Sherwood/Newcastle R-972 Official Thread - Page 56 - Home Theater Forum and Systems - HomeTheaterShack.com
post #551 of 944 Old 02-04-13, 09:00 AM Thread Starter
tonyvdb's Avatar
Tony
Re: Sherwood/Newcastle R-972 Official Thread
I use mine almost exclusively for 2ch listening and it sounds fantastic. I do have a sub with it as well. Im not sure how Trinnov would like not having one.
Home theater:
Living room system:
tonyvdb is offline
post #552 of 944 Old 02-04-13, 09:17 AM
All:
Sorry for all the questions but i really want to know what I am getting myself into.
Did Sherwood ever correct this issue (from Stereophile)?
Second, there's no way to set a default audio mode for each input format. Since I prefer to listen to almost all sources in their native formats, I choose Stereo for two-channel sources, but want appropriate decoding for all the rest. If you listen in stereo and change channels, the Sherwood will, by default, downmix Dolby Digital to two-channel. Even worse, switch from a nicely decoded Dolby Digital source to a stereo source and the R-972 will reprocess it into a surround mode, with unpredictable results
quern is offline
post #553 of 944 Old 02-04-13, 09:19 AM Thread Starter
tonyvdb's Avatar
Tony
It will remember the last setting you used for that input.
Home theater:
Living room system:
tonyvdb is offline
post #554 of 944 Old 02-04-13, 02:18 PM
Onkyolover's Avatar
Which is better for home theater sound the Onkyo or sheerwood. From this thread it sounds like the sheerwood has better performance. I have yet to experience a sheerwood. I currently own a 809 Onkyo and was wondering what the difference is as far as sound quality.
Sent from my PC36100 using HT Shack
Onkyolover is offline
post #555 of 944 Old 02-04-13, 03:14 PM
Mike
I had a Onkyo 5508 and still have a 3008. I prefer the Onkyo for music but for movies the 972 creates such a cohesive sound field that the Onkyo cannot match nor any other receiver or pre-pro I have owned.
sub_crazy is offline
post #556 of 944 Old 02-04-13, 03:36 PM
Onkyolover's Avatar
Am going to have to give a sherwood a try I use my Onkyo for 80% movies and 20% music
post #557 of 944 Old 02-05-13, 10:25 AM
One common comment is that when purchasing this unit you must like to tweak.
What exactly does this mean?
Are you referring to multiple times running the setup software for trinnov... Or experimenting with what settings to turn on?
quern is offline
post #558 of 944 Old 02-05-13, 10:56 AM Thread Starter
tonyvdb's Avatar
Tony
quern wrote: View Post
The receiver produces awesome sound however the mic placement is crucial and the 972 has its quirks meaning it is a little temperamental as it sometimes misses turning on the output to the speakers. (switching inputs fixes that). And there is also the sub thump that occurs when using a remote command from another remote.
Home theater:
Living room system:
tonyvdb is offline
post #559 of 944 Old 02-05-13, 07:56 PM
Hi Guys, First time poster and fell R-972 post, well as of today. I got this REceiver to replace my Marantz SR6004 which has served me well for 4 years but I felt like a change. The Box arrived today and its a big piece of electronics. The remote like everyone else has said is bad and the interface is not the most user friendly.
I reset the unit as is recommended on this thread and ran the trinnov calibration with my marantz pm8004 driving the L and R fronts. All was good for and hour or two but things seem to have gone downhill. There is a buzzing from my front right speaker, I changed out the Pm8004 and let the Sherwood drive the fronts but its still there, I tried another speaker and it produced the same distortion. I checked my source and replaced the sacd player with another, still the same buzzing.
I did a full reset and the buzzing seemed to be gone , so i re ran the calibration and there it was back again.
Anyone got any idea?
This was one of the 1saleaday refurnished units and I know they will be on no help
Any input appreciated, i think I have covered all the bases
melmoth76 is offline
post #560 of 944 Old 02-05-13, 08:01 PM Thread Starter
tonyvdb's Avatar
Tony
That is not sounding good. Its sounding like there is an issue with it. Have you disconnected everything but the speakers and see if the buzz is still there?
Home theater:
Living room system:
tonyvdb is offline
impressions , r972 , sherwood or newcastle
