PDA
View Full Version : BFD | Electronic Equalization Devices
Pages : 1 2 3 [4] 5 6 7
  1. hum elimination?
  2. BFD fbq2496 with two subs
  3. Input conversion?
  4. What does a beginner have to purchase to start using BFD?
  5. BFD keeps applying more filters ?
  6. FBQ2496 and leds..
  7. Bfd Input Level
  8. FBQ2496 not responding to midi
  9. Fbq2496....how loud is your hum?
  10. Bfd , Ecm8000 , B Mic800 pre-amp , G-star 5.1 soundcard whats next please.
  11. Recommend Me A Usb Sound Card
  12. House Curve Or Filter Change?
  13. Freq Boost Question
  14. FBQ2496 REW Software issue
  15. BFD Level Input Setup
  16. BFD Connectivity
  17. Defective BFD, or Input Level too low?
  18. Initial measurements...opinions requested
  19. Can the BFD be used to limit max output?
  20. FBQ 2496 output is flat after power off/on
  21. When Do I play with Phase?
  22. Bfd frequency bandwidth
  23. Which EQ to buy/use for IB cal
  24. 1124P Reset?
  25. Best Connections for DEQ2496?
  26. Can I use the BFD this way?
  27. BFD Guide Question?
  28. Got an idea, and have a question for BFD users
  29. FBQ2496 or DSP1124P gain?
  30. Why BFD
  31. Should I have bought the FBQ2496
  32. No Input Levels AT ALL!
  33. does anyone use the Hd 400 to get rid of hum
  34. BFD At Last!!!
  35. No output from FBQ2496
  36. Nubee need help w/ eq filters
  37. I want one too.
  38. BFD vs. Bass Traps & best position for target curve
  39. beginner questions...high pitch tone on BFD
  40. A couple of BFD questions...
  41. Mic Positioning
  42. Samson D3500
  43. Help with BFD (newbie here)
  44. Test Tones
  45. Typical Hookups
  46. DSP1124p& SACD
  47. BFD as a low pass
  48. BFD showed up today, DOA
  49. How important is setting the absolute maximum peak input level?
  50. RCA to 1/4 cables for hookup
  51. Could my BFD settings have destroyed my sub's amplifier?
  52. Can BFD be used on recording studio monitors?
  53. Why is high level to cure dips a bad thing?
  54. sub delay
  55. Difference between +4db vs -10db input level
  56. Behringer noise
  57. EQ what?
  58. does number of filters used effect audio quality?
  59. Level on bfd too low ?
  60. My first session with my new FBQ2496 - Results inside...
  61. Car audio EQ
  62. Free cd in 1 Hz increments from 10hz up
  63. Why do you guys love these so much???
  64. Signal doesn't go through BFD
  65. Microphone preamp in BFD?
  66. DSP1124P performance???
  67. Will a USB Sound Card adapter work?
  68. Do most HT receivers have parametric eq?
  69. Elemental Designs eQ.2
  70. Preventing BFD overload
  71. Dsp1124p
  72. Behringer 1124p vs. FBQ2496
  73. New setup and first round with BFD - "feedback" please?
  74. Confusion W/ RS Correction Values
  75. DCX2496 vs. DEQ2496
