Sherwood/Newcastle R-972 Official Thread - Page 47 - Home Theater Forum and Systems - HomeTheaterShack.com
post #461 of 944 Old 08-13-12, 12:59 PM Thread Starter
tonyvdb's Avatar
Tony
Re: Sherwood/Newcastle R-972 Official Thread
I read a few posts on AVS that users have had this thump happen. It seem common enough that I think its just another quirk and not a problem with the unit. I only her it if I am using the Trinnov Imaging correction 2D/3D and such if I have it set to none I dont hear it.
Home theater:
Living room system:
tonyvdb is offline
post #462 of 944 Old 08-13-12, 01:11 PM Thread Starter
tonyvdb's Avatar
Tony
Not sure if anyone has seen this but I found this very useful PDF on the 972 and how to correctly understand and use Trinnov, located here
Home theater:
Living room system:
tonyvdb is offline
post #463 of 944 Old 08-13-12, 02:18 PM
Inactive
Ty
tonyvdb wrote: View Post
Yep but i was bummed i couldnt get the two trinnov calibrated rooms found on page 12 to work for me. This article was linked early on in this thread, i think by jj. Just got new seating in the theater so might give the dual calibrations another shot. Maybe its the folded ribbon martin logans that are high mounted in zone 2 that trinnov just doesnt like...
TypeA is offline
post #464 of 944 Old 08-16-12, 07:31 PM
HTS Moderator Emeritus
Anthony's Avatar
Anthony
Just got the whole family room system hooked up. Ran the Trinnov and got an interesting result.
Distances and levels seem right, but the -6dB point for the speakers said zero for all of them. Anyone else get this? My fronts are a pair of DIY 2.5" speakers that I know can't play below 80 Hz, and I was putting them at 120Hz manually.
Sadly my cal mic is packed for shipping (calibration), so I can't get an REW reading.
Did I do something wrong? I figure even if it got the fronts wrong, it should have had something for the surrounds (8" in ceiling speakers).
Overall it sounds pretty good with just the position and DLY+LVL spatial mode. 2D and 3D sounded weird.
Still playing around with it. I'm sure some of this is my fault
Anthony is offline
post #465 of 944 Old 08-16-12, 07:38 PM
Mike
Something doesn't sound right.
I have always found that I get better results if I do a factory reset before running Trinnov, I have only gotten weird results when I have not done this.
I copied this from the first post on this thread:
To reset the R-972 to factory settings:
Once in Standby Mode, press and hold down the STANDBY & MEMO/ENTER buttons simultaneously for at least 3 seconds. This will reset the unit and it will turn on automatically. If the reset was successful, you should notice that the receiver powers up at 87.5 FM . If not, repeat the reset process.
sub_crazy is offline
post #466 of 944 Old 08-16-12, 07:48 PM
Anthony's Avatar
Anthony
I set all the speakers to full with no crossover and ran it again.
The volume on the measurement was much louder, and I do remember turning it up while I watched shows to listen to the differences.
I did not pay attention to that last time, but it might be dependent on the system volume. It's calculating now. Might be the levels were too low and the speakers could handle full range at that lower volume
We'll find out . . .
Anthony is offline
post #467 of 944 Old 08-16-12, 08:05 PM
Anthony's Avatar
Anthony
nope, still zero for the -6dB point.
I wonder if this is because I don't have a sub yet. The rears can handle some bass, but the fronts are definitely smalls. I'll try the reset tomorrow night and recal. For now it's not bad, though.
Anthony is offline
post #468 of 944 Old 08-18-12, 04:41 PM
Drudge's Avatar
D
Sounds like another Sherwood quirk rearing it's ugly head.
The sub thumping is normal in standby mode and I doubt there will be any fix for it.These units definitely have stability issues.There seems to be no rhyme or reason to some of the results you get from the calibration.
Drudge is offline
post #469 of 944 Old 08-20-12, 08:37 AM
Good Day:
Can anyone please inform me if the 972 can accept dsd over hdmi and decode it as sacd. This is the only issue I find not clear in all the info I find. Thinking of selling my onkyo 3009 for one of these. Love to try Trinnov. Also how is the vid processor. I usuall use direct or through for that anyway.
Thanks in advance.
bobav is offline
post #470 of 944 Old 08-20-12, 04:42 PM
Drudge's Avatar
D
The R-972 doesn't accept DSD direct over HDMI, only DSD to PCM decoded by the player.The video processor works,but most recommend just bypassing it.I don't know how well it would compare to the Onkyo 3009.
Drudge is offline
impressions , r972 , sherwood or newcastle
