Buttkicker experience - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Equipment Reviews.
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Seating and Accessories
Discuss Buttkicker experience in the Home Theater Installation and Systems forum; Buttkicker experience Hello All, I need opinions on how many Buttkickers to place in a 20x13x9 dedicated, if any. My plan is ...
Old 06-19-07, 02:21 PM   #1 (Link)
Alias: Nick
Loc: Aiken SC
User: #6642
  NickS is offline
Hello All,
I need opinions on how many Buttkickers to place in a 20x13x9 dedicated, if any. My plan is to mount two LFE’s (using their amp), in the floor joists, under the house, directly under the front couch. Is this enough for that seating position? Are these just a gimmick or do they replicate an actual feeling of bass? Will I feel anything while using dual svs 20-39’s? Best place for a deal? Thanks for any help everyone.
Old 06-19-07, 02:31 PM   #2 (Link)
Design and Acoustics Moderator
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
Re: Buttkicker experience
If you want to do them, I'd recommend putting them in the framing of the couch. Trying to vibrate a whole floor isn't going to be easy and will cause all kinds of resonances.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 06-19-07, 02:32 PM   #3 (Link)
Loc: L.A. (Lower Bama)
I'm gonna move this over to the Ultimate Home Entertainment forum and I would suggest contacting Roman for a deal on Buttkicker gear. I don't believe anyone will beat his prices... He should also be able to assist you in how many to order.
Old 06-19-07, 02:47 PM   #4 (Link)
Alias: Nick
Loc: Aiken SC
User: #6642
  NickS is offline
Bryan,
I should have been clearer that the couch is more of a futon and running the cables to the seating would mean putting a small hole in the middle of the room through the floor to run the cables back to the amp. Otherwise the frame of a couch would probably be a better location since I could just turn down the amp if it were too powerful. I've read where you can put them in floor joists but I agree with you in resonances and their ability to really move the floor is questionable.
Old 06-19-07, 08:33 PM   #5 (Link)
RSH
Ultimate Rep
Alias: Roman
Loc: NJ
User: #1787
  RSH is offline
Nick,
I would not mount the buttkickers to the floor joists. This will attempt to shake the whole house, and the effect will not be great at all. It will also disturb a lot of surroundings and create resonance like Bryan said.
You have several options:
1. Mount the buttkickers to the frame of the couch, wire the amp to the buttkickers, and if you do not want/cannot run the wires to the couch, put the amp next to it and use wireless connection from the sub out on your receiver/peamp-processor to the buttkicker amplifier.
2. According to your dimensions you have enough room for two rows of seating. You can build a platform and set it on the kinetic isolators to decouple it from the floor. Then you can install the buttkickers into the platform.
3. Purchase the HT seating with the buttkickers installed in each chair - this will give you the most effective, precise localized effect.
I hope this helps.
Roman
www.rtheaters.com
sales@rtheaters.com
732.617.2348
Old 06-21-07, 09:44 AM   #6 (Link)
Alias: Nick
Loc: Aiken SC
User: #6642
  NickS is offline
Roman,
Thanks for the info. My best bet is to save a little more and buy the seating. I've needed new seating for a while just wasn't sure what to get. I like the berkline but it may be more cost effective for me to buy seating and attach the kickers myself. Thanks again.
Old 06-21-07, 09:51 AM   #7 (Link)
RSH
Ultimate Rep
Alias: Roman
Loc: NJ
User: #1787
  RSH is offline
Nick,
Check the special I am running right now for the HTS forum members on the Berkline 078 recliners - only $425 per manual recliner + shipping. These are one of the most comfortable seats that the Berkline make in high quality - group 3 leather/vinyl combo. And this is below dealers cost deal...
I would recommend getting them with power recline and buttkicker already installed. Yes, you can install the buttkickers yourself at later point, but the feedback I am getting from the customer when they do that - " I should have just ordered them with the buttkickers installed and be done with it".
Roman
www.rtheaters.com
sales@rtheaters.com
732.617.2348
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Seating and Accessories »
Similar Threads
Any experience with the Velodyne SMS-1 Huck Home Audio Subwoofers 33 02-19-08 09:48 PM
Subwoofer DIYers, share your experience! Blaser DIY Subwoofers 4 05-08-07 07:37 PM
Describe the Buttkicker experience... Owen Bartley Home Theater Seating and Accessories 8 10-24-06 09:40 AM
Any one with experience with Hegel? kentsvanaasen HiFi Audio Components 5 09-15-06 06:25 AM
Office Space iPod Experience Wayde Home Theater, Audio and Video News 4 08-28-06 01:05 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228
