Sherwood/Newcastle R-972 Official Thread - Page 9 - Home Theater Forum and Systems - HomeTheaterShack.com
post #81 of 944 Old 02-28-12, 09:27 AM
Re: Sherwood/Newcastle R-972 Official Thread
tonyvdb wrote: View Post
Are you certian that you have the DVR outputting Surround Or Bitstream If its in stereo that could be why its only giving you Dolby Pro Logic.
I'll check, but it must be because I get DD 5.1 when I run the HDMI directly into the receiver's HDMI #1 input.
Edit: Yes, it is set to output DD/PCM.
Like I say, when I run the DVR's HDMI cable (same one as above) to the TV, and use the TV's optical out into the 772, all I can get is DD pro logic (and a bunch of Neo, stereo, Effects, etc.) Just so strange. I suppose I can buy a splitter and run one branch to the TV and one into the 772. The real cause of all this is that the 772 doesn't allow HDMI pass thru, so I can't operate TV w/o receiver on. Also, if I hook it up w/HDMI directly into the 772, I get the DD 5.1 I want, but no sound output to the TV; must have the 772 on all the time. If I turn the HDMI to send sound out, then the TV has sound, but this cuts off all the speakers connected to the 772. Nice, huh? This is all to accomodate the Wifey.
Jim
jaymz is offline
post #82 of 944 Old 02-28-12, 11:07 AM Thread Starter
tonyvdb's Avatar
Tony
Oh, Ok I understand. If your going back out from the TV to the receiver you will only get 2.1 sound as that is a restriction put on the manufacturers by the "powers that be"
Home theater:
Living room system:
tonyvdb is offline
post #83 of 944 Old 02-28-12, 02:01 PM
Am sending inquiry to LG on this issue.
Hmmmmmmmmmmmmmmmm...well, at least that would make sense out of what I'm experiencing. The TV manual implies DD 5.1, but doesn't actually say it is ("if you want to listen to an audio source thru a 5.1 system...use the TV's audio out"). On the other hand, my LG TV downstairs (different model than the Wife's LG) outputs a DD 5.1 signal from its optical audio out to the optical in on my Marantz SR 7300, and does DD 5.1 just fine (this was only after hacking into the service menu and switching AC3 on). It looks like running the little splitter would solve the problem:
DVR HDMI/out into the splitter.
One branch of splitter directly into TV (maintains picture and TV sound). No need to turn on 772 to just watch TV.
Other branch of splitter into HDMI#1/in on 772. Will output DD 5.1 to speakers and show video on TV screen.
All the Wife has to do is turn on the 772 or switch TV HDMI inputs to watch DVD.
We'll see what happens on the R-992 when it comes tomorrow.
Thanks,
Jim
jaymz is offline
post #84 of 944 Old 02-28-12, 02:23 PM Thread Starter
tonyvdb's Avatar
Tony
If your using the TVs built in tuner then you will get 5.1 output but if your sending a signal from another source to the TV then back to the receiver it is restricted to 2.1 only.
Home theater:
Living room system:
tonyvdb is offline
post #85 of 944 Old 02-28-12, 02:30 PM
OK...I'm assuming since the only input to the TV is from the Dish #622, then all I'm getting is 2.1. That still doesn't account for the fact that the HDMI in on the 772 passes the DD 5.1 signal.
My head hurts.
Jim
jaymz is offline
post #86 of 944 Old 02-28-12, 03:16 PM Thread Starter
tonyvdb's Avatar
Tony
jaymz wrote: View Post
But thats because your using HDMI from the 772 your not going through the TV first. Only TVs are restricted not receivers.
Home theater:
Living room system:
tonyvdb is offline
post #87 of 944 Old 02-28-12, 05:14 PM
Ben
972 has sold out on a4l thanks to us
Ascend Sierra Towers RAAL | Ascend Sierra Horizon RAAL | Ascend HTM-200SE | Rythmik F15HP | Anthem MRX-520 | Sony PS3 | NEC PX-50XR5A | Meridian Explorer | OpenELEC Chromebox | Roku 3 | Samsung BDP-2550 | CalMAN HomeTheater | CalMAN C3 | HCFR | i1Display2 | MobileForge | REW | Cross Spectrum calibrated UMIK-1
eyecatcher127 is offline
post #88 of 944 Old 02-28-12, 07:24 PM Thread Starter
tonyvdb's Avatar
Tony
I wonder how many were purchased by Shack members?
Home theater:
Living room system:
tonyvdb is offline
post #89 of 944 Old 02-28-12, 07:37 PM
Jungle Jack's Avatar
Jack
Hello,
I definitely think we were out ahead of purchasing them. Compared to even larger AV Forums. Just an awesome deal. 3 Year Warranty, $1200 off MSRP, Trinnov, Reon, Preamp Outputs, and a solid Amplifier Stage. I hope Mark gets more 972's, but I am not sure if AC4L will be able to.
Cheers,
J
HT
Speakers: Martin Logan Vantage (Mains), Martin Logan Stage (Center), Martin Logan Vista (Surrounds), Martin Logan Montages (Surrounds) Hsu Research VTF-15h MK2, Martin Logan Descent i (Subwoofer)
Amplification: Aragon 8008bb, Parasound HCA-3500, Parasound HCA-2205 AT, Parasound HCA-1000a
AVR/SSP: Denon AVR-4520CI
Electronics: OPPO BDP-93
Gaming Consoles: Sony PS4, Xbox 360 S (250 gb)
Display: Panasonic TC-P65ZT60, Sony KDL-55EX500, Sony KD-34XBR910
Jungle Jack is offline
post #90 of 944 Old 02-29-12, 09:06 AM
Ben
Anyone know how to display the firmware level on the 972? I'm having some issues with HDMI handshake when I change channels on my cable box where the resolution changes, - i'll get snow. I have the upscale set to bypass and tried configuring the video and audio from auto to hdmi and vice versa. I've periodically has issues in the past with some avr's and my display but the 3008 has been the best so far, it always sync's up and I get picture. Its particularly bad with the 972. The audio delay is bad enough but tolerable, I almost don't mind the clicking now fromt he 3008. Its so fast, I'm a channel surfer. I'm not sure I could use it if I can't resolve this hdmi sync. It sounds totally different than audyssey, I just got it all setup last night, so I need some more time with it before I report on the sound. Anyone experience video issues?
impressions , r972 , sherwood or newcastle
