??? Was it working before???
I agree with Anthony, if the AVR works with the speakers disconnected, check all wires to see that they're not touching; maybe a staple or nail cut them and there making a short circuit
salvasol is offline
post #6 of 11 Old 10-21-10, 10:22 PM Thread Starter
william
everthing is unhooked still same problem
post #7 of 11 Old 10-22-10, 01:05 AM
Banned!
Then it must be the AVR which has developed a fault and that will need to go in for repair, some sound advice from Anthony in the first Instance for fault finding
I hope you get it sorted quickly!
recruit is offline
post #8 of 11 Old 10-22-10, 07:25 AM
Anthony's Avatar
Anthony
Some units have a factory reset procedure that usually involves holding down a button for 15 seconds or holding the power while you plug it in. It wipes all the user settings, but puts everything back to the original state.
Not likely to fix it, but worth a shot in case this is an internal "software" glitch. Hopefully someone here knows it for Onkyo products and can help. It may even be in the regular user manual towards the back in the troubleshooting section.
Otherwise, back for repairs. Might be covered under warranty. Sometimes they get extended (due to a known fault) or the CS rep is nice and they honor it anyways. I had my Marantz fixed out of warranty several years ago. Cost me $280 total to replace two output stages (2 channels blew in the amp section). This was local, though, no shipping required.
Good luck.
Anthony is offline
post #9 of 11 Old 10-22-10, 04:15 PM
bambino's Avatar
bambino
The reset procedure should be in the manual, mine is but i've got a Denon. If not in there check the website for resetting. I really hope this will help but i have a good feeling it's an internal problem beyond a glitch. Good luck and let us know how you come out.
bambino is offline
post #10 of 11 Old 10-22-10, 04:50 PM
salvasol's Avatar
David
Did you follow this procedure??? (Is in the manual page 92)
Can't turn on the AV receiver
The amp protection circuit has been activated.
Remove the power cord from the wall outlet immediately.
Disconnect all speaker cables and input sources,
and leave the AV receiver with its power cord disconnected
for 1 hour. After that, reconnect the power cord
and set the volume to maximum. If the AV receiver
stays on, set the volume to minimum, disconnect the
power cord, and reconnect your speakers and input
sources. If the AV receiver turns off when you set the
volume to maximum, disconnect the power cord, and
contact your Onkyo dealer
I also found this to reset AVR...
http://www.justanswer.com/questions/...in-my-ht-s6100
salvasol is offline
onkyo , reciever , shutting
