PDA
View Full Version : BFD | Electronic Equalization Devices
Pages : 1 2 [3] 4 5 6 7
  1. What now ?
  2. MIDI Cable ??
  3. Consensus on BFD+Audyssey for house curve?
  4. BFD 1124P and SMS-1 for Stereo Subs
  5. FBQ delay/sync with mains?
  6. DCX-2496 and a DSP-1124 is this a match made in heaven?
  7. New to BFD, and to HT Shack!
  8. Will this midi device work for REW and BFD?
  9. BFD for Karaoke
  10. Sub hum with BFD off or on
  11. Behringer dsp1100p - still useful??
  12. Multiple BFQ2496 patched together?
  13. Alternative to BFD, FBQ, DEQ, Anti-Mode, SMS-1
  14. Can someone PLEASE help me understand the BFD?
  15. BFD for Full Range EQ?
  16. Newbie Question about BFD
  17. NOOB to sub-mgmt. Literally.
  18. BFD front panel weirdness
  19. Where to buy FBQ 2496
  20. Combining 1124P & DEQ2496
  21. Alternative to DEQ2496
  22. BFD 1124 How to apply filters without MIDI
  23. occasionally bad connection
  24. BFD firmware
  25. Sub EQ / room calibration equipment question
  26. BFD is Humming
  27. Behringer Date Code
  28. BFD for Buttkicker
  29. emotiva to fbq
  30. Preamp: Digital in + digital out "tape loop?"
  31. Need help w/two BFD issues
  32. BFD Sub Pop/Thump While Idle
  33. Hum Problem
  34. Dynamic EQ recommendations
  35. FBQ2496 Set up Help
  36. Which EQ for joz???
  37. Sub Eq
  38. BFD needed with SVS PB13-Ultra???
  39. BFD Alternatives: FBQ, SMS-1, DCX and more
  40. Will BFD increase input sensitivty similar to what a CleanBox does?
  41. Obvious nooby question
  42. Behringer DCX2496 ?
  43. Which product will do the magic?
  44. Testing the DSpeaker Anti-Mode 8033
  45. Epik Knight
  46. dcx 2496 LCR + sub
  47. How much headroom is needed?
  48. DSP8024 and then?
  49. BFD HUM
  50. BFD with 2 subs - question
  51. Newbie: BFD not turning on
  52. Suggestions for use in 2ch audio w/o pre/pro
  53. Problem with FBQ2496
  54. JBL car sub driver, in old DIY cabinet...
  55. Does calibration really make a difference?
  56. Tweaking FBQ2496 ?
  57. BFD RCA to TRS vs XLR input levels different
  58. Behringer FBQ2496 manual adjustment with RTA
  59. Is it ok to apply a gain of 6db or higher
  60. PEQ software
  61. How wide is a BFD behind the front panel tabs?
  62. My solution for the BFD hum/noise or "My custom $10.00 subwoofer cable."
  63. feedback destroyer causing buzz
  64. FBQ2496 versus DEQ2496
  65. help a newbie out
  66. I'm about to order a BFD, but look at this...
  67. No output to sub with 1124
  68. DSP1124P freezes/switch doesnt work. Need help with DVD
  69. Subs dial-in for HT and 2 Channel Audio?
  70. REW Setup and Connection Basics
  71. OK I have a Ultra Curve DSP8024, a Mic, SPL and all gear now what?
  72. Which model of BFD to buy
  73. EQing my main sub (HSU VTF3 MKII) and a mid-bass module (hsu mbm-12)
  74. FBQ 2496 Dj setup help.
  75. FBQ2495 & REW couple of questions
