Sherwood/Newcastle R-972 Official Thread - Page 17 - Home Theater Forum and Systems - HomeTheaterShack.com
post #161 of 944 Old 04-12-12, 01:21 PM
Mike
Re: Sherwood/Newcastle R-972 Official Thread
Thanks for the link, I found that site but it is only a sales flyer and not the owners manual,
Sucks that Sherwood pulled it off their main site, is it really that big a deal to keep a few files available for people to download! It's not like this thing is 10 years old, it is 1 generation old!
typ44q is offline
post #162 of 944 Old 04-15-12, 10:15 AM
Mike
I have a question about installing the bass curves, I have the files I picked the +3db and placed it in the root of my USB drive with no other files on the flash drive followed the instructions as far as turning the receiver on, waiting for the click changing to USB waited for the message and inserted the drive in after which it says UPDATING
This message would flash on for about 10 seconds then blink then flash back on over and over. after about 30 minutes I turned it off figuring that it was not doing anything.
How long should this take?? and did I do something wrong?
As far as I can tell you can only do 1 file at a time even thought the instructions say to copy ALL of the files to the flash drive.
Thanks
typ44q is offline
post #163 of 944 Old 04-15-12, 12:17 PM Thread Starter
tonyvdb's Avatar
Tony
After the hex file has been installed via USB you must Turn off the receiver and then hold down the STANDBY & MEMO/ENTER buttons simultaneously for at least 3 seconds. This will reset the receiver to factory. when you power it back on it should default to the tuner. You will then need to re run Trinnov and reset all your labels and other presets you may have changed.
Home theater:
Living room system:
tonyvdb is offline
post #164 of 944 Old 04-15-12, 03:38 PM
Mike
It never says that it is installed, it just continues to say INSTALLING and never finishes. Is there a message for when it is done? how long should it take?
typ44q is offline
post #165 of 944 Old 04-16-12, 10:49 AM
Mike
typ44q wrote: View Post
Does anyone know if the owners manual is available online? I would like to read through it before I get the receiver but it looks like Sherwood totally dropped support for this thing including the manual
Also are there any firmware updates available for this receiver?
In case anyone else is looking for the English pdf manual online, I found it.
http://www.prillaman.net/sn2007avr/R...ENG_090225.pdf
typ44q is offline
post #166 of 944 Old 04-16-12, 11:02 AM Thread Starter
tonyvdb's Avatar
Tony
If I remember correctly it just stops reading the flash drive. I dont remember if it said anything on the display.
Home theater:
Living room system:
tonyvdb is offline
post #167 of 944 Old 04-16-12, 11:48 AM
I'm considering an R-972, but I need to control it with a JP1 remote. Since Sherwood tech support seems to be down for now (hopefully not forever), I can't get the R-972 ir control codes. Does anyone have this information and could send it to me? Thanks.
StephenR0 is offline
post #168 of 944 Old 04-16-12, 10:38 PM
Mike
tonyvdb wrote: View Post
I re-downloaded the files and tried it again, it worked and only took about 30 seconds and I believe it displayed the message completed or finished.
Beyond that I am having a more serious problem with the receiver in that when watching recorded content on my Time warner HD cable box. If I am watching a recorded show and then switch back to live TV the video blanks out, no signal being sent to the TV at all but I continue to hear audio, the only way to get the video back is to change video inputs from Video 3 to a different input then back to Video 3 and the picture is fine.
I have the cable box connected using component video with optical audio and is being output to the TV via HDMI.
My firmware is version 1.47i
any ideas?? I would hate to have to send this thing back over this as I do like the receiver and love the sound from it but this makes watching TV extremely frustrating.
typ44q is offline
post #169 of 944 Old 04-17-12, 12:21 AM
Isn't the latest version 1.47v? At least, that's what I've read. I would upgrade before sending it back, although I don't know specifically what has been fixed. You might have trouble getting a response from Sherwood technical support just now. They haven't been responsive since before last week. Curt Hoyt from Trinnov said that he expects them to be more responsive some time this week.
post #170 of 944 Old 04-17-12, 07:24 AM
Mike
It would make sense that 1.47v is newer than 1.47i. Do you know where to download it from? all I see on the Sherwood site are firmwares for bluray players
typ44q is offline
impressions , r972 , sherwood or newcastle
