PDA
View Full Version : SPL Meters | Mic's | Calibration | Sound Cards
Pages : 1 2 3 [4] 5
  1. Shure RPM 420 preamp
  2. Older cal file?
  3. Need Help!!!
  4. Edirol UA-25 + ECM8000
  5. Looking to buy...Recommendations
  6. SMS-SVS Advice
  7. Laptop Soundcard Question
  8. Portable recorders...Sony PCM-D50?
  9. vista
  10. Just got a new toy! Yayy
  11. USB SoundCard - VISTA compatible
  12. ECM8000 + Motu Ultralite (hiqh quality preamps)
  13. Where can I d/l RS SPL calibration file(s) for REW?
  14. Where to from ECM8000?
  15. Galaxy 130 and/or PCM-6100 mic
  16. Galaxy CM-140 & Fast/Slow setting for REW
  17. REW and home stereo setup
  18. SPL Meter Lesson 1
  19. what settings to use on the begringer mic800 preamp
  20. ECM8000 microphone measuring techniques and usage discussion
  21. Mic phantom power
  22. SPL meter frequency range question
  23. EM-U 0404 USB Calibration
  24. Radio Shack SPL Meter - Analog or Digital?
  25. REW Cabling and Connection Basics
  26. ECM8000 Orientation and Cal Files
  27. External soundcard recommendation needed.
  28. Tascam US-144 or M-Audio Mobile Pre or ??
  29. Damaged meter?
  30. Best USB sound and midi module including Phantom mic input !
  31. Velleman DVM 1326 SPL meter
  32. Request for article
  33. ECM8000 cal file and mic orientation
  34. Where to get Radioshack SPL 33-2055 in Toronto Canada
  35. Calibration
  36. Why not Radio Shack for full scale measurements?
  37. Question about Galaxy 140 and M-Audio Mobile Pre
  38. should i calibrate the ecm8000 or use the calibration file
  39. ECM8000 orientation
  40. Radioshack SPL 33-2055. Can I use the Galaxyaudio spl calibrator on it?
  41. Radio Shack 33-4050
  42. Radio Shack Analog SPL Meters Giveaway!
  43. Digital RS SPL meter
  44. Anywhere to get a primer?
  45. Mic and SPL calibrations
  46. Xenyx802/ECM8000 Set up help
  47. Calibrate anyway?
  48. Is this preamp OK?
  49. Calibration diagrams
  50. E-Mu 0404 USB with Phantom Power for ECM8000
  51. Which external sound card do you recommend?
  52. Macbook running Vista--Soundcard?
  53. Soundcard calibration
  54. Newbie speaker set-up questions
  55. New Toys - Excited
  56. Extech 407730 SPL Meter
  57. ecm8000 high freq problems
  58. Art MicroMix
  59. 2 subs at each side of room
  60. digital Radioshack meter
  61. Does anyone know how to get hold of Kim Giarardin?
  62. How to...
  63. B&k 2218
  64. Do I need a ECM8000 ?
  65. AKG 451EB as REW mic?
  66. ECM8000 or Galaxy - CM-140? Which way to go?
  67. Cable problems
  68. What are my mic options?
  69. Galaxy CM-140 SPL Meter - International Sales
  70. Does the BFD
  71. Radioshack meter and max mode
  72. Behringer ECM8000 / SMS-1 mic
  73. Ypao Mic
  74. Modification for the RS meter
  75. Head is spinning - help with soundcard/mic choice?
