- New BFDer with basic problem
- Can I control the absolute level with the BFD??
- BFD at guitar center?
- BFD output hum -not ground loop associated
- How does the BFD compare to the Velodyne SMS-1?
- BFD - Is it worth it?
- A Thank you to everyone...
- BFDs on backorder everywhere
- Bass Management System Development
- "Upgrade" Revised Firmware V1.4 for the DSP1124P
- To buy or not to buy...1124P vs 2496???
- Updating DSP1124 v 1.3 to 1.4 Pictures
- BFD-like device for mains and surrounds?
- Can I still use my receivers PEQ for the mains and surrounds?
- Will my new BFD DSP1124P definitely not work with MIDI?
- Can I put my BFD at the sub?
- Newbie question for SPL advice & 1124ps
- which feq 2496 or 1124
- Input Level -4/-5, ok?
- FBQ 2496 vs DSP 1124P HELP PLS
- DSP1124P gain? M-Audio Uno gotcha
- Sub 20Hz EQ
- DSP 1124P. No more available in Germany!
- Phase problem? Will an EQ help?
- Stupid BFD question - the in/out button
- Setting up two subwoofers with BFD
- XLR or 1/4" to RCA Cables
- Max Sub Input
- DEQ2496 best choice for room acoustics "fixing" used for speakers and sub?
- Which Behringer unit?
- BFD Connection Question
- Any special considerations when correcting low end of full range signel??
- Revised Firmware V1.4 for the DSP1124P with V1.3 ONLY!
- HELP please 1124p
- Can't get the BFD input levels up high enough
- Basic BFD hookup/wiring questions- what cables do I need, etc?
- Running into headroom problems with my BFD
- BFD DSP1124P FIlter Chains
- A Question about Boosting
- On BFD 1124- Any way of adjusting below 20hz?
- Two different subs co-located- same frequncy response - possible?
- BFD in the studio
- Broken BFD
- 2496 vs. 1124
- BFD for dummies...
- Eliminated the dreaded BFD hum for free
- Bleedthrough from engine L to engine R?
- BFD without MIDI
- ? on Setting the input level on BFD
- BFD makes my sub amp pop, any solutions?
- Cheater Plugs OK with GFCI?
- DSP1124P roll off?
- New BFD... will you buy one?
- Operating level button - ok to leave in "OUT" position (+4dBu STUDIO) setting?
- BFD 1124 & 24 filters: howto?
- Is the 1124 sold in the U.S. capable of running on 230/240v?
- Alternative Bass EQ Method
- BFD 1124P Owners... the MIDI issue...
- My Custom DIY XLR to RCA cables
- Problem with BFQ2496
- FBQ 2496 better performing then DSP1124?
- BFD Outputs Rumbling noise to Subwoofer
- Noise or HUM from BFD
- House curve...boost filter...what's the difference?
- What solution do folks use for the dreaded BFD hum?
- DEQ 2496
- Ground loop hum?
- Secrets of Home Theater Onix Rocket R-DES Equalizer review
- What cables and where to buy?
- We have a September Winner!
- Strange input signal situation with BFD
- BFD Questions! House Curve Questions!
- H/K and BFD question
- Question on building an RCA to 1/4 inch cable for the BFD?
- More info on BFD pro midi interface issues?
