Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Seating and Accessories
Sconces needed
Discuss Sconces needed in the Home Theater Installation and Systems forum; Sconces needed Looking for some nice contemporary style sconces that will not cost a arm and leg for my HT room. Any ...
Views: 2137 - Replies: 16
Old 12-12-07, 09:29 PM   #1
Alias: Rick
Loc: Green Bay
User: #6523
  rick12667 is offline
Sconces needed
Looking for some nice contemporary style sconces that will not cost a arm and leg for my HT room. Any good sights to look at?
Thanks Rick
Old 12-12-07, 10:34 PM   #2
RSH
Ultimate Home Ent.
Alias: Roman
Loc: NJ
User: #1787
  RSH is offline
Re: Sconces needed
What is your price range?
Roman
www.rtheaters.com
sales@rtheaters.com
732.617.2348
Old 12-13-07, 09:54 AM   #3
Alias: Rick
Loc: Green Bay
User: #6523
Re: Sconces needed
I would like to stay under $50 for sure per unit
Old 12-14-07, 11:12 AM   #4
RSH
Ultimate Home Ent.
Alias: Roman
Loc: NJ
User: #1787
  RSH is offline
Re: Sconces needed
Sorry, I am not aware of anything decent in this price range...
Roman
www.rtheaters.com
sales@rtheaters.com
732.617.2348
Old 12-15-07, 02:15 PM   #5
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is online now
Re: Sconces needed
Go to your nearest Home Depot they sometimes have clearance specials on all sorts of lighting fixtures. You can also check out Ikea if you have one in your area thats where I got my Sconces from.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 12-15-07, 09:35 PM   #6
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
Re: Sconces needed
If you want something really inexpensive, I found these ceramic sconces at Ace Hardware for $20-22 each. This is an old pic, but you get the idea. I painted them.
Old 03-24-08, 08:26 PM   #7
mlscanlon
Inactive
Alias:
User: #
Posts: n/a
Re: Sconces needed
We just recently purchased our sconces at Lowes for under $17.00 each. They are your classic movie theater sconces and we have had many compliments on them.
Old 03-26-08, 04:23 PM   #8
Alias: Restless
Loc: Alabama
User: #18168
Since: Mar 2008
  Restless is offline
Re: Sconces needed
We also just bought sconces at Lowe's. We were so happy with them, that we stopped just last night to get one more for our room rebuild.
Old 04-08-08, 03:42 PM   #9
Alias: Zip
MatrixDweller's Avatar
Loc: Canada
User: #10408
Since: Jul 2007
  MatrixDweller is offline
Re: Sconces needed
I picked up 4 sconces from Walmart on clearance for $9 each. They were regularly $30.
Old 04-24-08, 12:41 PM   #10
Alias: Quenten
Loc: Tallahassee, Florida
User: #9895
Since: Jun 2007
  Tonto is offline
Re: Sconces needed
Got mine @ Lowes as well, couldn't beat the price & they look nice. One thing to consider...replace your switch with a remote control dimer. You can program your remote to dim the lighting as the projector Q's up the movie. Way cool!
Old 10-11-08, 05:45 PM   #11
Alias: John
Loc: SE, Tn.
User: #20492
Since: May 2008
  77sfan is offline
Re: Sconces needed
OK guys, hows about some photos of your bargin sconce finds
Seriously, that would help us all.
One guys' "not good enough" is another's "WOW, that's wonderful!"
I love a bargin!
John
Old 10-11-08, 06:37 PM   #12
Alias: Zip
Loc: Canada
User: #10408
Since: Jul 2007
Re: Sconces needed
Here's a pic of mine on one side of the wall. They were pretty cheap and I will eventually upgrade them to something a little more theater like. $36 for 4 sconces I can't complain especially when trying to keep my theater build's budget down (built from scratch).
One thing I learned was that regular incandescent bulbs tend to hum when dimmed (I have a Lutron GrafikEye). Using rough service bulbs or some ceiling fan bulbs fixes that. The filament and its posts are thicker and more resistant to vibration.
Old 06-24-09, 12:17 PM   #13
Alias: Spankey
User: #22387
Since: Jun 2008
  Spankey is offline
Re: Sconces needed
Not bad. What is the usual price of sconces? Are there brands that are specifically made for HT? (style wise).
Old 06-24-09, 12:47 PM   #14
Alias: Zip
Loc: Canada
User: #10408
Since: Jul 2007
Re: Sconces needed
If you check out Home Depot or Lowes they run anywhere from $20 up to $80 or more depending on how fancy they are. The ones that I got from Wall Mart were marked down more than half price.
The do make some HT specific sconces that look like movie reels or popcorn containers, etc. You pay a bit more for them and typically have to order them off the internet.
There are literally thousands of styles to choose from in sconces. It all boils down to personal preference. The following link shows quite a few examples.
http://www.eco-lights.com/wall-light...ll-sconces.php
Old 06-24-09, 01:39 PM   #15
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Re: Sconces needed
Ikea Has lots of inexpensive wall sconces that work great for theater rooms.
Home theater:
Two Channel system:
My Webpage
Old 06-24-09, 01:43 PM   #16
Owner
  Sonnie is offline
Re: Sconces needed
Here are my latest ones... they are about $30-35 each I believe. Not a great bargain, but less than a LOT of the ones I have seen.
I went to www.thefind.com and put in "sconces" (example - then enter your price range to narrow the search more) and man did I ever get a bus load of offers... I think there were thousands and several of the same ones with varying prices depending on the store.
Old 06-24-09, 01:44 PM   #17
Alias: Spankey
User: #22387
Since: Jun 2008
  Spankey is offline
Re: Sconces needed
Sonnie, I dig those. Going to take a look around that site.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Seating and Accessories »
