- Attempts at using waterfall graphs with frequency response to set filters
- snafu
- Can Someone Help Me Interpret My Graph?
- Should Measure Be Mono?
- First Butchered Graph
- inconsistent results with the various sweep rates.
- soundcard calibration, what am I doing wrong.
- Moving from REW 3.x to 4.0 gold
- REW active filter question
- graph of my sub
- Setting up house curve??
- REW review and comparison to AP System 1
- use of multiple sweeps in measurement
- EMU 1820m Help? - Don't Think Calibration is Correct?
- Odd Impulse Response
- Fuzzmeasure Users: Can it do EQ emulation?
- sound card calibration problems
- REW and Edirol UA-1EX: Anyone get this to work on a mac?
- Can't get input to match output on calibration...
- Strange calibration result....
- My Graph
- Can't get rid of peak at 80Hz
- Different readings from different computers...
- Filtering with an sblive/audigy/audigy 2
- Can't get REW to import response
- Soundcard problems: Native Instruments Audio Kontrol 1
- MP3+ Setup?
- E-MU 1616M soundcard calibration help needed.
- Is this response curve OK??
- computer noise
- help me interpret this graph
- newby questions
- Built a sonosub and have a question?
- compatible sound card enquiry
- Just curious how this compares. newb alert!
- Please help REW with FBQ2496
- sub hums if I turn on SPL meter
- Max cable length with REW?
- can REW measure sub delay?
- Please Help Me
- no gain on sub amp
- BFD filters nothing like predicted response.
- Room mode measurements
- Question about multiple subs in REW
- Sure would like to add some boost .....
- Now this isn't right...
- Will this work?
- What is Q Factor?
- First sweep. Does it look normal?
- Software EQ?
- Now what? Please give comments
- Anyone get REW/soundblaster to work with Vista?
- Hidden HT
- Soundblaster set up problems..
- 1st day using REW
- Some questions before I purchase ...
- Sound Blaster MP3+ - REW Measurement toness cut in and out... ???
- Any hope for my poor room?
- Trouble calibrating SB audigy2zs in REW- need help
- Creative X-Fi & Vista?
- Pls help integrating mains and sub
- Help with understanding my graphs
- Could this be right?
- Unable to download REW
- help with using REW
- Headroom question using REW
- Recommended Processor/Receiver For Use With BFD/REW
- Guide to using REW with Convolver...
- How do you get the info from RoomEQ to the 1124
- Check levels with Sub Problem
- Equalization using HTPCs ?
- Setting distances
- Phase control.....no effect?
- Using REW to measure headphone SPL.
- Slight problem but probably nothing
