| Home Theater Seating and Accessories How many theater recliners in a 13' wide roomDiscuss How many theater recliners in a 13' wide room in the Home Theater Installation and Systems forum; How many theater recliners in a 13' wide room I'm in the stud phase of my basement and dedicated home theater room. My home theater will be 13' wide ... |
Views: 857 - Replies: 6
| How many theater recliners in a 13' wide room I'm in the stud phase of my basement and dedicated home theater room. My home theater will be 13' wide and 19' long. Does anyone know if I will be able to get 4 theater recliners across in 1 row with room on either side to get around? | ||||
| | #2 | ||||
| Re: How many theater recliners in a 13' wide room A handy tool is the Theater Planner on Berkline's website: http://www.berkline.com/ht/planner.html Berkline has a slimline arm style that saves a little width. I am sure that other manufacturers do as well. | ||||
| | #3 | ||||
| Re: How many theater recliners in a 13' wide room Scott, Where in PA are you? We have a warehouse in Bridgewater, NJ with many Berkline and Private Collection Seating recliners on the floor. You are welcome to come and try them out. There are some other factors that need to be taken into consideration in addition to the room dimensions. These are your height, location of the entrance into the room, number of desired isles, etc, etc, etc... Give me a call at (732) 617-2348 and I will tell you all about these seats and help you choose the right one. Roman ---------------------------- Ultimate Home Entertainment www.rtheaters.com sales@rtheaters.com 732.617.2348 | ||||
| | #5 | ||||
| Re: How many theater recliners in a 13' wide room Well It's good to know we should have a problem fitting them in.. Thanks for the replies. I'm a little time away from buying chairs... Roman, you are about 2 hours away from me, but I may take you up on coming over as I get closer. I'm 6' 4'' and my boys are up there to so we will need some chairs to fit us... It's all confusing... You have a room, but then everything seems to depend on each other... Projector, screen size, riser height, chair placement, speaker placement, etc... I'm concentrating on finishing the basement other than the home theater first, but I need to do enough in the home theater (studs, soffits, electric, etc..) | ||||
| | #6 | ||||
| Re: How many theater recliners in a 13' wide room scyce, You may want to check out the Berkline 12003 group. It is imported version of the 45094 group and it will cost much, much less. I would recommend you to plan ahead and check the chairs as soon as you can. It may take some time to get the chairs you need... Roman ---------------------------- Ultimate Home Entertainment www.rtheaters.com sales@rtheaters.com 732.617.2348 | ||||
| | #7 | ||||
| Re: How many theater recliners in a 13' wide room Good advice here. I also think you should have no problem. My room is only 13' wide and I found chairs that fit fine. Here is a picture of my setup. Good luck. ![]() | ||||
