- Limited subwoofer options - what to get?
- pressure waves in room
- SVS Pb12+ vs HSU HO
- I don't really hear my bass!
- Martin Logan Dynamo Sub - Thoughts?
- SVS vs HSU Question (yea, I know.... another one)
- 120dB, 2metre high 25Hz.............
- What am I Missing with my V125?
- Under 300
- SVS SB12-Plus Subwoofer: The Mouse That Roars
- Zu Method or Mini Method
- NHT 12inch sub now... considering HSU VTF-3 HO Turbo upgrade
- Lots of distortion what to do???
- SVS or Fathom F113?
- Best Sub under $700 for big room?
- Small footprint/big sound??
- SoundSplinter Rp-15
- how much for my sub??
- Noisy subs
- What new sub should I get
- JL Audio Fathom f113 Ground Plane Results
- Dynaudio vs SVS subwoofer?
- Highest level in the LFE.1
- Vibration isolation....?
- Rear Sub
- 1st post. newbie ?
- Forward firing, downfiring or sideways?
- Options for remote controlling your subwoofer
- JL Audio Fathom F112 subwoofer review by Tom Nousaine
- Forward vs downward firing subs...
- Picked up a xsub.
- Sub Wiring Question????
- Best small powered subs for music only!
- strange thumping sound...
- New Subwoofer Technology
- Bass Effects on Downmixing DD to Stereo and Spectrum Labs information
- New subwoofer woohoo
- Music/Movie Switch = Slam/Depth Switch???
- How to keep my sub from "dancing"
- Velo SMS-1 calibration vs. sub "auto-on"
- Rainy wkend ahead / need sub hookup advice
- Help With Subwoofer Choice For Large Room
- Need help choosing new sub please!
- Fan is a subwoofer
- velodyne spl1000 in bigger box
- Advent and Sunfire (Bob Carver) subwoofer?
- Loud Noises at Night
- Subwoofer LFE adjustment questions...
- Riser Sub. new to Forum
- sub amplifier question...
- Round or square
- Sub locations...
- Four Subwoofers
- Subwoofer Tests - Spring 2006
- Best Way to EQ 2 Subs?
- Finally Corner Loaded
- Passive radiator
- Velodyne DPS-10
- Velodyne DPS-10 Subjective/Semi-objective review
- 2 sub placement
- New Drivers from Hawthorne Audio
- Another Face Off Thread
- My sealed 12" nearfield measurements.
- Sub wiring - Line in 0r speaker
- Driver Sensitivities and SPL's
- One or Two Subs
- Problem with Sub Sound
- Monolith DF Base Panel
- Face-Off - SVS PB10-ISD Takes On A Few Contenders
- Cable Run for Subwoofer
