| Home Theater Seating and Accessories Bass Shaker? Discuss Bass Shaker? in the Home Theater Installation | Systems forum; Bass Shaker? We need to know the Xmax of the subs, whether it's 8 mm or 18 mm will determine what can ... |
Views: 2892 - Replies: 64
| | #21 | ||||
| Re: Bass Shaker? We need to know the Xmax of the subs, whether it's 8 mm or 18 mm will determine what can be done with them. We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | ||||
| | #22 | ||||
| Re: Bass Shaker? Sonotube suppliers (called formatube or form tube here in Aus I think) Genuine Sonotube (I have been informed): Bower & Lever or Hudson's hardware (Bower & Lever were cheaper though). Bower & Lever 37 Victoria St Windsor Brisbane Ph:3857-2018 (Hudson's Hardware dearer - quoted $355 for 762 x 3metre length) Open: 6am-4.30pm weekdays 6.30am-11am Saturdays About 13mm thick walls Internal diameters: 610mm x 3 metre = $210.61 610mm x 6 metre = $285.51 762mm x 3metre = $314.92 Delivery = $44 These prices were valid about this time last year - probably dearer now ![]() Hope that helps? By the way - I have 4 jaycar bass shakers (2 x 2 units wired in series) and use and old NAD amp to power them (sacrilege I know). Works very well though and is especially popular with the neighbours. Sam HTPC - Xeon 2.66 ghz E7300|PowerDVD 8 ultra|Theatertek 2.6|7600gt nvidia|X-mystique DD live soundcard|NAD T743 receiver|BFDPro DSP1124P|B&W DM602 S3 x2 fronts|LCR600 S3 center|DM601 S2 rears|DIY 2 x Mach 5 Audio IXL-18 sonosubs 365ltr 15hz|Behringer EP2500 sub amp|Mitsubishi HC1100 projector | ||||
| | #23 | ||||
| Re: Bass Shaker? As for amps for the sub - can't go past the Berhinger EP1500 or EP2500 for value for money - DJ-warehouse and/or New-Media are probably the cheapest suppliers in Aus at the moment. HTPC - Xeon 2.66 ghz E7300|PowerDVD 8 ultra|Theatertek 2.6|7600gt nvidia|X-mystique DD live soundcard|NAD T743 receiver|BFDPro DSP1124P|B&W DM602 S3 x2 fronts|LCR600 S3 center|DM601 S2 rears|DIY 2 x Mach 5 Audio IXL-18 sonosubs 365ltr 15hz|Behringer EP2500 sub amp|Mitsubishi HC1100 projector | ||||
| | #26 | |||||
| Re: Bass Shaker? Quote:
We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | |||||
| | #27 | ||||
| Re: Bass Shaker? thats ok Mike thanks anyway i only paid $60 for them inc shipping. I like the Mach 5 Audio IXL 18" subwoofer or 12" subwoofer what will give me the best bass for movies? and what size sonotube would you recomend for both applications. Cheers Troy | ||||
| | #28 | ||||
| Re: Bass Shaker? How big is the room and is it open to other areas? Would a 13 cu.ft. sonotube be acceptable if you go with a IXL-18? We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | ||||
| | #29 | ||||
| Re: Bass Shaker? I have a dedicated home theatre room with one door 6 metres long and 5 mertres wide. I am going to put home theatre velvet curtains around the room with no shine or lustre im leaning towards matt black and the ceiling will be painted dark grey. 13 cu.ft is too big. the ED subs look very solid with great TPS and xmax now i dont know so can you please advise me of the better sub i will stay with 12" or 15" if i can get away with it. | ||||
| | #30 | ||||
| Re: Bass Shaker? What's the biggest size that would be acceptable? Are you willing to build a box or do you want to use sonotubes? What's your budget for subs and amp? We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | ||||
