Receiver not working?Help!! - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 7 Old 11-16-10, 02:44 PM Thread Starter
Banned!
Spencer
Okay I'm using a KLH R5100 Receiver and when ever I turn it on and turn the volume past about 25 out of 60 it just cuts off and the amplifier shuts down. Anyone know what this could be?
spencerearl1996 is offline
post #2 of 7 Old 11-16-10, 04:10 PM
GranteedEV's Avatar
Kick logic 2 da curb
Re: Receiver not working?Help!!
Uh.....
.... I've never even heard of your receiver but I assume it's going into protection mode
GranteedEV is offline
post #3 of 7 Old 11-16-10, 04:12 PM
Jungle Jack's Avatar
Jack
spencerearl1996 wrote: View Post
It would appear that is where the AVR goes into Protection. That is where it runs out of available power. The Speakers used and size of the Room will usually dictate this. Also, things like raising the Bass Level or Speaker Level Gain will affect where the AVR runs out of steam.
Just to make sure, do check all Speaker Connections for shorts and oxidation if using Bare Wire. If the level is not to you're liking, you might need a more powerful AVR or the addition of an Amplifier.
Cheers,
JJ
HT
Speakers: Martin Logan Vantage (Mains), Martin Logan Stage (Center), Martin Logan Vista (Surrounds), Martin Logan Montages (Surrounds) Hsu Research VTF-15h MK2, Martin Logan Descent i (Subwoofer)
Amplification: Aragon 8008bb, Parasound HCA-3500, Parasound HCA-2205 AT, Parasound HCA-1000a
AVR/SSP: Denon AVR-4520CI
Electronics: OPPO BDP-93
Gaming Consoles: Sony PS4, Xbox 360 S (250 gb)
Display: Panasonic TC-P65ZT60, Sony KDL-55EX500, Sony KD-34XBR910
Jungle Jack is offline
post #4 of 7 Old 11-16-10, 05:47 PM
koyaan
The AVR could also go into protection mode due to heat. Make sure you've got enough venelation space around it, particularly above it. I use shelves that are open in the center and create extra breathing space for my amp by placing bricks beneath the feet of the disc player above it.
koyaan is offline
post #5 of 7 Old 11-16-10, 05:53 PM
DaRoza's Avatar
Ryan
An added not if none of the above works, there could be a leaky output transistor or some bads caps on the output line. In either case you may need service on the unit as they take alot of work to get to most components to test.
Good luck
Ryan DaRoza.
Electronics Tech
Service Manager
352.575.4166 (Cell)
DaRoza is offline
post #6 of 7 Old 11-16-10, 07:54 PM
bambino's Avatar
bambino
GranteedEV wrote: View Post
Uh.....
KLH is a brand that has been around for quite along time, not top of the line but they do the job.
I would agree with the rest of the posters is to check all wireing if it's all good then i would assume your overloading it causing it to go into protection.
bambino is offline
post #7 of 7 Old 11-17-10, 06:57 AM
akeoo7's Avatar
AKE
It seems like some protection circuit is kicking in.
You may be using 4ohm low efficiency speakers, these are power hungry speskers that may be bringing your receiver down to its knees.
Heat is another culprit to check out, try moving the receiver into an open place and regularly check it for overheating.
Last check your wiring for faults.
akeoo7 is offline
receiver , working?help!!
