PDA
View Full Version : Home Theater Components
Pages : [1] 2 3 4 5 6
  1. "Sub" amplifiers for full range use
  2. "Crank it up" - Cheap AVR's vs Headroom
  3. different reciever's overall sound quality
  4. Nakamichi Question, CA-1 pre/pro
  5. Where does the decoding happen? So confused :-(
  6. Subwoofer amp tweak
  7. NAD M15 vs AVR4308 vs Audyssey Sound EQ
  8. What Receiver Mode Do You Watch DVDs with Mono Soundtracks In?
  9. Could HDMI Cables Affect PCM Output?
  10. Display Analyzer
  11. Integra/Onkyo Surround modes w/HD DVR
  12. Yamaha RX-V361 Question
  13. Pre/Pro vs Receiver
  14. Denon 1506 AVR
  15. Modern power supply operation
  16. Another Receiver Advice Inquiry!
  17. Is there a real benefit to preamps or two channel amps in HT?
  18. Emotiva
  19. Searching for a receiver
  20. NAD T743 receiver sub channel clipping - need upgrade?
  21. memory problem HK AVR435
  22. setting speakers
  23. Lexicon RT-10 VS Oppo DV983H...
  24. Cheapest current receiver with modern room correction
  25. How to connect sub to Yamaha V661 w/busted low level input ??
  26. onkyo vs. marantz
  27. Bose, VS-2 HDMI problem
  28. Onkyo 702 vs. Denon 3300
  29. installing amp
  30. 19" Rack Mountable DVD / VHS / etc... ???
  31. Problem with one of my recievers
  32. Should I just upgrade my AVR or get an amp and AVR?
  33. Criticisms and Comments of Integra DTR-7.8 AV Receiver
  34. Need Help with an Onkyo 805
  35. Anatomy Of Rotel Components
  36. Are there any Pioneer receiver owners here?
  37. Yamaha HTR-6160
  38. Help Onkyo 805 Or Pioneer Vsx90txv
  39. audyssey worth it?
  40. Speaker wire question?
  41. Idle Power
  42. Onkyo 605 Or 805?
  43. voice channel
  44. Reviews on Samsung LNT5781F flat screen?
  45. Question about multiple speaker setup
  46. Worth getting into 2001 model receiver like this one?
  47. Yamaha Announces New Line of Home Theater Receivers
  48. I'm looking for suggestions please.
  49. Denon 1602 with Bluray source
  50. Yamaha RSXV1700 vs Onkyo 805 vs Onkyo 705
  51. HDMI and Audio Issue
  52. HK wattage ratings
  53. True HD receiver needed?
  54. Onkyo 605 or 705?
  55. Software upgrade goes well on HK AVR-635 Receiver
  56. Emotiva XPA-2 / XPA-5
  57. Which Amp????
  58. HK avr 35
  59. Harman Kardon AVR 247 and non-HD resolutions
  60. Marantz 7002 and 8002
  61. Denon 3808 vs Yamaha RX-V1800
  62. New Oppo DV-983H is here!
  63. Just got a SI T Amp
  64. Will upgrading to a 7.1 surround system be worth the install?
  65. Hooked up my new amp today.....
  66. denon reciever with pro amp
  67. Eye Candy
  68. 2 HDMI Outputs
  69. Thinking about Audyssey -- experiences?
  70. Outlaw 7075 + Vienna bach & Waltz = ?
  71. Yamaha RX-V1800 initial review
  72. Which reciever Onkyo TX-SR875 or Denon 3808ci
  73. Blue volume ring on Harmon Kardon is dead.
  74. Audyssey problems in Onkyo 805...
  75. Which is better speaker level or line level input to sub?
