Sherwood/Newcastle R-972 Official Thread - Page 59 - Home Theater Forum and Systems - HomeTheaterShack.com
post #581 of 944 Old 02-09-13, 06:25 PM
asere's Avatar
bhazard wrote: View Post
I sold my Denon 4311 and kept the Sherwood. That's what you should expect.
I might be using two subs now my hsu and kreisel. Will it work with only multeq since it eqs them as one?
asere is offline
post #582 of 944 Old 02-10-13, 11:29 AM
Re: Sherwood/Newcastle R-972 Official Thread
I have a dual opposed sub in one spot, so I have no idea how it will handle 2 subs. I have a feeling Trinnov will compensate somehow.
bhazard is offline
post #583 of 944 Old 02-10-13, 11:42 AM
mdp
Trinnov will see both as a single unit, it can't match level on those individually. So, you need to level match each sub. After that, Trinnov will level match both subs together to mains.
mdp is offline
post #584 of 944 Old 02-24-13, 10:55 AM
bguzman's Avatar
bguzman
Hello, my R-972 will be arriving Tuesday and I have a question. Currently I am running an Onkyo 707 with all 11 speaker positions used. I then select a 7.1 combination for playback, PLIIz, PLIIx, or DSX wide/heights. My plan is to connect the Surround Back/Multi to a speaker selector that is connected to the SB, FH, and FW speakers. Then run Trinnov and save each setup to one of the three Positions. I am getting my self prepared for the numerous trials and resets but I think the end results will be pretty awesome. Inevitably I will need to do a reset in between positions. Will this erase any positions that are already calibrated?
In Both Main HT Living Room HT
SIGHT
Mitsubishi ~ Samsung ~ Panasonic ~ Pioneer ~ Oppo ~ Marantz ~ Toshiba
SOUND
Polk ~ Klipsch ~ Sherwood/Newcastle ~ Pro-Ject ~ Def Tech ~ B&W ~ Klipsch ~ Infinity ~ Yamaha
bguzman is offline
post #585 of 944 Old 02-24-13, 12:21 PM
Mike
When you do a reset the receiver goes back to it's original settings so this will erase any previous calibrations and remove any bass target files you may have uploaded. Basically a reset will put the 972 back to it's original state that it came in when new.
What your planning on doing sounds interesting, I would definitely like to hear how it works out for you.
sub_crazy is offline
post #586 of 944 Old 02-24-13, 12:26 PM
asere's Avatar
I was told Trinov does not eq the sub like Audyssey. Does Trinov do anything for the sub?
asere is offline
post #587 of 944 Old 02-24-13, 12:46 PM
Mike
asere wrote: View Post
Trinnov does EQ the subs and does a decent job. I got a little better results with my Onkyo 5508 and XT32 on the sub channel but I still sold the Onkyo and kept the 972 because Trinnov and it's 3D re-mapping is something I cannot give up.
I would say that is you have your speakers in the exact proper location that the Trinnov spatial re-mapping has little to nothing to correct than my choice would be Audyssey XT32. In my system XT32 did a little better job in EQ'ing the speakers and subs and overall I preferred the Onkyo 5508 for music listening.
post #588 of 944 Old 02-24-13, 01:03 PM
bguzman's Avatar
bguzman
sub_crazy wrote: View Post
I will definitely post my results. Hopefully once I get the mic set and reading the angles properly, I can get my three positions calibrated relatively problem free.
Edit:
I found this when I was looking for the bass files, it says to reset after loading the file.
tonyvdb wrote: View Post
Its ok I can try and hopefully I dont cause trouble.
Please open the attached zip file and uncompress. Please copy all of the factory.hex files to USB drive root position. (ex. E:\factory.hex)
To update this firmware, turn ON the 972 and wait for relay click. Once you hear the relay click, change the input to USB. When NO DEVICE displayed, please insert the USB drive to the front USB slot.
Update will automatically start.
After finished, please reset the receiver by following the attached instruction.
To successfully reset, you need to start with the unit in the Standby Mode. To put
the unit in the standby mode simply press the standby button when the unit is On or unplug the
power cord from 120V AC and then plug it back in. Once in Standby Mode, press and hold
down the STANDBY & MEMO/ENTER buttons simultaneously for at least 3 seconds. This
will reset the unit and it will turn on automatically. If the reset was successful, you should notice
that the receiver powers up at 87.5 FM . If not, repeat the reset process
SIGHT
SOUND
bguzman is offline
post #589 of 944 Old 02-24-13, 01:07 PM
asere's Avatar
How is Trinov with in ceiling speakers vs Audyssey?
asere is offline
post #590 of 944 Old 02-24-13, 01:47 PM
bguzman's Avatar
bguzman
Having waded through this and other threads there are people using ceilings speakers with Trinnov. The speakers had aim-able tweeters from what I can recall.
SIGHT
SOUND
bguzman is offline
impressions , r972 , sherwood or newcastle
