Upgrade receiver/external amp? - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 18 Old 08-11-09, 04:21 PM Thread Starter
Just looking for input/advice on powering a set of rockets. I posted a similar thread on av123 about a year ago but was wanting to revisit the topic since the rockets seem to love extra power.
Listening habits are probably 70% movies and 30% music. It seems that different tracks/sources have a huge impact on high the receiver is turned up. Obviously it varies between receivers and speakers, but for some blu-ray discs the volume at -30 would be louder than a regular dvd at 0 and vice versa. Some music needs to be turned up to the 0 mark and other cd's are fine at -20. Not sure how the variance is this much, but whatever... (Btw, everything is played through a ps3 via hdmi).
Currently using a Yamaha 663 and it seems to be turned up quite a bit, I'm wondering if it's being pushed pretty hard to power the rockets...
I'm curious about upgrading to a higher end receiver, such as the onkyo sr805 or maybe the newer pioneer sc-05 with the ice amps. I've seen the results from the test bench and with five channels driven, the onkyos seem to put out great power. I know the 805 has a couple issues, but I'm curious about finding a used one and seeing if the power difference would be noticeable..
The other option was since my receiver has pre-outs, using an external amp such as the emotiva lpa-1 or something similar. My only worry is this being overkill, not to mention probably getting a new stand to house to monster that is the lpa-1.
Just curious how you guys like the higher powered receivers powering your setup and/or other advice you might have. Thanks in advance. :thumbsup:
Interspy24 is offline
post #2 of 18 Old 08-11-09, 11:10 PM
droht's Avatar
droht
I haven't tried the exact components and speakers you are using or considering, but I have run Ref1s with Yammy 659 and Emo LPA-1. The LPA-1, with either the Yammy or the LMC-1 was a pretty signifcant improvement over the AVR by itself.
I got rid of the Refs and the Emo gear, but then really considered more Refs, with a better AVR instead of separates. Lots of research lead me to believe that better AVRs will be an improvement over the 659, but not the kind of step change I experienced with the LPA-1. I think separates is the way to go, I just don't have the space to do it.
droht is offline
post #3 of 18 Old 08-11-09, 11:48 PM
Mike_WI's Avatar
Mike
AVS - (un)Official "Should I get an amp" Thread
Interspy24 wrote: View Post
Check this AVS thread out...
From that...
"IMHO there are three main questions you need to answer YES to in order to benefit from an external amp
1) Are your speakers difficult to drive - Typically this means that they are 4 ohm or lower.
2) Are your speakers inefficient - The less efficient your speakers are, the more power they can benefit from
3) Can your speakers hit very low frequencies - IE. bass. For now I'll go with a figure of < 40 hz."
I hope that helps.
Mike
Mike_WI is offline
post #4 of 18 Old 08-11-09, 11:49 PM Thread Starter
droht wrote: View Post
Thanks for your response, I appreciate it.
Just curious what advantages do I gain from running the LMC-1 versus a receiver? Are their any disadvantages? I believe most don't have the latest hd audio formats like the receivers do...
post #5 of 18 Old 08-11-09, 11:53 PM Thread Starter
Mike_TX wrote: View Post
From that...
I hope that helps.
Mike
Mike,
Thanks for the info, I'll read that thread as most others seemed too one-sided. Meaning, an external amp will sovle world hunger or it didn't make a significant difference... Most who suggest the external amps seem to note they make a considerable difference for music. My main concern was volume, I have my receiver at "0" and I'm worried about how hard I'm driving it. Maybe I'm doubting the receiver and could do this for a long time? Or maybe it's peace of mind? Given a choice, I'd rather use a more powerful receiver at 60% of its capacity than mine at say, 95%.
post #6 of 18 Old 08-12-09, 12:02 AM
droht's Avatar
droht
I honestly was not a big fan of the LMC-1. I think the Yammy sounded just as good with the LPA-1.
In terms of what the LPA-1 did with the Refs, for 2 channel music it opened them up. I know that sounds like reviewer , but it is the best way to describe the change. The improvement on HT was significant as well. With the LPA-1 the Refs did an amazing job on details at low volume. Stuff that you might be straining to hear or missing unless you crank volume up was very audible. Maybe it seems odd that separate amplification made more difference at low volumes?
From lots of reading at av123 forum I think the Refs are harder to drive than the Rockets. CW seemed to be that Rockets benefit from better amplification, but Refs need it.
droht is offline
post #7 of 18 Old 08-12-09, 12:17 AM Thread Starter
Thanks again for sharing your experiences with the Yammy receiver and the LMC-1. :thumbsup:
The characteristics you stated are what I've been reading - more detail, fuller sounding, and smoother at high volumes. It would help to hear the smaller things at lower volumes imo.
I really don't listen at high volumes, but using the volume readout (though a bit silly) it seems the Yammy is being taxed quite a bit. I'd hate to hurt a perfectly good receiver because I'm playing movies too loud.
I will say I echo the thoughts of what others stated in regards to volume with the x-series vs the rockets. At lower levels the x-series seem to have more detail than the rockets. I was first using 4 x-sls classics with a matching x-cs center. I then upgraded to 5 x-cs encores. At lower volumes these speakers seemed to have more detail and/or I could hear more if that makes sense. The x-cs speakers are rated around 90.5 for sensitivity, so their efficieny over the rockets probably plays a major role in this.
With the rockets, they seem to be at their best when played at higher levels. At lower levels they sound okay, but when turned up they rock (no pun intended).
Btw, a bit off topic but I wonder how speakers such as the jtrs/catalysts/sparks sound at lower levels. They are very efficient speakers that can played at very high levels.
post #8 of 18 Old 08-12-09, 11:25 AM
Mike_WI's Avatar
Mike
Mike,
Interspy24 -
I may have missed it, but can you spell out:
- Rocket speakers and impedance in ohms
(realizing that impedance varies across the FR -- see av123 graph on link)
- SPL desired - see link
- music ("pop" music compressed with smaller dynamic range vs. classical, etc. with wider dynamic range)
- listening distance
EG...
If the speakers are av123 Rocket 850 Signatures then...
Frequency Response: 36 Hz to 20 KHz (± 3 dB)
Impedance: 8 Ohms nominal
Efficiency: 91.5dB (@ 1 watt / 1 meter)
At 1 meter with 1 watt of power you would get 91.5 dB -- pretty loud.
You can look at the power calculation tables for:
- increasing distance
- increasing SPL
- peak dynamic range
From AVS link:
"So to hit 110 db, you'd need 19 db or roughly 6 doublings.
2 - 4 - 8 - 16 - 32 - 64 watts"
and
"Distance from the speakers - Your SPL drops 6 db every time the distance in meters doubles"
at 2m SPL could be 107 dB for 64 watts
There is another link/thread on AVRs with "all channels driven" which is much less than 1 or 2 channels driven in most cases (eg cheap AVRs).
This is more critical for HT than 2 channel listening.
Mike
*EDIT*
Oh yeah, and...
2 speakers (vs. one adds 3dB), so in example above for 850Sigs at 2m at 64W = 110 dB (loud)
Mike_WI is offline
post #9 of 18 Old 08-12-09, 03:49 PM Thread Starter
Mike TX - thanks for the response.
Center: Bigfoot classic
89dbs and 6.8ohms (these are the specs for the sig, I assume the classic is close?)
Mains: RS750 classics
88dbs and 6ohm
Surrounds: RS250s
88dbs and 6 ohms
I know it's an important factor, but I can't say the spl for sure.
I don't listen at very loud levels, it just seems the receiver is cranked to 0 for the entire length of the movie. If this isn't a problem, then I'm good to go. If it is and/or I can gain quite a bit gaining more power, then I'll definitely look into it. As I stated earlier, even using the ps3, some dvds and blu-rays use the volume level at VERY different settings.
Seating distance is about 8 feet from the center and mains.
For music, I listen to mostly rock, jazz, classical, and some pop.
For movies, it's usually the action stuff with fun lfe scenes
post #10 of 18 Old 08-12-09, 03:55 PM
Angel City Audio
Vik,
Basic question (not sure if it's been mentioned), but have you re-calibrated everything after you changed out to the new Rockets?
I'd go for something like an Emo 3-channel amp and use whatever receiver to power the surrounds. If you need a new pre-pro, then I'd wait for something like the UMC-1 to be thoroughly tested before hopping on board.
PhenomeNhan is offline
amp , receiver or external , upgrade
