Sherwood/Newcastle R-972 Official Thread - Page 26 - Home Theater Forum and Systems - HomeTheaterShack.com
post #251 of 944 Old 04-23-12, 04:32 PM Thread Starter
tonyvdb's Avatar
Tony
Re: Sherwood/Newcastle R-972 Official Thread
Nope, its across the board.
Home theater:
Living room system:
tonyvdb is offline
post #252 of 944 Old 04-23-12, 04:34 PM
NoahKatz wrote:
Tony, thanks very much for the files and instructions.
If all of the bass targets are put on the flash drive, how will the 972 know which one we want?
Anything the matter with putting only the one we want on the flash drive?
It can not distinguish. You need to unpack them all and only put the single file you want on the flash drive.
cschang is offline
post #253 of 944 Old 04-23-12, 04:37 PM
kriskk wrote:
Will these curves only apply to the Spatial modes? Reason I ask is in my case the bass is very good when Spatial is not engaged.
That is odd. If Trinnov is engaged, bass response should be the same in all spatial modes.
cschang is offline
post #254 of 944 Old 04-23-12, 04:50 PM
cschang wrote: View Post
I have a feeling I need to ensure levels are similar between the speakers first, and then remeasure The sub seems pretty hot at the moment. I have to crack open my ole Radio Shack meter.
kriskk is offline
post #255 of 944 Old 04-23-12, 05:04 PM
The bass filters affect the subwoofer output, only. The names were chosen arbitrarily. The "Flat" curve has 3 dB less output than the curve labeled "+3" and 6 dB less output than the curve labeled "+6". It is not necessarily more accurate in your room than the other 2 curves. David Rich insisted that the +6 curve was flat in his room. I thought the "Flat" curve sounded best in Sherwood's listening/conference room. It could be that we are both correct. However, as Dr. Rich has not only academic credentials but science on his side, I now use the +6 dB curve in my home theater.
Jeff
Stereojeff is offline
post #256 of 944 Old 04-23-12, 05:06 PM
New Member
Thanks for clearing that up
NoahKatz is offline
post #257 of 944 Old 04-23-12, 07:43 PM
New Member
bonfilatos
Hi (please excuse my errors and confusion - I'm both a newbie and using a foreign language)
I have a quick question on the r972 room2 control; with:
1. a 5.1 set-up
2. the room 2 line-out connected to another amp -which will remain at a fixed level-
3. nothing connected to the room 2 speakers,
does the room 2 volume control have any effect?
i.e. is the room 2 line-out variable or fixed?
-thank you
Read more: room 2 control - Home Theater Forum and Systems - HomeTheaterShack.com
bonfi is offline
post #258 of 944 Old 04-23-12, 09:21 PM
bonfi wrote: View Post
1. a 5.1 set-up
It's variable.
cschang is offline
post #259 of 944 Old 04-23-12, 09:58 PM
New Member
bonfilatos
It's variable.
Thanks for the info and prompt reply.
bonfi is offline
post #260 of 944 Old 04-24-12, 07:12 PM
HTS Senior Moderator
HTS Reviewer
tesseract's Avatar
2 channel view
Reran Trinnov 3 times with the SHO-10's, same result. Looks like Trinnov may have issues with high sensitivity speakers. Audyssey Multi EQ has the same issues.
I did dial down the subs to within 1 dB of the mains during calibration, still get the humming at high volumes.
Switched to the TCA WAF-1's, -6 dB point is 71 Hz for both L/R speakers. Bass is non existent no matter which speakers I use, the LFE output is ridiculously low. I have to crank my sub amp gain up ridiculously high to compensate. The only way to get satisfactory bass is to set the Spatial Mode to "None", Room EQ to "Flat".
$84 in shipping fees as well as a 15% restocking fee if I return this. Major bummer.
"I left in love, in laughter, and in truth and wherever truth, love and laughter abide, I am there in spirit." - Bill Hicks
tesseract is offline
impressions , r972 , sherwood or newcastle
