AVR Suggestions - Page 11 - Home Theater Forum and Systems - HomeTheaterShack.com
post #101 of 108 Old 04-30-13, 10:54 AM
tonyvdb's Avatar
Tony
Re: AVR Suggestions
Sorry I should have been more clear about Phaze, Its not reversing polarity it will do slight adjustments to correct for how the sound reaches the listening position reducing cancellation of frequencies known as Nulls. If you tweak these "distance" settings from what Audyssey does you will cancel what it thinks is best and is usually correct.
Home theater:
Living room system:
tonyvdb is offline
post #102 of 108 Old 04-30-13, 11:19 AM Thread Starter
MrAngles's Avatar
Re: AVR Suggestions
8086 wrote: View Post
Distance is measured in Feet or Meters
Delay is measured in Time: Seconds, Millisecond (ms, millionth), Nanosecond (ns, billionth).
I don't think an AVR can switch phase. I assume it's hardwared in to the AMP design. But, it is possible to audibly detect and measure a speaker running out of phase.
Reading more about it I'm seeing that you're correct, Audyssey does not adjust phase at all, so again, all it's doing is adjusting the distance/delay, which yes are measured in different terms, but from an AVR's perspective are the same thing.
Don't get me wrong, I think Audyssey is very cool, but if it's just a time saving tool for dialing in the settings that I'm used to setting manually, I don't see that as being worth more than $20 or so, and not worth all the hype it gets about the various upgraded versions that are available.
MrAngles is offline
post #103 of 108 Old 04-30-13, 11:23 AM Thread Starter
MrAngles's Avatar
Re: AVR Suggestions
tonyvdb wrote: View Post
I agree with you that the distance settings shouldn't be adjusted the actual linear feet from the listening position, the point isn't the actual physical distance of course, it's the amount of time that the sound takes to get to you. When I set the distance manually I start with a tape measure, but I fine tune it based on the response of each speaker. In the end though, it's still just a simple "distance" setting in the AVR that adjusts for delays, not magic Audyssey voodoo.
MrAngles is offline
post #104 of 108 Old 04-30-13, 11:28 AM
8086's Avatar
Guns
Re: AVR Suggestions
MrAngles wrote: View Post
A speaker running out of phase will sound a little more bass heavy. I suspect Audyssey is also compensating for that in the EQ. Fix your wiring and run the setup again.
Save the whales?
Naaa... buy local and save your dealer's showroom from permanent extinction!
8086 is offline
post #105 of 108 Old 04-30-13, 11:39 AM
tonyvdb's Avatar
Tony
Re: AVR Suggestions
Thats the wrong approach, by doing it manually with a tape measure you are bypassing alot of what Audyssey does in the Time domain. it is far more than just what you see in the user menu but to each their own you can do what you like. But I can promise that Audyssey will do a better job than you can do by ear.
Home theater:
Living room system:
tonyvdb is offline
post #106 of 108 Old 04-30-13, 11:54 AM Thread Starter
MrAngles's Avatar
Re: AVR Suggestions
I think you're misunderstanding me, I understand that the "distance" settings are not referring to physical distance, and that Audessey in effect "does it by ear" by measuring delays. I only mentioned the tape measure because that's a good place to start when doing manual calibration, not that that's what I use for my settings.
I have not adjusted Audessey's distance settings at all because they sound great. However, your wording seems to indicate that if I were to adjust them by 0.1 feet that it would erase some other mystery settings that Audyssey has going on in the background, and I just don't see that being the case.
MrAngles is offline
post #107 of 108 Old 04-30-13, 01:19 PM
tonyvdb's Avatar
Tony
Re: AVR Suggestions
It can, Audyssey takes multiple readings and should be done with the mic placed in different spots even if you only move it a foot to either side of your main listening position. You room is not perfect and reflections will make a huge difference. You cant possibly adjust by ear what Audyssey does internally. Your ears are not located in the same position so thats why there is much more going on under the hood than you think.
Home theater:
Living room system:
tonyvdb is offline
post #108 of 108 Old 04-30-13, 02:40 PM Thread Starter
MrAngles's Avatar
Re: AVR Suggestions
I guess what I'm asking is if I adjust the distance manually, what (other than the delay) is it changing, and why in world would it? Moving the mic around just gives you more points to average out to make a larger sweet spot (which is great by the way, but still nothing more than averaging numbers and making adjustments to level and distance settings).
Their website is full of stuff that is great for marketing, but I haven't found anything there yet that actually explains what Audyssey does. I know that it adjusts level, distance and sub/satellite x-over frequencies, because the AVR told me that. Nothing I found on the website even went into as much detail to explain that it does that. It's full of great statements like "MultEQ corrects the subwoofer in every seat providing precise bass reproduction." Corrects it in what way?
The most perplexing is this one: "MultEQ filters are specifically designed to address these time domain problems and concentrate most of the signal energy in the direct sound (referring to reflections as indirect sound)" Unless I'm severely misunderstanding, it's claiming that it somehow not only has control over the signal energy in reflections, but it's reducing that energy in favor of concentrating more signal energy out of the speaker itself.. In my old-school way of thinking, all amps concentrate ALL signal energy into the "direct sound."
I realize that it's all marketing doubletalk anyway, but I haven't seen anyone actually explain what Audyssey does beyond saying it "corrects" everything.
MrAngles is offline
avr , suggestions
