This is off of a Yamaha receiver, I have no clue what they do? If someone could enlighten me I would really appreciate it. I know they are EQ settings but would like to know there function. Thanks!
Here is how it works: If you set 63Hz above 0 (like +3db) it boosts the bass; set it to below 0 (like -3db) and it will reduce the bass. Same way for the other frequencies but the effects are different. Changing the 1kHz setting will boost or reduce voice and vocals. Changing the 6.3kHz and 16kHz will boost or reduce high frequencies (treble).
Ok, so its basically to fine tune each speaker. So what I get on one speaker, say right front I should apply the same settings to my left and same with the surrounds right?
Be careful though you can really screw things up if your to aggressive , I would start with little adjustments with one or two bands +1 or 2 or -1 or 2 on each band starting with just the front speakers .
Many times the reason that YAPO is incorrect with how it sounds is that it is not done correctly. You must use a tripod for the mic and it must be pointed up and placed at the listening positions at ear level.
I did just that, I screwed it to my tripod and set it on my chair at my ear hight. I just find that there is something missing from the sound once YPAO runs. And being new to all this and I have no idea how to improve on the sound coming from my speaker's. That's why I've been trying to do some research so I can make some improvements.
Ok, now i am getting a better idea of where to recommend changes.
First, are you using your TV speaker as the centre channel?
Some recommendations,
Get a large throw rug and cover the floor particularly in front of the main speakers.
If you can move the left and right front speakers out farther to the left and right as well as slightly forward.
Move the large sectional away from the rear wall at least two feet if possible.
No I have my center channel on top of my entertainment center aiming toward my LP, the only reasons at this point I don't have a through rug in my living room at this point is I have some older dogs who have trouble controlling there bodily functions in there old age. Lol and at this point my wife plays a huge factor as to what I can and can not do, if you know what I'm saying
And I also will be moving my sub to the back rear corner of the room as soon as I can order a longer cable to run through the attic, I finally decided to do a sub crawl when my wife was at work and found that to be the best spot. I'll see about moving the L and R speakers further out. Hopefully by the end of the year ill have to do that anyways because I plan on upgrading my tv to a 80" so they will have to be spread further out.
Related Threads
742.3K posts
170.9K members
Since 2006
