Sherwood/Newcastle R-972 Official Thread - Page 94 - Home Theater Forum and Systems - HomeTheaterShack.com
post #931 of 944 Old 11-04-15, 03:26 PM
wes
wes's Avatar
wes
Re: Sherwood/Newcastle R-972 Official Thread
Too bad it s discontinued Trinnov is now into the JBL Synthesis
Bowers and Wilkins 800 Diamond & 802 Diamond - B&W 802D2
wes is offline
post #932 of 944 Old 11-11-15, 02:18 PM
wes wrote: View Post
While the Synthesis processor is based on Trinnov's Altitude, the JBL does not include Trinnov's Optimizer. It will be used with JBL's ARCOS room correction.
Jeff
Stereojeff is offline
post #933 of 944 Old 02-29-16, 02:57 PM
Mike
I recently built an 18" sub and am using an Behringer iNuke 6000 DSP amp to power the sub. When I run the Trinnov setup it puts the sub at -15dB every time (any lower on the gain and the sub does not show up at all) With it running at -15dB there is just not enough signal for the amp to perform properly and it only is outputting a small fraction of its potential power.
If I turn Trinnov off and manually set the level in the receiver it works great. BTW I do have the +6dB file installed on the receiver.
Is there any kind of workaround for this where I can keep Trinnov running and still use my sub without resorting to some kind of signal booster?
Thanks!
typ44q is offline
post #934 of 944 Old 02-29-16, 06:53 PM Thread Starter
tonyvdb's Avatar
Tony
Are you certain that the +6db file has truly taken it did not go the first time I tried. Also what level do you have the sub set at on the sub it's self.
Home theater:
Living room system:
tonyvdb is offline
post #935 of 944 Old 02-29-16, 08:42 PM
Mike
tonyvdb wrote: View Post
Well when installing the +6dB file it gave the "completed" message. I seem to recall a way of checking if it was actually installed but I can not find the post with the instructions.
When running Trinnov I had the level on the sub amp at about the 9'o clock position. That was the lowest position I could use and still have Trinnov find the sub.
typ44q is offline
post #936 of 944 Old 04-26-16, 03:19 PM
All,
Looking for some guidance (Jeff, perhaps you can help). I've got two of these now.. and maybe re-posting some issues in the hopes some "new light" might be shed. My original was working absolutely fine and one day I lost all video and the ability to activate "setup" from either the front panel or the remote. Audio remained fine. Picked up a second one that was supposedly fine.. Well, that one arrived with all video and setup working, but no audio (I mean no audio not even test tones).. So I'm thinking that there has to be one good unit perhaps between these two!!! I've tried all the obvious things like reset, etc.. nothing makes a difference in either one (I did get my money back on the second and got to keep it).
Is there ANYONE out there that still works on these that perhaps could make one good one from the two? Any ideas on the second one without audio? Pulled the covers and even though I've built quite a few PCs in my time, some of these connections and how to detach/re-attach are pretty foreign.. At some point will give up the ghost on these two, but hoping for one last ray of light as I said... I've even still got the R865 I had when I stepped up to the 972!! Replaced the 972 with Denon 4311CI which is a very capable receiver with Audessey (full) but I do miss the Trinnov optimization..
Any and all thoughts are VERY welcome.. Thanks..
Jay S.
JaySinCT is offline
post #937 of 944 Old 04-26-16, 03:53 PM Thread Starter
tonyvdb's Avatar
Tony
Well, I would guess that the first one has a HDMI board failure. The second one not so sure. Have you tried doing a full reset on both receivers?
Home theater:
Living room system:
tonyvdb is offline
post #938 of 944 Old 04-26-16, 05:53 PM
Yes on the reset (unless there is another unpublished reset I'm not aware of)... I agree about the HDMI board and since the second has video was hoping I could open up the cases and swap the HDMI board over to the first. It's easy enough to get into the case, even remove the screws in back to loosen the board. The issue is the connectors.. There is a bridge connector across from the HDMI board to the board with digital audio inputs that I REALLY didn't want to force.. there are a couple of ribbon/flex cable connections where I can't seem to find an "unlock" mechanism.. I'm not a novice at inside electronics, but there are just some things inside this puppy I'm not familiar with..
Anyone ever swap an HDMI board in these receivers or know of someone who can???
Would appreciate any info (and thanks for the reply Tony).
JaySinCT is offline
post #939 of 944 Old 04-26-16, 06:55 PM Thread Starter
tonyvdb's Avatar
Tony
To reset the R-972 to factory settings:
Once in Standby Mode, press and hold down the STANDBY & MEMO/ENTER buttons simultaneously for at least 3 seconds. This will reset the unit and it will turn on automatically. If the reset was successful, you should notice that the receiver powers up at 87.5 FM .
This is how you do the reset ^^
Home theater:
Living room system:
tonyvdb is offline
post #940 of 944 Old 04-26-16, 07:00 PM
Did that many times.. unfortunately
JaySinCT is offline
impressions , r972 , sherwood or newcastle
