- HLR model No picture Lamp/color wheel are on
- turning on the dnie option.
- help with PCN5425R service manual and adjustments
- HLN5065 50" DLP TV Shuts Off HELP!!!
- HLR4667W picture freeze with criss-cross green/yellow lines
- Issue with samsung hcm4215w
- samsung hl-s4266w
- HDMI input quit working on HL-R5067WX/XAA
- Green Screen
- samsung convergence please clarify
- hl56a650 samsung dlp ballast or bulb?
- Convergence adjust - squeal and shutdown
- Samsung fixing light tunnel on HLR and HLS models
- HLM617W - Blank Screen but Lamp is Lit
- Replacing Fan#1 on HLS4266 DLP
- Samsung DLP model HLR4667WX/XAA
- HLR5067 Problem
- where to find free service manuals?
- The Samsung DLP has sound but no picture, can't power off
- picture problems with a hlr5678w
- HLR 4667 trouble
- Bad PIC on DLP
- DLP 61" Neon green problem.
- Convergence amp replacement - thermal pad or thermal grease?
- Samsung DlP issue
- Samsung HL-R4667W DLP problems
- Listen to this sound, is it the color wheel?
- Samsung HLR5067W won't power up after surgery
- Samsung DLP HLN5065WX/XAA only works after hours of inactivity
- Broken Lamp Inter Lock Switch
- Sam HLT5087s - flickering then
- HLR6167WAX/XAA Digital board problems
- Samsung HCL473W Crispy Fried board :(
- Samsung PN50A550 screeching, cycling on/off
- Another Sammy HL-R5067W bites the dust
- I think I found a way to fix the digital board. hlr5067w
- Help with my Samsung DLP hlr5067wax/xaa
- HLN467WX - Three blinking lights.
- HL-5067W Power On Problems
- Problem with 54" Samsung PCN5425R...
- Samsung hlr5067wax/xaa
- Samsung HLN617WX No Picture
- Samsung hls4266wx/xaa
- trouble shoot a Samsung DLP 50"
- blue crt in and out of focus
- interesting problem with HCN4226W/HCM4215
- 3D Glasses (only no SW)
- HLT6189 Wireless USB?
- Samsung HL-4266W will not turn on
- Display issue with HLR5678w
- Samsung HL-R5067W Won't turn on (Lamp, Standby, Timer Lights)
- Original STK's for HCM5525W??
- Samsung HL-R5067W
- HLR5067 vertical green (mostly) bars
- Viore RPT50V24D (Samsung) DLP Problem
- Samsung DLP HL-R5067
- Help: Samsung DLP SP-52Q7HR
- Samsung HL-5067w starting problems
- Sammy HLR4667WAX/XAA Help!
- samsung plasma white rolling line
- Samsung PCL545RX/XXA Problem Solved!
- Pcl545rx/xxa
- samsung hls4266w work fine then cuts off
- Samsung PCN5425R
- Samsung DLP HL-R5067 blinking lights
- Resistor questions
- SAMSUNG RPTV convergence problem
- Need Help w/ HLR 5067WAX 52" TV
- hlr6167 Turning Off Intermittenly
- HL-R5067W hard to turn on
- DLP TV suddenly scrolls white/yellow bars,etc.
- It's back "Unsupported Mode"
- Replaced Color wheel
- looking for help
