Sherwood/Newcastle R-972 Official Thread - Page 34 - Home Theater Forum and Systems - HomeTheaterShack.com
post #331 of 944 Old 05-15-12, 11:40 AM
Re: Sherwood/Newcastle R-972 Official Thread
a poster on another forum states that Sherwood support claims there will be a firmware update the middle of next month that addresses an issue with a specific STB. Maybe there will be other fixes? Apparently some new bass targets on the way as well.
cschang is offline
post #332 of 944 Old 05-15-12, 12:21 PM
Mike
I heard the same thing from Sherwood support (actually I was told it would be out around the end of the month) and that they would continue to support it for two more years but I guess I am just a bit skeptical that these issues will be resolved.
typ44q is offline
post #333 of 944 Old 05-15-12, 12:24 PM
All we can do is hope.
cschang is offline
post #334 of 944 Old 06-14-12, 10:24 AM
Rich Morrison
I hooked up my new R-972 a couple days ago. The video is working properly but so far no audio at all. I'm using it as a preamp/processor connected to a B&K 200.7 power amp using the 972's preamp output. The power amp was working with the B&K processor so I doubt that is the problem. The 12 volt trigger turns the amp on and the front blue light illuminates when the 972 is turned on. There is output from the 972's power amp. Did I miss something in the setup that turns the preamp output on and/or the power amp off? My next test is to put a volt meter on the preamp outputs to see if there is a signal there unless those with experience know something I haven't learned yet.
Thanks,
Rich
richard7948 is offline
post #335 of 944 Old 06-14-12, 10:27 AM
Mike
I would try to connect the speakers directly to the 972 to see if you get anything at all. I have L,C,R speakers connected to a 3 channel amp and the rears powered by the receiver and I do not remember having to so anything special to get it to work.
typ44q is offline
post #336 of 944 Old 06-14-12, 10:30 AM
Speaker light on front panel lit?
Jim
jaymz is offline
post #337 of 944 Old 06-14-12, 11:15 AM
Rich Morrison
I attached one speaker to the r-972 power amp and that worked, also the red speaker symbol, (red makes you think it is muted) is on. The B&K also has switches for balanced or unbalanced inputs and I actually remembered to change them too.
Thanks for the quick responses,
Rich
post #338 of 944 Old 06-14-12, 11:56 AM
Jungle Jack's Avatar
Jack
Hello,
I have actually never hooked up a Speaker Cable to the 972 and have always used Outboard Amplification with it. This is the first instance I have come across where there is no sound when an amplifier is connected. I would try disconnecting the 12v Triggers just to see if that changes anything. I am guessing that you will get sound with the Triggers off for some reason. A gut feeling if you would. All the same, sorry you are having these issues and I hope for a speedy resolution.
Cheers,
JJ
HT
Speakers: Martin Logan Vantage (Mains), Martin Logan Stage (Center), Martin Logan Vista (Surrounds), Martin Logan Montages (Surrounds) Hsu Research VTF-15h MK2, Martin Logan Descent i (Subwoofer)
Amplification: Aragon 8008bb, Parasound HCA-3500, Parasound HCA-2205 AT, Parasound HCA-1000a
AVR/SSP: Denon AVR-4520CI
Electronics: OPPO BDP-93
Gaming Consoles: Sony PS4, Xbox 360 S (250 gb)
Display: Panasonic TC-P65ZT60, Sony KDL-55EX500, Sony KD-34XBR910
Jungle Jack is offline
post #339 of 944 Old 06-14-12, 12:42 PM Thread Starter
tonyvdb's Avatar
Tony
Im not at home right now but in the user menu there is a setting for HDMI that I accidentally turned on and I lost the sound output. is it possible that you did the same thing?
Home theater:
Living room system:
tonyvdb is offline
post #340 of 944 Old 06-14-12, 12:44 PM
hjones4841's Avatar
Silly Girl!
Is there an amp assign item on a setup menu that needs to be set for pre-outs to be live? I have Denon, so no help on Sherwood. I would think the pre-outs are live even when the internal amps are in use - that is the way it is on Denon.
Hug your pet today!
hjones4841 is offline
impressions , r972 , sherwood or newcastle
