- Question on ratshack meter and sub level.
- Question about mic preamp
- Need a soundcard for REW? How about X-Fi for $20??
- Sphynx same as RadioShack?
- "C" weighting question
- RS SPL orientation - horizontal or vertical
- B&K model 2230 SLM
- Could I use this soundcard with REW?
- Do I need a Galaxy CM-140
- Tenma 72-860 SPL Meter .cal File
- Feedback from my Radioshck sound level meter
- preamp for Behringer mic comparison--which should I keep???
- Settings to use on Galaxy cm-140 (manual measurements)
- Behringer ECM8000 still the one to get??
- Old Radio Shack SPL cal
- Looking for "full-range" 33-2050 cal or txt file.
- Which Correction values to use for RS model 33-4050?
- Galaxy CM-140
- Will sound Blaster Audigy work in Room EQ Wizard?
- better mic recommended?
- New RS SPL Meter Corrections are posted...
- Galaxy CM-140 Calibration File Info Thread
- Inexpensive external soundcard - and my tips on setting it up
- Galaxy CM-140 SPL Meter Pre-Order
- USB-Pre External soundcard
- ECM8000 C weighted
- RS Meter over 4K~5K - useless?
- my digital rs spl is 6 years old
- REW & RS Digital Meter - strange results in the high freqs
- Strange RS SPL meter calibration results
- Behringer ECM8000 Mic
- Digital spl-meter ok?
- Radio Shack SPL Meter may be gone!
- RA 33-4050 and cal files.
- Rives Audio claims all RS SPL meters measure the same, here you guys say they dont...
- Please help me understand the RadioShack 33-2055 correction table
- Voltcraft SPL-meter
- Behringer UB802 response
- FAST or SLOW setting for RS SPL?
- TES model 1350A calibration file wanted
- YPAO mic
- Accuracy of measurements...
- Laptop Microphone input / attenuator
- which microphone to 1124p?
- Question about digital RS SPL meters
- ECM8000-how do I set it up?
- do i have to use calibration #'s for Radioshack spl?
- Yamaha YPAO Microphone accurate?
- External soundcard
- Behringer ECM8000 Mic. Question.
- Soundblaster Live! 24-bit USB External Setup
- When do I switch from RS SPL to calibrated mic?
- Alterations in RS calibration files
- Radio Shack SPL Meter Correction Values (All new *.cal files are published!)...
- external soundcard
- Help with bouncing meter Plz
- RS Digital SPL meter and RCA output with REW
- Mic Calibration - non USA ?
- Whats the purpose of an SPL meter when using calibrated Mic with REW?
- sine waves
- New SPL Meter...
