- what exactely do I need for REW
- Behringer EURORACK UB802 or XENYX 802?
- Does this look good?
- HUM ???
- Binaural Mics used for REW? am i making a mistake?
- Mic Pre-Amp Options
- Kicking off my "Room Measurement" project
- No sound from Laptop
- Surround Mixer app for Creative SB Live 24 bit external
- maya 44 pci or m-audio firewire solo?
- ECM8000 gone bad??
- Extech SPL meter
- SRM Turtle beach help!
- Galaxy CM-150 = Monarch 322?
- Vista, Behringer UCA202 set-up my turn
- Difference between A and C graphs
- Xenyx 802 vs MIC100
- Using REW with a DigiDesign Mbox
- Alternative mic to RS SPL?
- Radio Shack 33-2050 Frequency Response
- Phonic PAA3
- Creative Soundblaster 24-Bit External USB card - noise in right channel
- Rolls PB 23 ?
- Vista, Behringer UCA202 set-up?
- Help Using Calibration Mic on Denon 3808CI
- Audssey setup vs. REW
- Denon Microphone
- Comparing CALIBRATED microphones
- Cheap soundblaster card
- Soundcards in Canada
- pros and cons ECM8000 vs CM-140 or CM130
- Behringer Xenyx 802
- EMU 0404 USB 2.0 Midi/Audio Interface
- Hmmm, OK I'm stumped w/ initial REW run
- Use 1/3 octave or Narrowband Cal File
- Why do certain areas of my room have feedback?
- Connecting Mobilepre USB?
- Sound Blaster Live 24 External driver
- An alternative to the ECM8000
- Which SPL meter for me??
- need some advice
- MB 4000C for broadband sweep?
- SPL Cal procedure on ECM8000
- How to input 2 mic in laptop?
- DBX RTA-M Calibration curve?
- DEQ2496 phantom power for ECM8000?
- WaterFall Loopback Delay
- Is my RS Digital SPL Meter Damaged?
- Polarity in electronics & speakers?
- Probably a stupid question Re correction figures
- Recommended audio card?
- cheap cables ok?
- Which Sound Card
- Sound Card Specs
- ECM8000 w/ M-Audio MobilePre
- sound calibration and beyond, a few questions
- drivers for soundcard m-audio 2496
- measurement to two channels
- Really need a meter?
- Galaxy CM-140 range (Newbie Question)
- Real Traps room measuring mics comparision
- Microphone Calibration Question
- Samson MM01 measurement mic + RoomEQ wizard+ Mbox ?
- Calibration problem..
- Which SPL meter is worth buying?
- So I got everything I need finally ... now i'm stuck with calibrating.... need help
- Will this microphone work? Parasound C1 / C2 Processor Auto Setup Mic
- Cabling w/ MP3+
- Radio Shack SPL meter -0 analog or digital?
- lame first post, but . . .
- Using Edirol UA-1EX with REW
- digital RS meter
- Rode NT1-A and m-audio questions
- Galaxy 140 has no threaded socket for tripod
- MXL Mic Mate?
