Trying to figure out a way to stop the blinking madness while still being able to see it when I need (so no tape or paint).
The LED flashes when in standby, which is of course annoying.
[/B]ut less obvious and unmentioned is that it's a ******** bright LED when the unit is powered on. Not so good when the room is dim and you're watching a movie.
Yet another problem with the design is the LED is behind a plastic front panel, making it harder to mask the angry blue light.
Any ideas? Functionality is the desired end result, but it sure would be nice if it looked good too.
If you're not going to change the volume TOO often, you can take a small strip of electrical tape and tape a "shade" over it. You can use colored electrical tape (BTW, I like electrical tape as it doesn't leave residue as much as other tape), and a prettier square of material.
Only tape the top, so it acts like a hinge if you need to view the LED......
I cover LED's in my bedroom system with black tape, and there are no distractions at night this way.....
The way to fix the brightness would be to replace the resistor for the LED with a higher value which would dim it, however, that would require tracking down the current value and solder work.
Don't have any ideas how to fix the blinking, that would just drive me insane.
I use fusion tape to cover the lights in my theater. It will completely block the light and does not have adhesives. It will stick just enough to not fall off and is reusable so you can take it on and off as much as you like.
What about just a simple switch that removes the ground signal from the display. You turn off the power and turn off the display. I know it is not a optimal solution but it would work.
Related Threads
742.3K posts
170.9K members
Since 2006
