Peterman's HT - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
 3Likes
post #21 of 106 Old 08-26-13, 09:38 PM
tripplej's Avatar
Re: Peterman's HT
Cool. You moved those single chairs to the back. Additional seating for the second row. Looks very good. Also, more spacious in terms of moving around. Excellent work!
tripplej is offline
post #22 of 106 Old 08-26-13, 11:06 PM Thread Starter
HTS Reviewer
Peter Loeser's Avatar
tripplej wrote: View Post
Thanks Tripplej. The new seating arrangement is much better for group viewing, and will be more so once the 2nd row is elevated.
Peter Loeser is offline
post #23 of 106 Old 08-27-13, 12:54 AM
Mike0206's Avatar
Mike
Man that's a lot of speakers!!!! The one thing I wish I had was a layout like yours that enabled me to install more speakers. I may go up to 7.1 with front heights as that would really be my only feasible option but I doubt that will happen anytime soon. Nice setup Peter! Looking forward to seeing more progress pics as you move forward with your plans.
Mike0206 is offline
post #24 of 106 Old 08-27-13, 05:23 AM
Dale Rasco's Avatar
Dale Rasco
Looks great Peterman and I bet it sounds awesome!
Dale Rasco
“Opportunity is missed by most people because it is dressed in overalls and looks like work." -Thomas A. Edison
Dale Rasco and
Dale Rasco is offline
post #25 of 106 Old 08-27-13, 08:23 AM Thread Starter
HTS Reviewer
Re: Peterman's HT
Thanks guys.
Mike0206 wrote: View Post
Mike - adding front heights is worth trying. I have only tried front wides so far, but to be honest they made a much more noticeable difference than adding rear surrounds to a standard 5.1 configuration. I would expect the same to be true of front heights.
post #26 of 106 Old 10-07-13, 06:47 PM
david yurik's Avatar
david yurik
Re: Peterman's HT
how do you like the surrounds mounted to the side wall and the rear walls? if your not in a sweet spot is it still enveloping? i am guessing you send the same surround signal split to the sides and the surround back to the rear ( 7.1 ) ? thanks.
dave
david yurik is offline
post #27 of 106 Old 10-08-13, 08:03 AM
daddieo's Avatar
Daddieo
Re: Peterman's HT
Looks great! With the size of the room and the vaulted ceilings I'll bet the sound is really rich and incredible
daddieo is offline
post #28 of 106 Old 10-08-13, 08:39 PM
kevin360's Avatar
Kevin
Re: Peterman's HT
Peter Loeser wrote: View Post
Although I've almost knocked them down a few times while working on the wiring (standing up while forgetting I was crouched below one ). Only my own clumsiness to worry about
It's refreshing to read that I'm not alone in this. It's funny how we concentrate on something to the exclusion of others, until...plunk...oh, yeah. All one can do is laugh and hope it was just embarrassing.
It looks awesome so far. The drapery material appears to do a good job of blocking light...as long as they're fully closed. You're right about the rear speakers after the riser is in place - they'll need to be higher. Man, I'm familiar with that circumstance too. The good news is that, after putting up 6 of them, you're an expert at the chore now.
It's fun to watch these threads in which a 'finished' setup progresses. The initial setup looked great and comfy, too, if not ideally arranged for viewing pleasure. I do appreciate the clean look obtained from installing the gear in a closet and I like what it did for your speaker arrangement/environment. It just gets better and better!
9.1 eh, I bet that pans smoothly and convincingly (not a complaint, but...). Do you think we'll eventually have a couple dozen speakers arrayed about our rooms? I find 4.1 (no center) immersive. I imagine 9.1 is amazing.
kevin360 is offline
post #29 of 106 Old 10-08-13, 09:49 PM
Wardsweb's Avatar
Luther
Re: Peterman's HT
Looking good Peter. I need to make it back to Houston some time and check your system out.
~There are many roads to nirvana, while the ultimate goal is the destination, don't forget to enjoy the ride~
Wardsweb is offline
post #30 of 106 Old 10-10-13, 10:24 AM Thread Starter
HTS Reviewer
david yurik wrote: View Post
how do you like the surrounds mounted to the side wall and the rear walls? if your not in a sweet spot is it still enveloping? i am guessing you send the same surround signal split to the sides and the surround back to the rear ( 7.1 ) ? thanks. dave
The two sets of speakers on the side walls are my side surrounds (basically aligned with the 3-seat couch) and the front wides (located closer to the front of the room). Altogether it is capable of 9.1. My eventual goal is to add front heights and also angle the front wides toward the listening area, but for now they work nicely even with less than ideal alignment.
There is a definite sweet spot at the primary listening position which is ok for most of the time since it's usually just me using it. One of my short term goals is to work on the room acoustics and seating arrangement to improve surround effects and bass response in the non primary listening seats. That is partially why I have not finalized plans for a seating riser or purchased recliners. I would also like to experiment with dipole/bipole and possibly omnipolar surrounds at some point. All budget dependent though.
daddieo wrote: View Post
It's a pretty ideal space for the HT with lots of freedom in terms of speaker and seating arrangements. I plan to improve the acoustic treatments but for now the overall sound is quite good IMO.
kevin360 wrote: View Post
It's refreshing to read that I'm not alone in this. It's funny how we concentrate on something to the exclusion of others, until...plunk...oh, yeah. All one can do is laugh and hope it was just embarrassing. It looks awesome so far. The drapery material appears to do a good job of blocking light...as long as they're fully closed. You're right about the rear speakers after the riser is in place - they'll need to be higher. Man, I'm familiar with that circumstance too. The good news is that, after putting up 6 of them, you're an expert at the chore now. It's fun to watch these threads in which a 'finished' setup progresses. The initial setup looked great and comfy, too, if not ideally arranged for viewing pleasure. I do appreciate the clean look obtained from installing the gear in a closet and I like what it did for your speaker arrangement/environment. It just gets better and better! 9.1 eh, I bet that pans smoothly and convincingly (not a complaint, but...). Do you think we'll eventually have a couple dozen speakers arrayed about our rooms? I find 4.1 (no center) immersive. I imagine 9.1 is amazing.
Yes, my style is to do things in smaller increments (although I do enjoy following the ground-up theater builds). I do one level of improvements/upgrades and soon get ideas for more. All part of the fun of the hobby. I agree that something like a 4.1 or 5.1 system can sound extremely good with careful setup. I plan to eventually go to 11.1 at which point I don't imagine there will be much merit in adding more speakers to the room. Many believe that to be the case with 5.1, although front wides have made a very noticeable difference IMO. Either way, I enjoy tinkering and experimenting with different options.
Wardsweb wrote: View Post
Absolutely! Another Houston get together would be fun.
Thanks for all the comments guys. I'm still cleaning up some wiring, so I'll have a few more pics to post soon. I also have a receiver review in progress so that's taking priority over some of the changes to the room for now.
ht , peterman
