- How To Find Hours Of Sony DLP Lamp???
- Ayreonaut finally goes HD
- Best Plasma, Pio, Panny...?
- Panasonic rear projection question
- LCD versus Plasma versus DLP
- Sumsung rear DLP w/LED questions?
- Samsung HLT6187SAX 61" Slim LED Engine 1080p DLP HDTV or what?
- Best bang for the buck 50-60" DLP 1080p?
- Video Calibration Q&A
- Colorimeter for both PC screen and projector screen?
- Need help getting an HD picture on my TV
- What's a Mitsubishi 52725 worth?
- Back 2.5" of DLP RPTV -- Not Supported ??
- Setting White Level (picture/contrast)
- Panasonic TH-58PZ700
- Aftermarket bulbs as good as OEM bulbs?
- Mitsubishi WD-65731
- Picture Quality
- Front Projection 1080p LCD's
- Is Panasonic TH-58PE75U 1080p or not?!?!?
- LG 37LB1R service menu
- Component input - picture artifacts
- bad picture
- 14 bit video
- CalMAN Pattern Generator test w/nvidia GeForce8400M G
- 1080i vs. 1080p
- my experience with lamps-dlp.com
- Do LCD RPTV Bulbs Go Bad?
- Flat panel assistance...
- anyone use lamps-dlp.com?
- quick poll
- Need an upgrade
- scaler cord question. Maybe I would be able to watch HD-DVD quality
- Replace bulb even though it's not burnt out?
- Mitsubishi Lifespan
- CalMAN v3 beta
- 15 Hz, 102 dB and . . a CRT
- Would like to upgrade my display
- Link request
- 20" LCD Monitor for Oppo DVD setup?
- Chief Automated Flat-Panel Speaker Panel
- Wife Demands New Display -- Please Help!
- Video Calibration Tools
- Video Calibration
- Question about cooling down procedure for Toshiba??????
- TV in bed...
- LCD mount
- Can I play XBox on my Toshiba DLP?
- Upconversion ?????
- The Ultimate Accessory
- Help with new light engine????????
- Are the new Samsung LED DLP's any good?
- HDTV vs Front Projectors with Screens
- Samsung DLP lag with Guitar Hero???
- Anybody using a Sony XS955 with a HD DVD player
- Mitsubishi 2007-2008 DLP RP sets
- Anyone here ever had a professional-model display?
- cheap vid scaler, any good?
- Comcast & Sharp 37" LCD with 1080P
- 40-ish display recommendations
- Samsung DLP bulb replacement
- My new 42'' LCD.
- Phillips ambilight 37 inch LCD
- TV making buzzing sound?????????
- Flat Screen Recommendations
- Video Scaler Question (Long)
- Advise on Heat Build up inside TV ....
- Where to buy a DLP Lamp ????????
- Sony KDS-55A200 55" SXRD 1080p and PS3- an initial review
- Upscaling- Let the TV do it or a Scaler/High Def DVD player?
- Help with No Power ???????????
- SD on an HD LCD
- TV signal booster recommendation?
- Do I need a scaler?
- 37"-42" with Faroudja DCDi processing
