PDA
View Full Version : REW Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25
  1. Setting distances
  2. Phase control.....no effect?
  3. Using REW to measure headphone SPL.
  4. Slight problem but probably nothing
  5. Set lowest frequency for sweep
  6. House Curve Comments
  7. Range and integration questions
  8. Shiva Graphs to compare with SD-12
  9. Using REW to access new equipment
  10. Does Windows XP updates mess with REW?
  11. Do I need room EQ?
  12. I want to simplify my equipment setup, can I do this?
  13. TFC : a new software complementary to REW
  14. REW crashes on startup
  15. Room EQ Wizard Doubles as Crossover Design/Measurement Tool
  16. REW repeatability.
  17. Is there a REW compatible sound card list?
  18. REW, M-AUDIO Solo and OSX
  19. Another "Need help with soundcard" situation.
  20. EQed sub, now how do I intergrate it?
  21. Noobie with REW help with measurements
  22. REW Ideas / Features
  23. Should I EQ??
  24. DSP1100 and REQW
  25. Average House Curve
  26. Need help with Soundcard Cal
  27. A little help needed with REW and house curves please.
  28. Digital out
  29. Hi Newbe here question about REW
  30. Twin Servo 15's - 1st play
  31. REW sound ideas
  32. About to take the REW/BFD plunge…A couple questions please
  33. SPL Meter panel clarification setting
  34. A Few Questions
  35. readings after room treatments
  36. Room response data - how do I?
  37. Input level, starts to decrease by itself
  38. Full Range Measurements with REW - What Equipment?
  39. First Shot at REW/BFD
  40. some issues figuring this all out
  41. Finally got it working - results - input appreciated
  42. low input
  43. When calibrating SBLive low signal level
  44. new sound card....1st attempt
  45. Please help me with my 20dB+ peak and 10dB dip!
  46. Lets try this soundcard cal thing again.
  47. First Measurement, doesn't look good.
  48. getting ready for REW couple questions.
  49. Did I calibrate my soundcard correctly?
  50. USB/MIDI interface -XP Media center What works
  51. Any Room EQ Wizards in Orange County, CA
  52. Will my Sound Blaster Audigy 2 ZS work in REW?
  53. Room EQ Wizard Sound Blaster Audigy 2 ZS
  54. Frequency response of AVRs?
  55. Amplitude at Crossover Frequency
  56. REW not recognising USB Midi cable
  57. learn from my mistakes.
  58. DPL2 and REW
  59. 1st attempt at REW
  60. Lose EQ Correction Settings Between Measurements?
  61. input level not stable with ecm 8000
  62. Making progress, continued help appreciated
  63. What do you think?
  64. REW Issue #1: Calibrating SoundCard
  65. First graph
  66. rew wiring connections
  67. No change after BFD...
  68. Live Pro Sound - Is REW Applicable??
  69. REW trouble with LF Waterfall
  70. Importing Low Freq Data from ETF?
  71. More than One Listening Positions
  72. Post BFD results....
  73. am i doing something wrong ?
  74. Getting ready for REW?
  75. computer recommendation for REW
