| Home Theater Seating and Accessories Wiring For SeatingDiscuss Wiring For Seating in the Home Theater Installation and Systems forum; Wiring For Seating Hey guys,
I'm wiring my riser for my theater chairs. I'm thinking I can place 1 double wide box in ... |
Views: 770 - Replies: 6
| Wiring For Seating Hey guys, I'm wiring my riser for my theater chairs. I'm thinking I can place 1 double wide box in the middle of the riser to plug in the rear row. I'm thinking the cords should be long enough for each side chair to reach under the middle chair, but I wanted to make sure. Anyone know just how long the cords are. I really hope I can hide them like this. | ||||
| | #2 | ||||
| re: Wiring For Seating Tonto, Yes, that is the way to do it. Usually the power cords are 6-8 foot long, and you will be able to plug them all in one place. Note: Add a couple outlets on the front of the riser as well, so you can plug the front row seats from their backs to these outlets. Roman ---------------------------- Ultimate Home Entertainment www.rtheaters.com sales@rtheaters.com 732.617.2348 | ||||
| | #3 | ||||
| Re: Wiring For Seating Thanks Roman, It occurred to me today that I didn't ask about the front row. Now that I know the cords will reach, I'll do it like that, two 4 outlet receptacles. I noticed you seem to know a bit about buttkickers. I don't plan on using them...but, if I was to need them later , what king of pre-wire do I need to install before I nail down the flooring & carpet. I will have 2 rows of 3 connected chairs.Last edited by Tonto; 07-25-08 at 09:06 PM.. | ||||
| | #4 | ||||
| Re: Wiring For Seating If you don't mind ... What are you installing??? ![]() I think is not the LFE kit, Right??? ... that comes with one amp only ... I'm assuming that your chairs have the built in shaker ![]() Anyways, wherever it is ... just be prepared to be during movies ... a shaker adds that extra effect ![]() | ||||
| | #5 | ||||
| Re: Wiring For Seating Hey Sal, I have done no research on buttkickers, don't know what the LFE kit is or what I would need . I just know I won't be pulling my riser apart to rewire. Now mind you I'm building a fine theater (SVS MTS 7.1 with the PB 13U), I just hate that upgrade demon ...I know he's coming . Maybe you could explain what they entail. | ||||
| | #6 | |||||||
| Re: Wiring For Seating Quote:
![]() Quote:
I'm using one on each row of three seats, but two will work better ![]() There's other shackers that you install on every chair (that's what I thought you were doing ) but I read that they don't compare to the LFE kit ![]() Quote:
system ... I'm sure you will enjoy it until you get the upgraditis ![]() | |||||||
| | #7 | ||||
| Re: Wiring For Seating tonto, If you want to prewire for the buttkickers, run at lease one 12 gauge speaker wire from the location of your equipment to the top of the platform and one to the front of it. Each run will allow connecting up to 4 buttkickers. Of course it all depends on what kind of seating you are going to be using. I would like to tell you about the new Private Collection Seating that we a currently offering and taking pre-orders. These will have a very unique wireless buttkicker package (2 mini buttkickers w/power amplifier) built into the chair. You will also have a RC that will allow you to individually control each recliner. Check this out: www.rtheaters.com/PCS In this case you need no prewiring done. Everything is self contained. Price wise it is very competitive and quite less expensive solution comparing to for example Berkline set up. I hope this helps. Roman ---------------------------- Ultimate Home Entertainment www.rtheaters.com sales@rtheaters.com 732.617.2348 | ||||
