Sherwood/Newcastle R-972 Official Thread - Page 77 - Home Theater Forum and Systems - HomeTheaterShack.com
post #761 of 944 Old 05-28-13, 11:31 AM
Re: Sherwood/Newcastle R-972 Official Thread
Does anyone know if the settings for assignments and the Trinnov settings keep if you turn off the power button, or does it have to stay in standby mode to keep the settings? Since this is on the TV my wife uses, i don't get to use the surround sound very often, so I would rather turn the power off until I use it, but I am not sure if all the settings stay saved if the power button is turned off. Also, I keep all my gear on a UPS as we get a lot of power outages in my area as i live in a forest area. So if the power is out for longer than the UPS can hold the charge, does that lose the settings? If you know, please let me know.
Thanks
Mike
mike in ca is offline
post #762 of 944 Old 05-28-13, 12:14 PM Thread Starter
tonyvdb's Avatar
Tony
As long as it stays plugged in to the wall it should keep the settings for a couple weeks at least.
Home theater:
Living room system:
tonyvdb is offline
post #763 of 944 Old 05-28-13, 02:26 PM
islandman2020's Avatar
I always turn mine completely off. Never lost any settings.
islandman2020 is offline
post #764 of 944 Old 05-28-13, 02:59 PM
HTS Senior Moderator
HTS Reviewer
tesseract's Avatar
2 channel view
Mine was unplugged and set aside for months, all settings were retained.
"I left in love, in laughter, and in truth and wherever truth, love and laughter abide, I am there in spirit." - Bill Hicks
tesseract is offline
post #765 of 944 Old 05-28-13, 10:59 PM
Mike
tonyvdb wrote: View Post
I have no idea why someone would buy a used 972 when you can get them brand new for $599 at accessories4less (not refurbished) with a 3 year warranty.
+1
The extra $ is worth the piece of mind just for the 3 year warranty on a receiver with a lot of known issues.
BeeMan458 wrote:
It's easier for you to prove I'm crazy than it is for me to prove I'm not.
sub_crazy is offline
post #766 of 944 Old 06-01-13, 03:31 PM
Angry Re: Sherwood/Newcastle R-972 Official Thread
Well i finally got the time to sit and watch a dvd today using my new R-972. Major problem! I tried everything I could think of and no matter what i tried, I could not get any audio using the HDMI inputs. I tried every port, several cables including the one that goes to the TV which i know works and not a peep of audio from any HDMI port. I had no problem getting audio from both my DVD and satellite box using optical, but nothing from the HDMI. Any suggestions, or do you think the unit arrived defective? It sounds pretty good with the optical, but I keep reading on here that the HDMI ports deliver better sound, so i really wanted to use them. I also ran the TRINNOV setup and for some reason it put all the information that should come from the center speaker to my left main speaker. When i changed to manual setup it worked fine. Have not had time to futz with that yet as i spent the last 5 hours trying to get the HDMI ports to work. I even hooked it up exactly the way it shows in the quick setup sheet and still nothing from the HDMI inputs. I also tried going just audio from my DVD player and then tried both audio and video since my player has two HDMI outputs; one for both A/V and one for just audio. The video worked but no audio. Either i am totally doing something wrong or the HDMI audio section of my recever is dead. Please send suggestions!!!
Mike
post #767 of 944 Old 06-01-13, 03:48 PM
JBrax's Avatar
Jeff
Sounds as though it may be something in the audio settings menu. I'm not familiar with the Sherwood but I would start there. Hopefully a Sherwood owner chimes in soon.
JBrax is offline
post #768 of 944 Old 06-01-13, 04:38 PM Thread Starter
tonyvdb's Avatar
Tony
Hi Mike, have you gone into the user menu and made sure that you have the corresponding HDMI input assigned to the device your using?
EDIT: also make sure that you have the HDMI audio output set to OFF in the settings menu.
Home theater:
Living room system:
tonyvdb is offline
post #769 of 944 Old 06-01-13, 04:55 PM
Yes I ave tried pretty much every assignment setting there is. I tried just setting it to the HDMI and set it to the corresponding input number and i also tried auto detect. When I used the manual HDMI setting, the display on the receiver falshed the little red HDMI detect next to the surround speaker display, so it knew there was a signal there and it automatically chose the right port, but no sound. If i change it to optical it works fine. When I tried using the port on my DVD for both A/V and then connected the HDMI output of the receiver to the TV, it passed both video and audio to the TV, but no sound from the receiver. It really has me baffeled.
post #770 of 944 Old 06-01-13, 04:59 PM Thread Starter
tonyvdb's Avatar
Tony
just to make sure you saw my edit to my post above make sure that you have the HDMI audio output set to OFF in the settings menu.
Home theater:
Living room system:
tonyvdb is offline
impressions , r972 , sherwood or newcastle
