Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Receivers | Processors | Amps
HK or Onkyo
Discuss HK or Onkyo in the Home Theater | Audio and Video forum; HK or Onkyo Ok guys, looking at in the possibly near future upgrading my current receiver (old old pioneer 5.1 receiver) to another ...
Views: 1488 - Replies: 14
Old 05-04-07, 02:48 PM   #1
Alias: brandon
brandonnash's Avatar
Loc: Murfreesboro, Tn
User: #2533
Since: Sep 2006
  brandonnash is offline
HK or Onkyo
Ok guys, looking at in the possibly near future upgrading my current receiver (old old pioneer 5.1 receiver) to another newer one. Looking at something very very inexpensive and the shoponkyo page seems very good. Also the refurb site for hk on ebay looks good also. Going to try to get something under $200 if possible. I want good sound. It doesn't have to be all that powerful. It'll go in a small room and is rarely ever played that loud. I want the ability to on occasion to be able to crank it up. I like that the HK's have onscreen menus, but their power is a little questionable.
Any comments would be appreciated.
Old 05-04-07, 02:55 PM   #2
Alias: brandon
User: #2533
Since: Sep 2006
Re: HK or Onkyo
OH, let me add that I do like the pioneer receiver, I just want a few of the more modern features associated with newer receivers. I would like to get at least component video switching, more than 2 digital audio inputs, little more actual (not quoted) power, auto calibration wouldn't hurt, and better sound quality.
Old 05-04-07, 04:07 PM   #3
Alias: chas
Loc: Minnesota
User: #6091
Since: Jan 2007
  chas is online now
Re: HK or Onkyo
From your other posts I know you have Athena speakers which tend to run on the bright side. I haven't heard an Onkyo receiver but I have had an HK AVR-340 which was warmer sounding and very musical.
Old 05-04-07, 04:28 PM   #4
Alias: brandon
User: #2533
Since: Sep 2006
Re: HK or Onkyo
I like the AV-140 from HK, but 40 watts times 6 gives me a bit of pause. Can't afford the higher end models. I like denon products too, but once again, too expensive.
Old 05-04-07, 04:38 PM   #5
Alias: brandon
User: #2533
Since: Sep 2006
Re: HK or Onkyo
Ok, hate to keep adding but I do want better bass management. My current receiver has a 100/150/200 crossover. Would much rather have an 80 or possibly 60 hz crossover.
Old 05-04-07, 05:52 PM   #6
Alias: chas
Loc: Minnesota
User: #6091
Since: Jan 2007
  chas is online now
Re: HK or Onkyo
The power ratings on the HK's are deceptive. They are much more powerful sounding than you would think, and the Athena's are efficient speakers.
Both Onkyo and HK have good bass management - many of their models allow you to set separate crossover points for center, fronts, and surrounds. Most will probably have 60 and 80 hz settings.
Old 05-04-07, 11:30 PM   #7
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is online now
Re: HK or Onkyo
Look for a used Denon or Yamaha unit.
Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for.
Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information.
Old 05-10-07, 01:26 PM   #8
Alias: Paul
Loc: Wichita, KS
User: #3420
Since: Oct 2006
  pgoko is offline
Re: HK or Onkyo
HK probably makes the most powerful receivers out there. These are high current boxes. Anyway that is why an amplifier is called "amp"lifier and not "volt"ifier. I have auditioned quite a few receivers myself. A 40W per channel HK receiver can out perform any 100W Japanese receiver any day. And again, at very high volumes the HK gets faster and tighter, and still maintains 5.1 seperation, and clean. On the other hand, you cannot tell the difference among channels in a "voltage" amplifier or low current machine at high volumes. All the channels are not discernable and tend to sound as one channel and muddy. HK boxes are good old raw American power. If you want very clean power, go for HK. For instance, I have a signature series amplifier (very high current) that I am yet to overdrive, and it is putting every subwoofer to shame. HK is probably the most underrated product out there...maybe HK did it to themselves by discontinuing lots of excellent stuff. 'nough said, go audition before you buy.
Old 05-10-07, 01:52 PM   #9
lcaillo's Avatar
User: #328
Re: HK or Onkyo
This kind of generalization is correct only up to a point. It starts with a bit of truth but is very misleading when stated as you have. Yes, amplifiers need to be able to provide current. High current amps will sound like they hav more impact on music that requires substantial current, particualrly with more difficult loads. To suggest that the HK is significantly better in this regard than other better quality Japanese products is to greatly exagerrate the matter and may not be correct at all, depending on the comparison. The design of the HK does not differ very much from other similar products that hav ben discussed here. I have an HK receiver on my bench right now and comparing the transformer and power supply capacity to a similar Yamaha or Denon, or even a Pioneer, there is little difference. In fact, the Pioneer seems to have a much larger PS capacity than the others. (I am not a fan of Pioneer at all, BTW.)
Old 05-10-07, 03:33 PM   #10
Alias: Paul
Loc: Wichita, KS
User: #3420
Since: Oct 2006
  pgoko is offline
Re: HK or Onkyo
Hey Leo, I am not generalizing, its all from auditioning an HK along with some other receivers side by side. For instance HK is among the few that gives you the High Instantaneous Current Capability (HCC) of thier amps or receivers. For example, if you have an HCC of 20 amps for a 100W receiver, it will sound muddy at high volumes and will have the hardest time driving difficult loads. If you have a bench try listening side by side at very high volumes and you will understand where I am coming from.
Old 05-10-07, 04:03 PM   #11
lcaillo's Avatar
User: #328
Re: HK or Onkyo
HCC is marketing hype. The current capacity of an amp will depend on the power supply filter capacitance and the transformer, assuming the output devices can handle the current. There just is not that much difference between the competing brands in this regard. I work on them all the time. 20 years ago when everyone was using slimmed down power supplies and going to integrated output devices what you say may be true. Today, it is only true when comparing to lower end products. Brands like HK, Onkyo, Yamaha, and Denon are very similar in PS capacity and output capability. Like I said, one of the most beefy power supplies I have seen lately was in a Pioneer.
I have listened to the products many times into many kinds of loads. I have an HK on test right now. I Your statements are exagerations and generalizations of the differences that one might find, and the ability to drive a complex load and deliver current appropriately is likely to vary within brands as much as between brands when comparing the top few on the market. HK is a good product. It is worthy of consideration along with the other brands mentioned, but the performance differences are not as extreme as you would describle them.
Old 05-11-07, 04:02 PM   #12
Alias: Steve
SteveB's Avatar
Loc: Atlanta, GA
User: #3208
Since: Oct 2006
  SteveB is offline
Re: HK or Onkyo
brandonnash check this:
http://www.hometheatershack.com/foru...html#post36031
I have a HK and love it, great customer service too.
Old 05-20-07, 01:48 PM   #13
Alias: Artie
Loc: I ain't tellin ya!
User: #1700
  spyboy is offline
Re: HK or Onkyo
lcaillo wrote: View Post
Hi
I have owned both HK separates and a Citation 7.1 power amp. I had too many problems with the HK separates. I almost bought an HK 8000, but I read about noise problems in the center channel, so I canceled my order. I never regretted canceling my order. I eventually bought a Kenwood VR 6070. That tested at 92 watts RMS X 6 simultaneously. It has served me very well.
Now I have a Denon 5803A that is a monster receiver. However, it is way more complicated than my Kenwood VR 6070.
I simply can't recommend any HK receiver. Over the years, I have come to the conclusion that HK receivers do not get enough Beta Testing.
I would choose an Onkyo over the HK, especially the new Onkyo line, including the Onkyo 605.
All the Best
Old 06-02-07, 05:02 PM   #14
Alias: brandon
User: #2533
Since: Sep 2006
Re: HK or Onkyo
Still going to have to stick to the cheaper receivers. Looking on the SHOPONKYO.COM site, I stumbled on a TX-SR304S on the very cheap. Does anyone have an opinion on this? It's still only 5.1, but it's going in my ~medium sized living room until I can afford more to put into a dedicated theater. Would love a 7.1 receiver, but I'm not so sure my living room is big enough and that my current furniture configuration can support it correctly.
Old 06-03-07, 01:02 AM   #15
Alias: Artie
User: #1700
  spyboy is offline
Re: HK or Onkyo
brandonnash wrote: View Post
Hi
I would save up a little bit more and get the Onkyo 504.
All the Best
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Receivers | Processors | Amps »
