- Affordable multichannel DSP-based equalizer?
- Reckhorn B2 Bass Management Device
- Is the DCX2496 My Best Solution?
- dvd to behr dcx 2496 to surround amp??
- clipping/level meters
- FBQ2496 Power on
- FBQ 2496 Owners - Help With Status Display
- DCX : How to create an LT? - Is it the right device?
- BEHRINGER EURORACK MXB1002 any good?
- PC based solutions? (ASIO)
- BFD for Guitar Rig Eqing
- DSP 8024 software
- Integra DHC-9.9 : Audyssey
- Two subs for 2ch HIFI : Stereo or Mono ?
- To BFD or not to BFD
- BFD Bypass
- Already have a Outlaw ICBM..opt for a BFD setup?
- 2 BFD 1124's FOR 2 SUBS?
- Trinnov Optimizer ST
- Full Range EQ Options - DCX2496???
- Im confused on which "behringer" to buy!
- Reckhorn b1 and b2 differences?
- help with BFD
- SSF project prototype preview
- Intermittently faulty DCX2496
- Name TOP 3 sub EQ's?
- Midi connection with DEQ2496
- Help with FBQ2496
- Isolation Transformer
- Does This Sound Reasonable?
- Phase Shift Audible?
- bfd thump
- pre n post bfd, svs pb12+
- BFD just setup could use some advice.
- Behringer MIC2200
- Help....totally confused
- can i benefit
- SMS-1 Early Results
- Behringer 1124
- Using DCX2496 as EQ and crossover with REW
- KRK Ergo ?
- Wiring
- Trinnov
- Newbie Question
- Does the FBQ2496 add a delay…?
- Digital Room Correction for the rest of us?
- Connecting one sub to two systems
- Which is best BFD 1124P or SMS-1
- EQ Challenge
- DEQ2496 digital input volume
- Multiple subs and BassQ
- SMS-1 Update to 2.1.3
- Behringer DCX2496 1/3 smoothing?
- Setting BFD With 4 Subs
- Guitar Hero USB MIDI adaptor
- Recommended one box sollution for sub rumble filter and EQ?
- anyone in Portland area with ECM8000 and DEQ2496
- Giving the BFD a makeover?
- BFD Placement
- anyone has any experiece with IK Multimedia ARC
- Sub in corner + parametric EQ = No more muddy sound?
- BFD Systemic Problem with Hum
- 1124 Power Surge Failure
- DSP1124P and Hi-Rez Audio
- BFD or FBQ for Studio Applications?
- DEQ2496 RTA question
- FBQ2496 DJ Setup
- New and confused
- FBQ2496 Connection
- Input level - compromise between bits or amp performance?
- Sub Equalization With High Pass Filter
- Heartbeat sound coming from sub when changing tv channels..
- Anti mode 8033 question
- Will a BFD help my situation?
- BFD as crossover/to prevent DC from reaching sub
